Goldmund Mimesis 18.4. Mono Power Amplifier (Used)
A pair of used GOLDMUND MIMESIS 18.4 mono amplifier in good condition (7.5/10) for sale. Come with original box. Asking price RM 30K. (reduced) 3 months warranty COD in Klang valley Pls call Cheong o123o6-3455 Spec: - Nominal power : 200 W RMS (2 - 8 Ohms). 120 W RMS (1 - 16 Ohms). - Maximum instantaneous power : 400 W RMS (8 Ohms). - Maximum voltage swing : 62 V peak. - Maximum current swing : 20 A peak. FREQUENCY RESPONSE These figures are valid for the circuit alone, at any level between 0 and nominal power. - +/- 0.1 dB, 0 - 300 kHz, +/- 1 dB, 0 - 800 kHz. - +/- 3 dB, 0 - 2 MHz. INPUT SENSITIVITY - Nominal level : 1.45 V RMS. - Voltage Gain : 29 - Input impedance : 52 kOhms. GROUP DELAY - Propagation delay < 140 ns stable with frequency from DC to 200 kHz. DISTORTION Figures valid for all levels from 0 to 26 V / 8 Ohms : - Dynamic : TID < 0.01 % (- 80 dB). - Static : THD < 0.01 % (- 80 dB). - Signal-to noise ratio : > 115 dB. - Weighted ASA A : > 130 dB. OPERATING TEMPERATURE - Room temperature : -30 to +40 degrees Celsius (-22 to +104 degrees Fahrenheit). - Internal temperature : +45 to +65 degrees Celsius (+113 to +149 degrees Fahrenheit). POWER SUPPLY 7 - Nominal line voltage : 117, 234 V (internally switchable). - Input voltage range : +/- 10 %. - Maximum power consumption : 700 W. - Power used in standby : 70 W. - 4 toroidal transformers, 3 separated power supply. GROUNDING - Chassis connected to mains earth. SAFETY FEATURES - AC voltage fuse : min 5 A slow-blow for 220 V / 8 A slow-blow for 110 V. - Built-in detection for HF and DC with speaker disconnection. FRONT PANEL CONTROLS - Power key. - 3 control Leds (Safety, Power, and Digital Lock) REAR PANEL CONNECTORS AND CONTROLS - Power cord: universal socket 3 lugs. - Main fuse (8 A slow-blow 110V / 5 A slow-blow 220 V). - Green-yellow AC earth binding post. - Earth connection switch to connect earth and signal ground (link-float). - Output speaker 2 X 5 ways post. - Output speaker Coaxial for Goldmund Speaker cable. - Analogue Input connectors : RCA and XLR for balanced input. - Digital Input connector RCA for input and output. - Digital input channel selection switch. - Input attenuator : -9, -6, -3, 0, +3, +6, +9dB SIZE AND WEIGHT - 22 cm (17") W x 44 cm (17") D x 17 cm (7") H. - Weight : 25 kg net Thanks For viewing! |
Novman- Frequent Contributor
- Number of posts : 321
Registration date : 2012-05-29
» Goldmund Mimesis 11 Digital Hub / Preamplifier And Goldmund ProLogos Plus Wireless Speakers.
» GOLDMUND MIMESIS 18.4
» Goldmund Mimesis 27.8 / Telos 280 (used)
» Goldmund Mimesis 12 DAC (Sold)
» Goldmund Mimesis 18.4 Monoblocks
