AudioQuest Golden Gate Stereo interconnect cable - 0.6m (Used)
AudioQuest Golden Gate Stereo interconnect cable - 0.6m (Used) Empty AudioQuest Golden Gate Stereo interconnect cable - 0.6m (Used)
Post by raymond88 Sun Jan 17, 2016 11:05 pm
Item: AudioQuest Golden Gate Stereo interconnect cable with RCA plugs - 0.6m
Condition: Item is in MINT condition. Used for a while only. With original box packaging.
Price: RM230 or swap/topup
AudioQuest Golden Gate Stereo interconnect cable - 0.6m (Used) Golden10
Description:
While theoreticians debate whether the true nature of the universe is analog or digital, one constant in our audiophile galaxy is that the music, dialog, and sound effects which reach our ears is analog. In order to preserve this precious cargo, AudioQuest has designed a range of analog interconnects optimized for the single-ended world. Bridges & Falls take advantage of years of carefully balancing design and material selection in order to bring you a series of interconnects which, as much as possible, "Do No Harm" to the original audio signal.
To respect different budgets and honor the wide breadth of applications, AudioQuest offers seven models of these new multi-application low-distortion analog interconnects. All include AudioQuest’s proven design expertise featuring: better metals, superior geometry, and our exclusive Noise-Dissipation System. For the upper four models, we employ Air-Tube Insulation, while the top three models use AudioQuest's amazingly effective Dielectric-Bias System (DBS).
Great sound and great pictures, music that consumes you, movies that transport you around the universe ... all come from honoring the original signal. An unavoidable fact-of-life: Every component and cable in a system causes some amount of distortion. These aberrations add up, like layers of foggy glass between you and the image. The goal of high quality components and cables is to be like clean clear panes of glass, altering and distorting the information as little as possible. Some of the most fundamental distortion mechanisms are honored and addressed by AudioQuest’s 4-Elements. Any improvement in these areas of design and materials results in less damage and a more effective, immersive experience.
Solid Conductors
Electrical and magnetic interaction between strands is one of the greatest sources of distortion in normal cables. Separate solid conductors prevent interaction between strands.
Insulation
In addition to insulating, all conductor coatings are also a “dielectric.” Signal flow is slowed down and distorted by a dielectric, making the choice of mate- rial, and AQ’s Dielectric-Bias System, very important.
Geometry
The relationship between conductors, whether of the same polarity (+ & +) or opposite polarity (+ & -) af- fects many electrical and mechanical parameters, in- cluding capacitance, inductance, RF Interference, etc.
Metal Quality
Conductor material quality has a pronounced effect on the signal passing through. Different materials have more or less impurities, grain boundaries, surface irregularities, etc.
Features:
[*]Metal: Solid Perfect-Surface Copper (PSC) Conductors
[*]RCA Plugs: Cold-Welded, Gold-Plated
[*]Geometry: Asymmetrical Double-Balanced (lower impedance)
[*]Dielectric: Foamed-Polyethylene Insulation
[*]NDS: Metal-Layer Noise-Dissipation System
[*]Links:
[*]http://www.audioquest.com/bridges-falls/golden-gate
[*]http://www.crutchfield.com/S-7vV9iI1maW2/p_703GGRR06M/AudioQuest-Golden-Gate-0-6-meter-2-feet.html
Number of posts : 10093
AudioQuest Golden Gate Stereo interconnect cable - 0.6m (Used) Empty Re: AudioQuest Golden Gate Stereo interconnect cable - 0.6m (Used)
Post by raymond88 Mon Jan 25, 2016 11:36 pm
Post by raymond88 Wed Feb 03, 2016 8:14 pm
Post by raymond88 Thu Feb 11, 2016 3:24 pm
