Audio Note Valve DAC 0.1X USB (Used) Sold
Audio Note Valve DAC 0.1X USB (Used).Made in UK. Condition 8.5/10. Like New. Sold
The DAC 1.0x is the first and currently the only unit in the Audio Note UK range to offer both coaxial 75 ohm SPDIF and USB inputs, selectable using a fascia-mounted switch. The DAC circuit is based around the well-regarded Phillips TDA1543 converter chip and employs 1x oversampling using Direct From Disc technology together with no digital filtering. The DAC 0.1x uses a valve output analogue stage with a 6111WA miniature dual triode, Beyschlag precision resistors and Audio Note tin foil capacitors.
Sold
lawken- Dealer\Reseller\Trader\Service Provider
- Number of posts : 1604
» Audio note SOLD
» Audio Research DAC8(sold)/ Audio Note CDT2 MK2(sold)- used
» Sun audio SV-2A3 valve amplifier (Used)SOLD
» Audio Note OTO SE - SOLD
» Audio Note Dac-Zero (Sold)
