Bryston 3B SST2 Power Amplifier (Used)
Item: Bryston 3B SST2 Power Amplifier
Condition: 8.5/10. Item is in mint condition. Have been in the hifi rack since it was purchased about 3 years ago.
Comes with original box packaging.
Price: sold
Contact: 012-3816611 Raymond
![Bryston 3B SST2 Power Amplifier (Used) Brysto10](https://i.servimg.com/u/f55/14/76/78/48/brysto10.jpg)
Specs:
Features:
Bryston SST2 C-Series Upgrades
Some info here:
http://www.audioadvisor.com/Bryston-3B-SST2-150-Watt-Stereo-Amplifier/productinfo/BY3BSST2/#.UpWWJsQW2-0
http://www.10audio.com/bryston_3bsst2_4bsst2_7bsst2.htm
Manual:
http://www.audioadvisor.com/pdf/3Bsst_4Bsst_MANUAL.pdf
Thank you.
Price: sold
Specs:
- Power output: 150 watts per channel at 8 ohms, 250 watts at 4 ohms, 3400 watts bridged at 8 ohms
- Gain and sensitivity: 29 dB at 1.3v; 23 dB at 2.6v
- Distortion: < 0.005% from 20Hz to 20kHz at rated output into 8 Ohms
- IM or THD + noise: < 0.007% from 20Hz to 20kHz at rated output into 4 Ohms
- Noise (Measured with input shorted; 20 Hz to 20 kHz): >110 dB below rated output @ 29 dB gain (-75 dBu); >113dB below rated output @ 23 dB gain (-78 dBu):
- Slew rate: Greater than 60 volts per microsecond
- Power bandwidth: From less than 1 Hz to over 100 kHz
- Damping factor: Over 300 at 20 Hz, ref. 8 Ohms
- Input Impedance: 50k Ohms single-ended, 20k Ohms balanced (10k each leg)
- Dimensions" 19" wide, 5.25" high, 12.5" deep
Features:
- 150 watts per channel at 8 ohms, 250 watts at 4 ohms, 400 watts bridged at 8 ohms
- Soft start circuit on power up
- Multiple filter capacitance per channel
- Selectable Balanced or Unbalanced inputs
- Low noise and distortion
- Modular design with independent power supplies
- Remote 12 volt trigger
- Selectable gain
- Available in Silver or black finish with 19 or 17 inch faceplate
- 20 Year Manufacturer's Warranty
- New power supply transformer design
- New push on/of power switch
- New chassis design
- New 'Soft-Start' circuit
- New balanced input stage
- New power supply board
- Bridging mode performance improvement
- Reduced point-to-point wiring
- Reduced circuit board count
- Redesigned output chokes
Some info here:
Manual:
Thank you.
Last edited by raymond88 on Wed Jan 08, 2014 10:04 pm; edited 2 times in total (Reason for editing : sold)
» Bryston 3B SST2 Power Amplifier
» Bryston 7B SST2 Monoblock Power Amplifier
» Bryston 4B SST2 Dual-Mono Power Amplifier
