Various Interconnects: Nordost, Van Den Hul, Atlas, Taralabs, Chord Company, Audioquest, etc
2 posters
Various Interconnects: Nordost, Van Den Hul, Atlas, Taralabs, Chord Company, Audioquest, etc Empty Various Interconnects: Nordost, Van Den Hul, Atlas, Taralabs, Chord Company, Audioquest, etc
Post by raymond88 Mon Mar 17, 2014 1:58 pm
Item: Van Den Hul D300 MK3 Interconnect  - 1m
Condition: 8/10. In good working condition.
Price: RM330.
Contact: 012-3816611   Raymond
Enlarge this image Click to see fullsize
Various Interconnects: Nordost, Van Den Hul, Atlas, Taralabs, Chord Company, Audioquest, etc Vdhmk310
Some info:
After the success of the original D-300, there was demand to make some improvements in the original design. So the D - 300 III HYBRID was born.
The main items are:
The cable is a Hybrid which combines highest quality metal with our Linear Structured Carbon ® (LSC) technology.
Under the shielding one now finds an additional LSC saturated layer to further close the cable against HF signals and to dramatically improve the signal quality.
Furthermore, an extra LSC saturated layer is applied around the centre conductor, this again to improve signal quality and resolution.
Also the internal insulation is more flexible; the material used now is polyethylene-foam with another advantage: reduced capacitance between the signal line and the shielding.
The expanding gas for the foam is completely inert: Nitrogen.
Oxidation of the centre-conductor or the braiding is therefore nearly impossible.
The density of the conductor strands’ very pure silver coating is improved both on the central signal line and the shielding braid.
Furthermore, the flexibility of the external jacket is enlarged by using a new material with a very attractive colour and gold colored printing.
The material used for this jacket is our HULLIFLEX ®.
The electrical and sonic properties are remarkable.
The resistance of the centre-wire is 2.71 Ohm/100 meter and the shielding presents 1.36 Ohm/100 meter.
The internal capacitance is 95 pF/meter.
The characteristic impedance is 75 Ohm.
The external dimensions are nearly equal to the original D - 300: 5.65 mm.
While maintaining perfect audio signal transmission properties, this low priced cable has been especially designed bearing music lovers with a low budget in mind.
The D - 300 III HYBRID’s frequency range is very extended and its low level signal handling is remarkably good.
Van Den Hul The D-300 III Hybrid (Halogen Free)
Length: 1m
Material: Hybrid
Cable type: Coaxial
Conductor material HYBRID: High purity dense Silver coated high purity OFC + Linear Structured Carbon ® saturated layer(s)
Design purpose: Unbalanced audio interlink
Eff conductor Core: 0.636 mm². / ~AWG 19 / Core: 1; Screen: 112
External diameter: 5.65 mm
Jacket colours: Brown metallic
Resistance Core: 2.71 Ohm/100 m.; Screen: 1.36 Ohm/100 m.
capacitance 95 pF/m
Characteristic impedance 75 Ohm
Insulation Core: PE foam; Jacket: HULLIFLEX ® / 300 Vrms min
Connector types Our RCA type C - 5.5
Item: Analysis Plus Oval 1 RCA interconnect 1m
Condition: 8/10
Price: RM380 RM290 nett or swap with your cables
Various Interconnects: Nordost, Van Den Hul, Atlas, Taralabs, Chord Company, Audioquest, etc Analys10
Some information:
For audiophiles who don't need XLR connections, we developed the superb-value Oval One interconnect.
It uses a braided signal conductor in our proprietary hollow oval design along with a braided outer shield mated to a true 75 ohm RCA connector with a low-loss dielectric.
Because Oval One is handmade using first-rate materials, it will outperform other cables costing many times more.
The 100-percent shield coverage ensures the very low noise floor that's essential to experiencing the entire dynamic range of symphonic music.
The RCA connection is solder-less, using a compression contact technique that spares the dielectric from damage that heat from soldering can cause. This technique also eliminates the poor signal transfer that results from a cold solder joint.
Our fussiness adds to the cost of the cable, but the performance increase is worth the added care.
Item: Nordost Flatline Magic 1 Interconnect - 1m (Used)
Condition: 7/10
Price: RM 240
Various Interconnects: Nordost, Van Den Hul, Atlas, Taralabs, Chord Company, Audioquest, etc Nordos10
Various Interconnects: Nordost, Van Den Hul, Atlas, Taralabs, Chord Company, Audioquest, etc Nordos11
Item: Audioquest King Cobra RCA Interconnect - 1.5m
Condition: 8.5/10
Price: RM450
Various Interconnects: Nordost, Van Den Hul, Atlas, Taralabs, Chord Company, Audioquest, etc Audioq10
Item: Audioquest Sidewinder RCA Interconnect - 1m
Condition: 8.5/10
Price: RM150 nett
Various Interconnects: Nordost, Van Den Hul, Atlas, Taralabs, Chord Company, Audioquest, etc Aqside11
Item: Audioquest Topaz X2 Hyperlitz Interconnects - 1m
Condition: 8/10. Smooth, warm tube-like sounding! Clear sound and large soundstage.
Price: RM240 or swap with your cables.
Various Interconnects: Nordost, Van Den Hul, Atlas, Taralabs, Chord Company, Audioquest, etc Aqtopa12
Various Interconnects: Nordost, Van Den Hul, Atlas, Taralabs, Chord Company, Audioquest, etc Aqtopa13
Item: TARA Labs Prism 5 RCA Interconnect - 1m pair
Condition: 8/10
Price: RM190 or swap with your cables
Various Interconnects: Nordost, Van Den Hul, Atlas, Taralabs, Chord Company, Audioquest, etc Tarala14
Item: XLO HTP1 Interconnect - 1m
Condition: 8.5/10. In excellent condition
Price: RM290
Various Interconnects: Nordost, Van Den Hul, Atlas, Taralabs, Chord Company, Audioquest, etc Xloht10
Item: Atlas Equator MKII Interconnect - 1m
Condition: 8.5/10. In excellent condition, comes with original packaging
Price: RM200 or swap+topup with your cables
Various Interconnects: Nordost, Van Den Hul, Atlas, Taralabs, Chord Company, Audioquest, etc Atlas110
Various Interconnects: Nordost, Van Den Hul, Atlas, Taralabs, Chord Company, Audioquest, etc Atlas10
Item: AudioQuest Turquoise 2 interconnects - 1m
Condition: 7/10
Price: RM230 or swap with your cables
Various Interconnects: Nordost, Van Den Hul, Atlas, Taralabs, Chord Company, Audioquest, etc Turquo11
Item: Chord Company Crimson Plus VEE Phono (2RCA) to Phono (2RCA) 1m Cable
Condition: Item is only 2 months old and in MINT condition.
Used only for a while as already upgraded to better cables. comes in original box.
Various Interconnects: Nordost, Van Den Hul, Atlas, Taralabs, Chord Company, Audioquest, etc Crimso14
Various Interconnects: Nordost, Van Den Hul, Atlas, Taralabs, Chord Company, Audioquest, etc Crimso15
Some info:
Chord Crimson Plus
2 RCA to 2 RCA Audio Lead
Now with New VEE Plugs
Real performance has always started with the Chord Crimson. The Crimson, benefited hugely from the development work carried out during the design of the Chord Signature interconnect.
In terms of configuration the cables are very similar.
Both share separately insulated signal and return conductors and a floating shield arrangement. This configuration is part of the reason that the original Crimson performed so well.
The new CrimsonPlus builds on the original Crimson's performance but takes detail levels and dynamics to a new level, stereo image is improved and CrimsonPlus has an extremely neutral tonal characteristic.
During the development of the latest Chord Company high end cable, we learned important lessons about the application of heavy gauge foil shielding. This knowledge has been taken and applied to the new CrimsonPlus.
The improvements are significant and whether the cable is used to link a hi-fi or home cinema, the results are remarkably consistent. The improved shielding also makes CrimsonPlus ideal for longer runs and the cable is particularly impressive when used with subwoofers
Use it with:
The improvements CrimsonPlus can bring can be further enhanced by using CrimsonPlus interconnects in combination with Carnival SilverScreen speaker cable and it is also worth introducing Chord SuperScreen mains cables. The three cables together produce an extremely cost-effective cabling system that will help a system to perform at its best and produce a genuinely musical and involving performance from almost any system. CrimsonPlus can also be used with Chord Carnival Classic speaker cable to good effect.
Terminations:
The CrimsonPlus is available fitted with gold-plated RCA plugs, Din plugs, gold-plated stereo minijack, Neutrik XLR balanced plugs with silver-plated contact areas and ¼ inch mono or stereo jack plugs.  CrimsonPlus can also be terminated with other connectors.  If you have a specific requirement, please contact us.
The CrimsonPlus is available in 0.5 and 1 metre lengths.  Custom lengths are available to order.  We do not recommend the use of Din cables in lengths shorter than 1 metre for reasons of sound quality.
Multi-strand oxygen free copper conductors
Pseudo-balanced twisted pair configuration, High frequency effective floating braid and foil shielding
Low density polyethylene conductor insulation, Vibration controlling outer jacket
Gold-plated Chord RCA plugs - also available in DIN and XLR configurations
Various Interconnects: Nordost, Van Den Hul, Atlas, Taralabs, Chord Company, Audioquest, etc Crimso16
Gold-plated Chord VEE RCA plugs - also available in DIN and XLR configurations
Item: Kimber Kable PBJ Interconnect - 1m pair
Condition: 8.5/10
Price: RM290 or swap with your cables
Various Interconnects: Nordost, Van Den Hul, Atlas, Taralabs, Chord Company, Audioquest, etc Pbj1010
Item: Cable Talk Interconnect - 1m
Condition: 7.5/10
Price: RM100
Various Interconnects: Nordost, Van Den Hul, Atlas, Taralabs, Chord Company, Audioquest, etc Cablet10
Number of posts : 10090
Various Interconnects: Nordost, Van Den Hul, Atlas, Taralabs, Chord Company, Audioquest, etc Empty Re: Various Interconnects: Nordost, Van Den Hul, Atlas, Taralabs, Chord Company, Audioquest, etc
Post by raymond88 Tue Mar 25, 2014 6:23 pm
Post by raymond88 Wed Apr 02, 2014 8:15 pm
Post by raymond88 Sat Apr 12, 2014 8:49 am
Post by raymond88 Thu May 01, 2014 6:28 pm
Post by raymond88 Tue May 13, 2014 7:28 pm
Post by raymond88 Thu May 22, 2014 2:17 pm
Post by raymond88 Thu May 29, 2014 6:44 am
Post by raymond88 Thu May 29, 2014 6:46 am
Post by raymond88 Thu Jul 24, 2014 8:25 am
Post by raymond88 Thu Nov 06, 2014 7:07 pm
Post by raymond88 Fri Nov 21, 2014 8:45 am
Post by raymond88 Mon Mar 09, 2015 10:54 am
Post by raymond88 Wed Mar 18, 2015 8:32 am
Post by ed_chin Wed Feb 17, 2016 9:52 am
Hi, which of these are still available? Please PM.
TQ.
ed_chin
Number of posts : 4
Registration date : 2016-02-04
Post by raymond88 Wed Feb 17, 2016 10:03 am
Bro, this is a very old posting, way back in time.
You can whatsapp me at 012-3816611 and I will update you on what interconnects are available. Tqvm bro. Have a great day.
