Primare PRE-30 PreAmp
The PRE30 is a fully balanced preamplifier designed with operational simplicity in mind. When used in conjunction with a balanced power amplifier, such as the A33.2 or the A32 and a source that provides balanced outputs, like the CD31, it becomes a significant link in an ultra-low noise signal chain that connects the source with the speaker. Each of the seven inputs may be adjusted for the differences in output level produced by each source. It also provides such useful features as a surround bypass switch, allowing you seamlessly to integrate the PRE30 with a home theatre system.
- Reference Balanced Preamplifier
- Audio Inputs: 5: Unbalanced Stereo (RCA), 2: Balanced Stereo (XLR)
- Audio Outputs Variable: 1: Unbalanced Stereo (RCA), 1: Balanced Stereo (XLR)
- Audio Outputs Record: 1: Unbalanced Stereo (RCA)
- Dual Mono Construction: Totally Independent Power Supplies
- Remote Control Operation
- 5 Volt Trigger Output
- Dimensions:W 430mm x D 385mm x H 100mm (With Feet)
- Weight: 7 kg
Price Before :
But NOW : RM4,150
Richard Yew (+016-6217099)
pls:whatsapp/sms
CMY Audio & Visual S/B
LG2.13,LOWER GROUND LEVEL2,SUNWAY PYRAMID SHOPPING MALL,
NO3,JALAN PJS 11/15,BANDAR SUNWAY,
46100,PETALING JAYA,SELANGOR,
MALAYSIA.
Richard@yew- Dealer\Reseller\Trader\Service Provider
- Number of posts : 228
Registration date : 2016-03-30
» Primare PRE30 stereo preamp (SOLD)
» Primare D30.2 cd player (SOLD)
» primare CD31 and primare I30 amp (used)
» Musical Fidelity preamp 3A mkIII preamp & P 180 power amp(Used)SOLD
» Musical Fidelity preamp 3A mkIII preamp & P 150 power amp(Used)SOLD
