Cambridge Audio Stram Magic 6 Hi-Res Audio Streamer
CAMBRIDGE AUDIO STREAM MAGIC 6 HI-RES AUDIO STREAMER
Specification:
Condition: NEW
Colour: Silver
Rated Input Voltage: AC 240V
Selling price: RM4200.00 (Nego)
Warranty: 1 year local Cambridge Audio distributor warranty
Contact: 0122876106 (SMS/Call/What's App/We Chat)
Specification:
Digital to Analogue Converter | Dual Wolfson WM8740 24-bit DACs |
Digital filter: | 2nd Generation ATF2 up-sampling to 24-bit/384kHz. Linear Phase, Minimum phase or Steep modes. |
Analogue filter: | 2-Pole Dual Differential Bessel Double Virtual Earth Balanced |
Digital Inputs: | S/PDIF 75 ohms or Toslink optical |
USB | USB Audio Input USB Type B conforming to Audio profile 1.0 or USB Audio profile 2.0 (user 1.0 or USB Audio profile 2.0 (user selectable) Local USB media 2 x USB 1.1 current limited to 1A each |
File systems | FAT32, NTFS |
Digital Outputs: | S/PDIF Co-axial and Toslink Optical 16-24 Bits, 32-96kHz |
Analogue audio outputs | Balanced XLR and unbalanced RCA analogue audio outputs |
THD @ 1Khz 0dBFs: | <0.001% 24bit (at volume set to full) |
THD @ 1kHz -10dBFs: | <0.001% (at volume set to full) |
THD @ 20kHz 0dBFs: | <0.002% (at volume set to full) |
Frequency Response: | 20Hz-20kHz +/- 0.1dB * |
Signal to Noise Ratio: | -112dBr (at volume set to full) |
Total correlated jitter: | < 130pS |
Crosstalk @ 1kHz: | < -100dB |
Crosstalk @ 20kHz: | < -90dB |
Audio Formats | WAV containing uncompressed PCM 16-24 bit 32-96kHz FLAC containing losslessly compressed PCM 16-24 bit 32-96kHz Apple Lossless (ALAC) 16-24 bit @ 12/16/22.05/24/32/44.1/48/88.2/96kHz AIFF containing uncompressed PCM 16-24 bit 32-96kHz Microsoft® Windows MediaTM Audio (WMA 9 Standard) 32-320kbps MP3 (CBR or VBR) 16-320kbps AAC, HE AAC and AAC+ (CBR or VBR) 16-320kbps OGG Vorbis 32-320kbps |
Streaming Protocols | RTSP (Real Time Streaming Protocol) MMS (Microsoft Media Server Protocol) HTTP (Hyper Text Transfer Protocol) |
Wi-Fi | IEEE 802.11 b/g or n (2.4GHz connection used only) |
Wi-Fi Encryption | WEP, WPA, WPA2 |
Ethernet | IEEE 802.3, 10 Base-T or 100 Base-T |
Mains inlet voltage | 100-240 VAC (switch mode) |
Max. Power Consumption | 30W |
Standby power consumption | <0.5W |
Dimensions (W x H x D) | 430 x 85 x 305mm (16.9 x 3.4 x 12.2”) |
Weight | 4.0Kg (8.8lbs) |
* Steep filter disabled |
Colour: Silver
psyglobal- New Member
- Number of posts : 6
Registration date : 2013-08-16
» Cambridge Audio Stream Magic 6 Hi-Resolution Audio Streamer
» Cambridge Audio DAC Magic (Used)
» cambridge audio dac magic
» WTS: Cambridge Audio DAC Magic (Used)
