Mission Cyrus 2 with Psx SOLD
Description Of cyrus 2
Essentially similar to Cyrus One, the Cyrus Two provides even greater drive capability for systems requiring more power.
The benefits acquired by moving to the Cyrus Two include an increase in headroom and wider dynamic capability, the extra power allowing it to respond to whatever demands are placed upon it by either the music or the partnering speakers.
In addition, it incorporates a more refined MC section to match and optimise the performance of the most esoteric cartridges available.
But it doesn't stop there. For music lovers wanting even greater power in reserve, the Cyrus Two can be upgraded with the addition of the PSX outboard power supply.
Power output: 50 watts per channel into 8Ω (stereo)
Frequency response: 1Hz to 50kHz
Total harmonic distortion: 0.003%
Damping factor: 100
Input sensitivity: 0.2mV (MC), 3mV (MM), 50mV (line)
Signal to noise ratio: 75dB (MC), 84dB (MM), 86dB (line)
Dimensions: 85 x 215 x 345mm
Weight: 5kg
Cyrus 2 Psx Overview
Housed in a matching enclosure as the Cyrus Two the PSX delivers unrestricted amounts of current-rich power to the Cyrus Two’s amplifier section. Thus dedicating the Cyrus Two’s generous onboard power supply to service the preamplifier section only.
Output voltage - ± 40V
Output impedance - 1 Ohm
Ripple - 750mV peak to peak at 140 watts into 8 Ohms
Noise - 300uV
Transformer regulation - 3% at 500VA
Total PS capability - Typically 0.1 Farad
Output to PCMII
Regulated voltage - ± 18V
Current capability - 1.5A peak
Dimensions - (H x W x D) 85mm x 215mm x 345mm
Finish - Black or Grey
Review:http://forum.audiogon.com/cgi-bin/fr.pl?aamps&1095960619&read&keyw&zzcyrus
Condition :8/10
Price: RMSOLD
If interest do call me at 012-4817282 for more info
THANKS
Damping factor: 100
Weight: 5kg
Noise - 300uV
Output to PCMII
Condition :8/10
Price: RMSOLD
THANKS
StanleyCH- Frequent Contributor
- Number of posts : 304
Registration date : 2014-01-10
» Mission CYRUS-3 sold
» Mission Cyrus Int Amp (sold)
» Mission Cyrus Two(Used)(Sold)
» Mission Cyrus One(Used)(SOLD)
» cyrus 1 mission (used) -sold
