10 Meters HQ Oxygen Free Transparent Speaker Cables. (Total 762 Strands)
10 Meters HQ Oxygen Free Transparent Speaker Cables. (Total 762 Strands) Empty 10 Meters HQ Oxygen Free Transparent Speaker Cables. (Total 762 Strands)
Post by vunjick1 Wed Mar 10, 2010 1:39 pm
10 Meters HQ Oxygen Free Transparent Speaker Cables. (Total 762 Strands) Speaker-cable-selection1
10 Meters HQ Oxygen Free Transparent Speaker Cables. (Total 762 Strands) 3
10 Meters HQ Oxygen Free Transparent Speaker Cables. (Total 762 Strands) 2
10 Meters HQ Oxygen Free Transparent Speaker Cables. (Total 762 Strands) 1
High Quality 762 Strands Oxygen Free Transparent Speaker Cable
This high quality speaker cable is suitable for all HiFi applications including home cinema wiring and wiring in car audio applications. Also suitable for connecting bi wired speakers, just use two lengths.
Let’s have a look at the specification of this cable:
Cable size - 2 x 6.0mm squared
Conductor - 762 x 0.1mm
Conductor type - oxygen free copper
Cable overall dimensions - 7.0mm x 13.0mm
Polarization - one core has a blue stripe
This speaker cable is transparent in line with modern styles of speaker cable and it is extremely tough and durable. The cable is polarized by the blue stripe on one of the cores. The polarized core would normally be used for the positive speaker connection but it can be used for the negative connection as long as you are consistent with this in the connections to all the speakers in your system..
The cross sectional conductor area of this cable is 6.0mm squared per core. It is extremely high quality cable and is tough as old boots. You will need a sharp knife or scissors to strip the insulation and separate the cores.
Use of this type of cable in your HiFi system will improve sound clarity due to the large amount of copper used in the cores. More copper means less resistance and therefore less of a loss in the cable. More of the sound energy reaches your loudspeakers leading to an enhanced clarity of sound. With 762 cores at 0.1mm diameter this cable has an impressive amount of copper and will guarantee the optimum sound quality from your loudspeakers. Why pay high street prices for this high end speaker cable when you can get a bargain here!
This cable is the same gauge as the cable used to connect an electric cooker to the mains! It is so thick and strong it could even be used as an emergency tow rope!
SGD 100+ (Shipping Included)
Can deal anytime after 7pm at Jalan Membina, Tiong Bahru area, thanks!
HP: +6597256667 email: vunjick1@gmail.com
Note: Unreasonable offer will not be attended.
vunjick1
Number of posts : 2
Registration date : 2009-04-15
