OEHLBACH 1008 Made In Switzerland Speaker Cables 2x2.5 mm² (NOS)
OFC - OFC
Highly flexible cable
Robust plastic casing
Stereo Speaker Cable
Amplifier power up to 150 watts
Made in Switzerland
ARTICLE DESCRIPTION
High quality stereo speaker cables for connecting amplifiers
or amplifiers with speaker boxes. Suitable is the
Speaker cable for power amplifiers up to 150 watts of power
per amplifier channel.
The outer casing of this Oehlbach cable is
from a robust and very flexible plastic mixture.
Simultaneously, the inner conductor is built from a variety of
Single strands, which in turn twisted bundles together a
Cable revealed that embarrassed itself extremely well and flexibly
leaves.
As inner conductor material was oxygen-free OFC copper
used in turn for his excellent
Known transmission quality.
SPECIFICATIONS / TECHNICAL DATA
1008 - SPEAKER WIRE
Cable geometry:
flat / flat
Appearance:
clear / transparent
Cable cross-section:
2 x 2.5 mm
Cable dimensions:
9.5 mm x 3.5 mm
Cable length:
1.00 m
Connector type cable end 1:
Terminal / Terminal
Connector type cable end 2:
Terminal / Terminal
Signal:
Audio
Signal direction:
IN / OUT
NOTE
It is sold by the meter.
The price refers to a meter
the speaker cord.
Price : RM 22 Per Meters ( Limited Stock Available)
Last edited by HiFiLab on Wed Jun 03, 2015 12:26 am; edited 4 times in total (Reason for editing : update)
- Number of posts : 2967
UP
BUMP
UP
» OEHLBACH Kabel Made In Switzerland 2 X 4.00mm2 Speaker Cable ( NOS)
» OEHLBACH Made In Germany 2 X 4.00 MM2 Speaker Cable ( NOS)
» Lenco L75 (Made in Switzerland)
» Lenco LT-5000 Made In Switzerland FM Stereo Digital Tuner (Sold)
» Revox Evolution Amp, CD player, Casette Deck, Tuner (All in One System) Made in Switzerland
