Creek Classic A53 Stereo Power Amp (SOLD)
Condition 7.5/10.
Reason for sale: Reducing inventory and simplifying my set up.
Location: Cheras, Selangor / Kuala Lumpur, Taman Maluri
Beautiful thick brushed aluminium face plate.
Able to bi-amp speakers as it comes with two sets of terminals per side.
No box, manual or power cord supplied.
Using it to power my center speaker in bi-amp mode.
Price : SOLD
Contact : 012 6135188 Wong or pm me on this forum
Will upload pictures of actual unit later.
In response to the demand for biamping from Creek 5350SE owners, Creek has developed a simple solution. The British company took a Classic 5350SE and removed everything that was not associated with the power amp section. The engineers removed the preamp, remote control volume, and input selection circuitry, plus the micro controller. The result is the elegantly simple Classic A53 Power Amp.
The Classic A53 Power Amp uses a 250VA toroidal transformer, together with multiple power supply capacitors totaling 31,000uF, 105 degree C, low impedance, to achieve the quality of computer grade capacitors but with very low inductance, for the ultimate in sonic performance.
Like other Creek amplifiers, the Classic A53 is DC servo controlled, to enable direct coupling from input to output and accurate low frequency roll-off, thereby eliminating sonically degrading capacitors from its signal path.
For the technically minded, the Classic Power Amp uses a high current, N channel only, MOS-FET power output stage, driven by a P channel MOS-FET phase splitter and double differential voltage amplifier with symmetrical 'Class A’ driver, to achieve ultra-low distortion and high speed with minimal negative feedback.
Price : SOLD
- Power delivery (both channels): >90 W in to 8 ohms, >180 W into 4 ohms
- Max current: >25 amps
- THD (total harmonic distortion): < 0.05% 20 Hz - 20 kHz
- Frequency response: 3 Hz - 25 kHz - 1 dB
- Power Amp Slew Rate: >50 V per µs
- Input Sensitivity: 559 mV for 90 W
- Signal to Noise Ratio: >105 dB
- Separation: >60 dB
- Power Consumption at Idle: <40W
- Power Consumption at Full Power: 340W
- Dimensions: 17" wide, 2.75" high, 11" deep
- Weight: 15.4 lbs.
Last edited by klimal on Mon Apr 28, 2014 11:58 am; edited 3 times in total (Reason for editing : SOLD)
klimal- Frequent Contributor
- Number of posts : 200
Registration date : 2009-11-11
Source(s): SLAT L75, OPPO 203D, Asus TinkerBoard / Topping D90
Amplification: LL9226 SUT, AHT Non Sig., EAR834 clone, BAT VK-3000SE, BAT VK150se, Emotiva XPA7 Gen3
Speakers: SB Acoustics Rinjani front main, DIY SBA Satori Center, , ELS3 sides Epos KI overheads. , Subwoofers SVS SB16Ultra, PC13Ultra
Re: Creek Classic A53 Stereo Power Amp (SOLD)
Pictures added.
Price reduced.
» PS Audio Classic 250 Stereo Power Amplifier (Used) SOLD
» Audio Research Classic 30 stereo power amplifier (sold)
» Classic Pre Amp & Stereo Power Amp (Used)
» Creek Classic 5350SE integrated amplifier (sold)
» Creek P43 pre & Creek A52se power amp (used)(sold)
