doge audio kt88 int tube amp...
Hi all,
Equipped with one of the best tubes, you can own this unique designed int amp for $1,799 (before tax) limited period.
TECHNICAL SPECIFICATIONS :
Output power :
55W RMS per channel, Max power : 90W
Max putput power : 90W per channel (rated at 40Hz to 20Khz)
Tubes components : KT88 x 4, 12AX7 x 2, 12AT7 x 2
RCA Inputs :5 + 1 for phono
Tape monitor :no
Remote Controller :YES
Bandwidth :16Hz - 60KHz
Signal to noise ratio :>87db
THD :<0.3%
Input impedance :50K ohms
Input sensibility :300mV
Output impedance:1 x 8 ohms + 1 x 4 ohms
stand-by mode :YES
Size in inches :W:17" x 15.4" x 8.7 (H)
Size in cm :W:43cm x D:39cm H: 22cm
Weight in pounds :48pd + packing
Weight in KG :22kg + packing
Voltage : depending your country : 100V, 120V, 220V, 230V, 240V
visit us at [You must be registered and logged in to see this link.]
email us at sales@hi5loft.com
like our facebook page https://www.facebook.com/Hi5loftPteLtd
Tel. +65 9451 4006
Output power :
Tape monitor :no
THD :<0.3%
stand-by mode :YES
Tel. +65 9451 4006
» Hi5Loft - The Happening Place
» KT88 Tube amp
» Tube Amp KT88 (SOLD)
» Psvane kt88 TII tube
» gec kt88 tube SOLD
» KT88 Tube amp
