Weiduka AC8.8 Power Filter & Conditioner 2018 Model for Sale or Swap
I have 3 sets of the below, brand new in box, for sale or swap/topup:
Item: Weiduka AC8.8 Power Filter & Conditioner 2018 Model
Price: RM330 or swap/topup
[size=33]Weiduka AC 8.8 Filter and Conditioner Power Strip Latest 2017 Model[/size]
Please take note! This is the latest 2017 model that shows two readings in the nicer coloured LCD display, not the older model that only showed the total connected voltage reading on a monotone blue LCD.
Electric AC power from our wall sockets can be littered with noise and interferences, as it goes through various stages of conversion and transforming before reaching us, travelling through long distance across the power lines. There is no problem for all these when they are powering normal appliances. However, if the output of these appliances are in the same forms of waves and currents as the electricity like our audio equipment do, there will be undesirable effects on the sounds. These noises and interferences will either mask away some frequencies of the sounds, by cancelling each other out at specific frequencies, or adding unwanted hums/noises by layering frequencies on top of some. This is what that is preventing music from being ‘transparent’, seemingly sounds as though the quiet part of the what the music should sound is still not silenced.
This AC filter and conditioner power strip from Weiduka/MagincSound acts as the all important filter and cleaner of the electric current from our wall socket. It filters the irregularities and noise off the current, attenuates the RFI down for a cleaner power to the end of the receiving equipment. It also delivers consistent voltages and currents through the regulators within, so the receiving equipment is always evenly-powered.
With a total of 10 plug inputs, it is separated into 2 rows of 5 plugs each. Each row, controlled by individual switch on the side for the entire row, consists of 2x US plug inputs and 3x multi plug inputs,
LCD panel is clean and bright, a clear reading of the current total voltage going through the power strip, and the total current drawn from the unit. Do note though that the LCD panel display is only showing Row 1 usages. It does not show Row 2 usages.
It comes with a maximum load of 3000W, and a surge protection of 15A. Together with high purity of copper content in the contacts of each plug used throughout the unit, you can be sure your audio equipment connected through this AC filter and conditioner power strip are not only well-protected from sudden surges, they will also perform with the cleanest and best-regulated power possible. Your music will improve with a quieter background and separation.
- Popular AC filter and conditioner power strip
- Performance and quality of the built especially are astonishingly high
- Filters the irregularities and noise off the current from wall sockets
- Delivers cleaner and consistent power
- Clean and bright LCD panel provides a clear dual reading
- Total of 10 plug inputs, separated into 2 rows of 5 plugs each
- Controlled by 2 switches for each of the entire row
- Maximum load of 3000W, and a surge protection of 15A
- High purity of copper content in the contacts of each plug
DESCRIPTION
This has been a popular AC filter and conditioner power strip for audiophiles everywhere, not just because the price is economical, but the performance and quality of the built especially are astonishingly high!Please take note! This is the latest 2017 model that shows two readings in the nicer coloured LCD display, not the older model that only showed the total connected voltage reading on a monotone blue LCD.
Re: Weiduka AC8.8 Power Filter & Conditioner 2018 Model for Sale or Swap
Last unit for sale at RM330 only. Brand new in unopened box.
» Weiduka AC2.2 Line Power Filter/Conditioner Socket (SOLD)
» Weiduka ac 8.8 (2018 latest model)new
» weiduka Ac 8.8 power filter
» Weiduka AC 8.8 Filter/Conditioner (Sold)
» Weiduka AC8.8 3000W AC Filter Latest Model - SOLD
