Yamaha R-N803 Stereo Network Receiver
Yamaha R-N803 Stereo Network Receiver Brand New, Now Selling at RM2,699. Free Shipping Within West Malaysia.
The elegant design of the R-N803 is equally matched with powerful brainy internals – a full suite of modern technological and connectivity features make the receiver even more captivating and result in a receiver worthy to take home to your Wi-Fi® and Hi-Fi.
* To be supported in future firmware updates.
Chris 012-2309169
amplifier
speaker
cd player
SPECIFICATIONS
Amplifier
RMS Power Output Minimum RMS: 100 W x 2 @ 8 Ohms, 20 Hz to 20 kHz, 0.019% THD
Maximum Output Power 145 W x 2 @ 8 Ohms, 1 kHz, 10% THD
Dynamic Power per Channel At 8/6/4/2 Ohms: 140/170/220/290 W per channel
Tuner
Tuner Type AM/FM
Connectivity
Wireless Connectivity Wi-Fi with Wireless Direct
DLNA version 1.5 (DMR)
Apple AirPlay
Bluetooth version 2.1 + EDR, A2DP, AVRCP, SBC/AAC (receiving only)
Supported File Formats MP3, WMA, MPEG4 AAC 48 kHz / 320 kbps, WAV, FLAC, AIFF 192 kHz / 24-bit, ALAC 96 kHz / 24-bit, DSD 2.8 / 5.6 MHz
Inputs 2 x optical TOSLINK
2 x digital coaxial
1 x stereo RCA phono with ground screw
4 x stereo RCA
1 x USB (front)
Outputs 2 x stereo RCA
1 x 1/4" (6.35 mm) headphone (front)
Other Connectors 1 x Ethernet LAN
1 x FM antenna
1 x AM antenna
1 x mono RCA subwoofer out
1 x trigger out
Speaker Connectors 2 (L/R)
General
Standby Power Consumption 0.1 W
Wired/Wi-Fi/Bluetooth, Network Standby On: 1.8 W
Wireless Direct, Network Standby On: 1.9 W
Dimensions (W x H x D) Without Antenna: 17.125 x 6 x 15.44" (43.5 x 15.24 x 39.21 cm)
With Antenna Up: 17.125 x 8.5 x 15.44" (43.5 x 21.59 x 39.21 cm)
Weight 24.3 lb (11.02 kg)
Packaging Info
Package Weight 26.0 lb
Box Dimensions (LxWxH) 21.0 x 18.0 x 8.5"
Experience the Legend, Enjoy the Musicality
The legendary Yamaha Hi-Fi design concept ToP-ART (Total Purity Audio Reproduction Technology) combines a meticulously symmetrical left/right circuit layout and signal directness (straightest, shortest signal paths) with a low-vibration chassis of high rigidity. The chassis is equipped with the special resin frame "Art Base" that absorbs and blocks unnecessary vibration. The result is sonic purity and an accurate stereo image of your music.High Precision, High Performance
The R-N803 uses the renowned SABRE 9006AS 192 kHz/24-bit DAC (from ESS technology) to deliver superior signal-to-noise ratio performance. Combined with the Yamaha original network module, the unit thoroughly draws out all the sonic merits of high-resolution sound sources, effectively reproducing even the subtle ambience of concert halls and delicate expressive nuances in the sound.Optimized for the Ultimate
For the first time in a Hi-Fi receiver, the R-N803 is equipped with the Yamaha Parametric room Acoustic Optimizer (YPAO™), a famed technology used in Yamaha AV receivers. It measures the shape of the room, the material of the wall and the position of the speaker, then automatically adjusts the sound to create the ideal response and sonic quality. The unit also features other advanced YPAO functions, including YPAO - Reflected Sound Control, which actively corrects the important early reflection sounds that greatly influence sound quality, and YPAO Volume, which applies exceptionally high-precision EQ (equalization), with 192 kHz / 64-bit operation. The result? You can create an ideal listening environment right in your home, just like that of a professional audio listening room. Moreover, you can control the YPAO feature and display the analysis results by using the MusicCast app.** To be supported in future firmware updates.
Sound Purity
Pure Direct mode enables the music signals to travel the shortest possible circuit route, bypassing the buffer amp and the tone, loudness and balance controls to virtually eliminate any signal degradation, for the purest sound quality.Pure Delight to Own
This receiver inherits the simple and sophisticated design style for which Yamaha Hi-Fi audio is famous. Its elegant simplicity beautifully complements your other Hi-Fi audio components. The stylish design with high-quality materials deepens both the joy of ownership and the joy of listening.Sophisticated Circuit Design
The power amp block adopts a symmetrical and direct circuit layout based on the ToP-ART concept, featuring a parallel push-pull structure using a total of eight bipolar-type power transistors (four each, on left and right) as its output terminals. And by minimizing the lengths of the audio signal paths in the circuit design, we've lowered impedance to achieve superb drive power with a maximum output of 145 watts (per channel).Please visit [You must be registered and logged in to see this link.] to find out more products for sale at very special price..
Chris 012-2309169
amplifier
speaker
cd player
SPECIFICATIONS
Amplifier
Tuner
Tuner Type AM/FM
Connectivity
Apple AirPlay
2 x digital coaxial
4 x stereo RCA
1 x USB (front)
1 x FM antenna
1 x AM antenna
1 x trigger out
General
Packaging Info
- Number of posts : 1336
» Yamaha RX-V4A 5.2Ch.8K Network AV Receiver
» Yamaha R-N803 Hifi Stereo Amplifier/Network Receiver (Brand New Condition)
» Yamaha R-N602 Network Receiver
» YAMAHA RX-V581 7.2ch network av receiver
» Yamaha RX-V483 5.1CH NETWORK AV RECEIVER
