Raphaelite DP34 II Integrated Tube Amplifier For LS3/5A (Used) SOLD
Used unit of Raphaelite DP34 II integrated tube amplifier, specially made to match the output impedance of LS3/5A at 11 Ohm and 15 Ohm.
Raphaelite is one of the best tube amplifiers manufacturer in China. They produce finest quality tube amplifiers with the special vintage look and has been established for more than a decade. Their power and output transformers are gaining very good reputation amongst audiophiles.
DP34 II is specially made for driving LS3/5A. The output impedance are 11 Ohm and 15 Ohm, which match perfectly with both 11 Ohm and 15 Ohm of LS3/5A.
DP34 II is based on a GZ34/5AR4 rectifier, 12AT7/ECC81 preamp stage and E99CC/6DJ8 as phase inverter. EL34 output stage uses fixed biasing. Plate current can be monitored via a VU meter and adjusted by simply rotating screws linked to the variable resistors besides the power transformer and precisely matched. The amplifier is of point to point soldering/wiring instead of using PCB board.
Technical Parameters
Model : Raphaelite DP34 II Integrated Tube Amplifier
Tubes : 5AR4/GZ34 x 1, E88CC/6DJ8 x 1, 12AT7/ECC81 x 2, EL34 x 4
Input Sensitivity : 340mV
Power Output : 2 x 28W (RMS THD<1% 1KHz 8 Ohm)
S/N Ratio : 90db
Input Impedance : 100K Ohm
Output Impedance : 11 Ohm, 15 Ohm
AC Input : 240V
Power Consumption : 150W
Frequency Response : 18Hz-40KHz - 1db, 5Hz-45KHz - 3db
Insulation Intensity : 250M Ohm (DC2000V, 1min)
Dimension : 340*230*190 (W-D-H)
Weight : 13.6kg
Condition : 9/10 with original box. User is upgrading to a set of 3 units pre and power 845 mono blocks. Unit used for 16 months.
Price : RM3,100 with 8 months warranty SOLD
Lee
012-4937380
wflee- Dealer\Reseller\Trader\Service Provider
- Number of posts : 425
Registration date : 2009-03-12
» Raphaelite DP34 II Integrated Tube Amplifier For LS3/5A (New)
» Raphaelite DP34 Push-Pull Valve Integrated Amplifier
» Raphaelite CP65 integrated push-pull vacuum tube amplifier (SOLD)
» 300B Tube Integrated SET Amplifier (sold)
» Raphaelite DSK6L Integrated Tube Amp (Used) SOLD
