Boston Acoustic CR-6 USA made Bookshelf Speaker
Made In USA
Boston Acoustics CR6 2 Way 2 Driver Max 100 Watt Bookshelf Speakers
Boston Pair of CR6 Bookshelf Speakers
Type: 2 way, 2 driver loudspeaker system
Frequency Response: 65Hz to 20kHz
Recommended Amplifier: 15 to 100W
Crossover Frequency: 3500Hz
Sensitivity: 88dB
Bass: 1 x 135mm
Tweeter: 1 x 19mm dome UPC 690283049072
Key Features
Speaker Type Main / Stereo Speakers Construction 2-Way
Technical Details
Peak Power Handling 100 W
Impedance 8 ohm
Sensitivity 88 dB
Connectivity Wired
Dimension : Width 5.87 in.
Depth 7.87 in.
Weight 7.5 lb
Small Speaker/Big Sound
Long-discontinued, the Boston CR-6 speaker more than holds it own when compared to similar speakers being produced today. It is solid and well-built, with nice features like 5-way binding posts and a mounting bracket for wall installations. The fit and finish, while utilitarian, is a notch above what you would expect.
The CR-6 is a very neutral speaker - there is no emphasis on any portion of the sound spectrum. The bass is surprising for a speaker this small, the mids are very natural and well-balanced and the treble has just the right bite to it. This is a speaker that will not hit you with the dreaded condition called listening fatigue.
Good-looking, versatile, and great sounding.....the CR-6 has a lot going for it.
Price : RM 630
contact Simon Ting 012-3612507
- Number of posts : 2967
» Boston Acoustic CR7 bookshelf (6" woofer)
» Boston Acoustic i-DS 2 ipod Speaker (New)
» Boston Acoustic XS satellite speaker 1pc 2pc or 3pc
» Boston acoustic xs satellite speaker : 1 unit
» Boston Acoustic HS450 floorstand speaker (Used)Sold
