Shunyata Venom-3 Power Cable (New)
The VENOM-3 power cord is likely the finest example of Shunyata Research's commitment to manufacturing products that deliver dramatic power system performance at a value price.
Shunyata Research has invested heavily in custom molds and automation processes to create a high performance power cord that outperforms products that are 3-5 times the cost.
The VENOM-3 is custom manufactured using Shunyata's exclusive, high performance molded AC connectors. These see-through connector designs display the attention to detail and craftsmanship that went into their construction and careful termination.
Shunyata Research uses its own top-quality OFC copper conductors and a 100% coverage shield that isolates the critical "first few feet" of power cable from the strong fields of radiated high frequency noise from nearby electronics.
The VENOM-3 is also extremely flexible and easy to place in even the most space-constrained areas and around any tight corner with ease which is a unique attribute in and of itself!
The VENOM-3's massive 12-gauge conductors make it ideal for all source components and many integrated amplifiers.Pair it with the VENOM-HC on a VENOM PS8 power distributor for a complete high performance power system.If you have very high power amplifiers, use the VENOM-3 on the source components with the VENOM-HC on the amplifiers for the best price to performance value.
Features
PURE OFC COPPER CONDUCTORS
- Oxygen free copper
- Large 12 Gauge Conductors
SHUNYATA DESIGNED MOLDED CONNECTORS
- Solid Brass Contacts (not folded metal)
- Nickel Plating for Corrosion Protection
- Superior Contact Grip
- Crimped and soldered connections
DTCD™ TESTED
- Designed using the Shunyata Research DTCD™ Analyzer
- Ensures maximum instantaneous current capacity
SAFETY ASSURANCE
- Continuity and Polarity Tests - by two technicians
- HiPOT Tests for each cable
- Cable spools tested for insulation breakdown @ 4,000 VAC
MULTIPLE AWARD WINNING CABLE
- Absolute Sound 30 Best Bargains in Audio
STANDARD LENGTH
- US 1.50M
- EU 1.75m
COLOR
- Blue w/white stripe
CABLE DIAMETER
- 0.45 inches (11.4 mm)
ELECTRICAL CONDUCTORS
- OFC 12 AWG
MAXIMUM VOLTAGE
- Max Voltage (US): 90-240 VAC (connector dependent)
- Max Voltage (Asia): 90-240 VAC (connector dependent)
- Max Voltage (Euro): 240VAC (connector dependent)
- Maximum Instantaneous Voltage: 1250 VAC
CURRENT RATINGS
- Max continuous current: 20 Amps (connector dependent)
- Max instantaneous current: >200 Amps (800ms)
ELECTRICAL TESTS
- Polarity and continuity tests x2 (each cable tested)
- HiPOT Test: 2,000 VAC @ 5s (each cable tested)
- Insulation Breakdown Test: >4,000 VAC @ 2 minutes
AVAILABLE CONNECTORS
- US P15 Molded
- EU EURO CEE 7/7 Molded
- IEC C15 Molded
Selling Price : RM882.00 (Call For Best Price)
Steve Chua (+6012.653.5703)
Jeremy Khor (+6010.374.7819)
CMY Audio & Visual S/B
Malaysia.
Tel : +603-7726 6893
Fax : +603-7726 6893
» Shunyata Research Venom Power Cable - 1.75m (2 pcs available)
» Shunyata Research - Venom 3 Power Cable (Sold)
» Shunyata Research - Venom 3 Power Cable (sold)
» Shunyata Research - Venom Power Cable (sold)
» Shunyata Research Venom Power Cable (Used) SOLD
