Musical Fidelity Typhoon Power Amplifier (Sold)
Made In England
Internally, the Typhoon is dominated by the 16 power output transistors, each of which is mounted directly on to the pcb through its own finned heatsink.
The two stereo channels are completely independent— separate bridged rectifiers and reservoir capacitors and so on—only the mains transformer being common to both, and even on that there are separate secondary windings so to all intents and purposes,
this is two mono specification amplifiers in a common case.
Operational amplifiers are used again to process the balanced input signal but discreet transistors are employed beyond that in the gain and pre-driver stages. One by-product of balanced operation is the ease with which bridged operation can be established.
In this mode the two channels of a stereo amplifier are driven anti-phase with respect to one another to form a composite mono device of very much greater power; the loudspeaker is connected across the two 'hot' terminals.
Together with an up-rated power supply these give it a continuous power output rating of 45 watts per channel into 8 ohms and, more significantly, a remarkable 60 amps instantaneous peak current ability.
A bridged Typhoon is rated at 150 watts into 4 ohms.
Price : RM 750
Last edited by HiFiLab on Mon Mar 17, 2014 8:10 pm; edited 1 time in total (Reason for editing : sold)
- Number of posts : 2967
BUMP
HiFiLab wrote:
BUMP
» Musical Fidelity Typhoon HP Power Amplifier (Used) SOLD
» SOLD-musical fidelity typhoon hp power amplifier used
» Musical Fidelity Typhoon XLR Balance Pre and Power Amplifier (sold)
» Musical Fidelity Typhoon Power Amplifier
» Musical Fidelity Typhoon HP Power Amplifier(used)
