Onkyo CP-1050 Direct-Drive Turntable
Onkyo CP-1050 Direct-Drive Turntable Brand New. Now Selling At RM2,829. Free Shipping Within West Malaysia.
There’s never been a better time to rekindle your passion for collecting and listening to records. With the introduction of the CP-1050, Onkyo offers a turnkey solution for audiophile-level analog sound with less hassle and expense. It features a smooth and stable direct drive (there’s no belts to replace and less high-frequency noise) controlled by a quartz-lock system to ensure the aluminum platter rotates with utmost precision. The aluminum tonearm ships with a quality MM cartridge, and thanks to an innovative counterweight system and detachable headshell, can also accept most popular aftermarket cartridges. Together with solid MDF deck construction, these elements combine to deliver exceedingly beautiful sound that’s both clear and detailed while celebrating the lushness, depth, and warmth so beloved of the analog format. As you would expect from a company that created its first crystal turntable pickup for the CP-1000 back in 1946, every aspect of the design has been painstakingly engineered to deliver audio performance well beyond its suggested price.
Onkyo CP-1050直驅黑膠唱盤,以易如反掌及超值的方案,帶來全方位的發燒級類比音色。其平滑和穩定的直驅系統 (沒有皮帶更換及高頻噪聲的問題),配以Quartz Lock高精準度石英旋轉控制系統,確保鋁合金轉盤以最高精準度轉動。CP-1050唱臂裝上優質動磁MM唱頭,並採用創新的唱頭重量調校系統和可拆式唱頭殼,當然你亦可以換上喜歡的唱頭。一切一切都建構在厚實的中密度纖維板機殼上,集合以上元素構成了明確、細膩、豐富的絕美音色。正如回到 1946 年,沒人會幻想到水晶轉盤會出現在CP-1000一樣,新唱盤每方面都經過精心設計,表現亦遠超於其售價。
ADVANCED FEATURES
CONNECTION FEATURES
創新的直驅設計令重播表現更清晰準確
震動、摩打及機械結構所產生的噪聲是音質的最大敵人。所以 Onkyo 特別採用低扭力摩打,取代直驅唱盤一直慣常用的高扭力摩打,以減低轉動時齒輪所產生的噪音,從而重現被模糊了的低率聲音。與使用高速摩打的帶動式唱盤比,直驅設計的CP-1050更可以避免高頻失真的問題。結合 Quartz-Lock 高精準度石英旋轉控制系統和優質軸承,令整體有如液體流動一樣平滑,流暢地把音樂靈魂再次展現眼前。
Effective Anti-Vibration Design
The turntable base is constructed from solid MDF (Medium-Density Fiberboard) and sits on four height-adjustable anti-vibration feet. Together with the smooth direct-drive motor, the rigid structure tames resonances so you can enjoy clean playback throughout the entire frequency spectrum.
有效的抗震設計
轉盤底座是以厚實的MDF(中密度纖維板)建構而成,以及底部四個可調高度防震腳。集合暢順直驅摩打,與剛性結構來克服諧振,令你全情投入享受純淨的音樂重播。
優質唱臂及唱頭
鋁合金唱臂具有可調整重量系統,而可拆式唱頭殼可兼容市面5-10克重量唱頭。唱盤亦附設足以應付不同唱片播放的動磁(MM)唱頭,加上寬廣的頻率響應、超過60dB訊噪比等規格,都在這華麗的機身上找到。集合所有設計元素,展現出開揚和細緻的類比聲色。
Good Looks, Great Build
Aesthetically, the CP-1050 is a pleasing blend of ’70s retro cool and clean, contemporary style; it’s dark woodgrain finish nicely contrasts the gleaming alloy tonearm and polished metal trim on the top of the deck. The player also includes a detachable acrylic dust cover, and makes the perfect centerpiece for stereo systems of any vintage.
美觀的外型
從美學觀點出發,CP-1050 由70年代復古的型格及簡潔的現代風格融合而成;黑色木紋正好與閃亮的鋁合金唱臂,與拋光金屬面板形成極大對比。唱盤還附設一個可拆卸的亞加力防塵罩,完全配合整個充滿懷舊味道的設計。
頂級的連接
機背上有兩個鍍金的 RCA音頻輸出端子,訊號可藉此連接到 Phono 擴音機,或者前級、立體聲或影音擴音機。機上附設專用的接地,用以消除沒接地而出現的電流聲等影響。
SPECIFICATIONS
Turntable Section
Drive Method Direct-Drive
Turntable Type 305 mm Die-cast Aluminum
Turning Speed 33 1/3 / 45 rpm
Motor Type Brushless DC
Starting Torque >1.0 kgf-cm
Brake Electronic Brake
Wow and Flutter 0.15% or Less at 33 1/3 rpm
Signal-to-Noise Ratio >60 dB
Tonearm Section
Type Static-balanced, S-shaped
Headshell Detachable
Headshell Weight 10 g
Effective Arm Length 230 mm
Overhang 15 mm
Applicable Cartridge Weight Range (Including Headshell)
15–20 g
Tracking Error Angle Within 3º
Anti-Skating Range 0–3 g
Stylus Pressure Adjustment Range
0–4 g
Cartridge Section
Cartridge Type Moving-Magnet (MM)
Output Voltage 2.5 mV/±3 dB (1 kHz at 3.54 cm/Sec.)
Channel Balance < 2.5 dB
Load Resistance 47 kΩ
Cartridge Weight 5 g
Replacement Stylus DN-105ST
Frequency Response 0±3 dB
(10 kHz, Based on Value at 1 kHz)
Channel Separation >18 dB (at 1 kHz)
General
Power Supply AC 220–240 V~, 50/60 Hz
Power Consumption 6 W
Standby Power Consumption
0.4 W
Dimensions (W x H x D) 450 x 158 x 367.5 mm
Weight 8.6 kg
CARTON
Dimensions (W x H x D) 542 x 243 x 465 mm
Weight 11.2 kg
Supplied Accessories
• Instruction manual • RCA audio cable • Dust cover
• Adapter for 17 cm 45 rpm records • AC cord
BRANDED led tv
amplifier
speaker
cd player
CP-1050
Direct Drive Turntable
Rediscover the Magic of VinylThere’s never been a better time to rekindle your passion for collecting and listening to records. With the introduction of the CP-1050, Onkyo offers a turnkey solution for audiophile-level analog sound with less hassle and expense. It features a smooth and stable direct drive (there’s no belts to replace and less high-frequency noise) controlled by a quartz-lock system to ensure the aluminum platter rotates with utmost precision. The aluminum tonearm ships with a quality MM cartridge, and thanks to an innovative counterweight system and detachable headshell, can also accept most popular aftermarket cartridges. Together with solid MDF deck construction, these elements combine to deliver exceedingly beautiful sound that’s both clear and detailed while celebrating the lushness, depth, and warmth so beloved of the analog format. As you would expect from a company that created its first crystal turntable pickup for the CP-1000 back in 1946, every aspect of the design has been painstakingly engineered to deliver audio performance well beyond its suggested price.
ADVANCED FEATURES
- Built to Deliver Affordable Audiophile-Grade Sound
- Stable Direct-Drive System for Minimal Low-Frequency Cogging Noise
- Customized Brushless DC Motor
- Quartz-Lock Control System for High-Precision Rotation
- Solid Anti-Vibration MDF Cabinet Construction with Black or Yellow Woodgrain Finish
- Die-cast 305 mm Aluminum Platter for Effortlessly Smooth and Stable Rotation
- Wow and Flutter Less than 0.15%
- Signal-to-Noise Ratio Over 60 dB
- Aluminum Static-Balance S-shaped Tonearm
- Moving-Magnet (MM) Cartridge Included
- Detachable Headshell Compatible with Aftermarket Cartridges
- Tonearm Counterweight Supports Range of Cartridge Weights
- Gold-Plated RCA Phono Output Terminals with Dedicated Grounding Post (Cable Included)
- Easy Button-Selectable 33 1/3 and 45 rpm Speeds
- Quickly Spins to Playback Speed Stability
- Includes Detachable Acrylic Dust Cover
- Resonance-Damping Rubber Slipmat Included
- Large Height-Adjustable Anti-Vibration Feet
CONNECTION FEATURES
- RCA Phono Outputs
- Grounding Post
- AC Inlet
Innovative Direct Drive Plays Records Clean and Clear
The enemies of turntable sound quality are vibration and electro-mechanical noise picked up by the stylus. Instead of a high-torque motor, Onkyo deploys a stable low-torque design that significantly reduces cogging noise, which can noticeably obscure low-frequency sound. And unlike belt-driven turntables that use fast electric motors, the direct-drive CP-1050 avoids the problem of high-frequency distortion. Combined with a precision quartz-lock control system and quality bearings, this liquid-smooth drive provides a clearer window on the soul of your music.創新的直驅設計令重播表現更清晰準確
有效的抗震設計
Quality Tonearm and Cartridge
At the business end of the aluminum tonearm is a detachable headshell that (together with an adjustable counterweight system) supports a range of aftermarket cartridges between 5 g and 10 g. The supplied MM cartridge does a brilliant job of capturing the depth and breadth of any track with an exceptionally wide frequency response and signal-to-noise ratio of over 60 dB—right up there with more costly decks. All design elements combine to produce such open and detailed analog sound you’ll be finding any excuse to go digging in the crates.優質唱臂及唱頭
美觀的外型
Top-Shelf Connections
On the rear panel are two gold-plated pin-type RCA phono terminals to output the left and right channel signals to your external phono preamp, stereo amplifier, or A/V receiver. There’s also a dedicated grounding post to eliminate hum.頂級的連接
SPECIFICATIONS
Turntable Section
Tonearm Section
Overhang 15 mm
15–20 g
0–4 g
Cartridge Section
General
0.4 W
Weight 8.6 kg
CARTON
Weight 11.2 kg
BRANDED led tv
amplifier
speaker
cd player
- Number of posts : 1323
» Sony Direct Drive Turntable
» Pioneer PL-70L Ⅱ direct drive turntable (used)
» DENON QUARTZ Direct Drive Turntable DP-55k
» Sony PS-212A Direct-Drive Turntable (SOLD)
» Sony Direct Drive Turntable PS T-15(used)Sold
