Naim NAC-112X Pre-Amplifier (Display Unit)
Naim NAC-112X Pre-Amplifier (Display Unit) Empty Naim NAC-112X Pre-Amplifier (Display Unit)
Post by steve126 Thu May 05, 2016 10:12 am
Naim NAC-112X Pre-Amplifier (Display Unit) 112x10
Naim NAC-112X Pre-Amplifier (Display Unit) 112x_b10
Description :
The Naim Audio NAC 112x takes its inspiration from our top of line, world beating preamps and is designed to offer great sound and useful features in an affordable compact and flexible unit. Six high level inputs can accommodate a wide variety of sources.
Volume and balance are controlled via a sophisticated discrete resistor ladder to optimise sound quality and channel matching. Time aligned filter networks, star earthing and optimal circuit layouts have all been carefully designed using the latest CAD technology and extensive listening tests.
Improvements over the original NAC 112 include: a new main board design for improved performance; a new display PCB using SMT (Surface Mount Technology) for lower noise; two switchable DIN or Phono inputs; an RC5 socket for easy external remote control without line of sight; an optional RS232 connector for external system contro; and a new rear panel layout for ease of use on a Fraim. The NAC112x can be powered from the supply provided by the NAP150x and can be upgraded by adding a FlatCap 2 or HiCap power supply.
Specifications :
Input Sensitivities..............................75mV, 47kOhm
Overload Margins..............................35dB (all inputs all audio frequencies)
Main Output Level.............................0.775V, <50 Ohms
Tape Output Level.............................75mV, 600 Ohms
Auxiliary Power Outputs....................For Stageline/Prefix phono stage.
Dimensions(w x d x h).......................43.5 x 33.5 x 7.5 cm
Weight.............................................5.5 kg
Selling Price : RM7,425.00
Offer Price    : RM4,900.00(Limited Stock Only!!)
Steve Chua   (+6012.653.5703)
Jeremy Khor (+6010.374.7819)
CMY Audio & Visual S/B
Malaysia.
Email :     [You must be registered and logged in to see this link.]
Website : [You must be registered and logged in to see this link.]
Tel :  +603-7726 6893
Fax : +603-7726 6893
steve126
steve126
Number of posts : 373
http://www.cmy.com.my
