collector item Threshold SA3 class A power amp
TRUELY A LEGEND! THRESHOLD SA3 PURE CLASS A AMP WORKING PERFECT VERY GOOD CONDITION.
listed following comments from other seller ; threshold SA/3 Stasis Power amplifier Optical Bias Power Amp. 50 watts per channel -- Pure Class A. These amps do not come up for sale very often -- for good reason. Designed by Nelson Pass during Threshold's heyday and considered to have very smooth sound, good thermal stability and more detail than Threshold's earlier amps. Threshold referred to the sound of this SA series as "extraordinary musical accuracy". The SA/3 is a favorite of Threshold lovers for its warm sound, and this amp is built like a tank. Machined-aluminum faceplate and metal chassis. Gold-plated machined Teflon insulated input connectors, five-way binding posts with gold-plated contact surfaces, military grade glass epoxy circuit boards are all hand soldered, and assembly and final adjustment was completed under the supervision of Nelson Pass. It delivers 16 continuous amps and 80 peak amps per channel and will effortlessly drive most speakers. Threshold SA/3 50watt/channel Stasis Pure Class A Power Amplifier. This amplifier, designed by Nelson Pass and Built in the USA by Threshold employs pure Class A circuitry at every stage - there is no corrective feedback loop, and the resulting sound is absolutely unmatched. There is nothing on the market today that comes close. This amplifier will drive even the most difficult speakers (think Quads or other electrostatics), as well the simplest bookshelf system, to the very limits of their sonic capability. Circuit boards are military grade, glass epoxy, with gold over nickel over¥ copper plated traces. All connections are hand soldered. This is truly a limited edition. Input connections are gold plated. This amp is absolutely Gem Mint inside and out and sounds magnificent. It weighs 56 pounds.
selling at rm 7500.
watsapp 017755320seven for viewing.
selling at rm 7500.
ferringi2000- New Member
- Number of posts : 3
» Threshold SA-1 Monoblock power amp class-A
» Threshold T-200 100Watt Class A power amplifier
» Threshold T-50 Class A Power Amplifier。(Used。) ~SOLD.
» Threshold S-200 Class AB Power Amplifier ( Used ) - SOLD
» Threshold Stasis 3 Power Amp - Class A 125 Watts - SOLD
