Bozak Madisson CLK-PH8 Phono Preamplifier
Hi guys..phono pre amplifier for sale
Condition - Open box
Price - Rm230nett + national courier / pos laju
Contact - 0195582838 Whatapps applicable
Most receivers and amplifiers today lack the phonograph input you need to hook up your turntable. And when manufacturers do include one on newer units, they sometimes use low-cost, low-performance circuitry that yields thin, lifeless results.
The new Bozak Madisson CLK-PH8 phono preamp takes advantage of high-quality, close-tolerance parts to give you the warm, richly detailed sound that vinyl is famous for, at a bargain price. It includes a newly designed external power supply that helps keep noise and interference away from sensitive electronics while also reducing energy consumption. DIN in/outputs also provided.
Features:
Package contents:
Thanks
Features:
- compatible with moving magnet phono cartridges
- external power supply for reduced noise and interference
- metal case shields electronics from vibration and electromagnetic interference
- gold-plated input and output RCA jacks for solid, corrosion-free connections
- dual-mono circuitry for optimal channel separation
- small size allows placement near turntable
- input impedance: 47 kohms/100pF
- DIN in/outputs
- Designated twist on/off grounding terminal
- gain: 32dB
- signal-to-noise ratio: 88dB
- THD: 0.005%
- RIAA response accuracy: 0.5dB (20-20,000 Hz)
- 2-3/4"W x 4-3/16"H x 1"D
- warranty: 3 years
- 30-day money-back guarantee
Package contents:
- CLK-PH8 Phono Preamp
- 100-240VAC to 12VDC power supply (worldwide compatible, EU or AU plug for Intl orders)
- Owners manual
Thanks
fizi- Frequent Contributor
- Number of posts : 1295
Registration date : 2009-02-16
Source(s): Analog - Lenco/Sota/Thorens/Roksan TT/Akai Reel Player / Digital - Ladiva
Amplification: DIY
Speakers: Harbeth/JBL?LINN
» BMC Phono MCCI MM/MC Phono Preamplifier (Used) SOLD
» Pro-Ject Phono Box E Phono Preamplifier (Sold)
» Phono Preamplifier
» Parasound JC3 Phono Preamplifier (used)
» EAR 324 MM/MC Phono Preamplifier
