Audio Analogue Fortissimo Integrated Amp
![Audio Analogue Fortissimo Integrated Amp 20140811](https://i.servimg.com/u/f39/14/47/45/93/20140811.jpg)
![Audio Analogue Fortissimo Integrated Amp Audio_10](https://i.servimg.com/u/f39/14/47/45/93/audio_10.jpg)
- Showroom demo set in very good condition
- Come with beautiful remote control, original box, manual
- Flexible connectivity with digital input as DAC, PRE-OUT, Phono input
- Asking RM5000, call Mike 0168606677
Detail Features
• Toroidal transformer analogue power supply with 2 separated lines:
1. Power amplifier supply.
2. All Preamp and small signal sections power supply.
• Separated supply section for each power amplifier channel.
• 4-layer board to minimize the track length and avoid interference between different stages.
• Low noise Solid state Input selector circuits.
• Highest-end quality volume control.
• Low-noise, low-distortion Pre amp stage.
• Automatic thermal tracking power stage.
• Integrated electronic protection designed to work against overloading and overheating with the less interference on
the audio performance.
• Settable Pre/Rec output.
• Phones output.
• Digital SPDIF output giving the selected digital input.
• 16-24 bit Optical digital input accepting a sample frequency as wide as 108KHz. The input can also be set in ByPass
Mode and the gain in bypass mode can be changed in the range of +/-10dB.
• 16-24 bit Coaxial digital input accepting a sample frequency as wide as 108KHz. The input can also be set in ByPass
• Low noise low distortion balanced input.
• 16Bit USB connection accepting sample frequency as wide as 48KHz.
• Preamp MM/MC Phono stage with settable gain and input impedance.
• Line input on the front panel.
• 3 Stereo RCA Inputs.
• 1 Stereo RCA input settable into ByPass mode. When the input is set in BY-Pass mode the gain can be changed in
• RecUSB output carrying the preamplified audio signal to the PC/MAC.
• Trigger In Input, by which is possible to turn on the unit via a 12VDC trigger signal.
• Highest-end quality passive components.
• Microcontroller based equipment management.
» SOLD Cambridge Audio Topaz AM10 Integrated Amplifier and Cambridge Audio SX-60 Bookshelf Speakers.
» Audio integrated
» Audio-GD CIA-400 integrated amp (New)
» Cambridge Audio Integrated Amplifier Azur 351A and Cambridge Audio CD Player Azur 351C (USED)(SOLD)
» Audio integrated
