Cypress Dual Active Subwoofer (USA)
2 posters
It has great response for both music and video. Not boomy, but adds depth and presence to my CDs and DVDs. It has all the basic features you want in a quality subwoofer; auto power-off, high-level and LFE inputs, phase switch, built in cross-over, etc. It also has a fairly small footprint which scores high on the spousal-unit scale.
Solid construction and heavy. This speaker produce smooth sound with excellent Bass Response.It won't give you listening fatigue. You won't find any subwoofer with this sound quality at this price.
Drivers : Two 8” Long Throw Hi Efficiency Drivers, Carbon Fiber Cone with Rubber, Surround.
Amplifier : Discrete Linear Class A/B Amplifier
Power Output : 250 watts Dynamic Power
Frequency Response : 20 Hz to 270 Hz, 6 dB ([email=LPF@Max]LPF@Max[/email])
Low Pass Filter : 60 Hz to 125 Hz, 24 dB/Octave (Continue Variable)
Phase Switch : 180 degree Phase Switch (Standby Operation: Auto On/Off Switch)
Peak Outputs (SPL) : 103 dB
Inputs
High Level (Speaker) : Left & Right High Level Speaker Wire
Low Level (RCA) : Left & Right Low Level RCA Jack
Throughputs
Pressure Clip Terminal : Left & Right High Level Unity Gain
RCA Line Jack : Left & Right Low Level RCA Jack
Unit Dimension : 380mm x 280mm x 760mm (15” x 11” x 30”)
Weight Net/Gross : Net 41 lbs. / Gross 44 lbs.
Cabinet Finish : Masa Maple
Power Requirement : 120VAC 60Hz 250 Max
Remark : Entire System Magnetically Shielded
Selling Price RM600 ONLY!!!!
Contact : Jason 019- 388 5148
limcsmis- Regular
- Number of posts : 64
Registration date : 2009-02-18
1
Do you have this subwoofer in pair? Is step-up transformer required?
chiangeg- Club Member
- Number of posts : 41
Registration date : 2013-11-11
Re: Cypress Dual Active Subwoofer (USA)
Hi, required the step down transformer is needed and this is 1 unit .
limcsmis- Regular
limcsmis- Regular
limcsmis- Regular
limcsmis- Regular
» Mirage BPS400 Home Cinema Bi Polar (dual) 12" active subwoofer - SOLD
» [WTS] Energy Passive Dual Subwoofer E-Sub [SOLD]
» Miller Kreisel MK MX dual 12inch Subwoofer
» Subwoofer -NHT10 Active subwoofer(sold)
» M&K MX-100 Dual 12" inch THX Powered Subwoofer(USA)
