NAIM Audio system (Display Set) CDX2, HiLine, Siltech
3 posters
Naim CDX-2 CD Player
The latest incarnation, CDX2 has incorporated some useful new enhancements, including a switchable digital output and extra low-noise clock regulation.
It is different from the motorised assemblies used by other players, but undoubtedly better, with superior isolation and resistance to resonance.
- Suspended transport with low-mass magnetic clamping mechanism to resist resonance
- Anti-vibration resonance-controlled feet plus cast and extruded anti-magnetic chassis to further counter vibration
- Fully double-regulated power supply with 20 low-noise, regulated voltages on the main circuit board, plus separate supplies on the servo control and display boards
- User-selectable DIN and RCA analogue outputs, plus digital output (only functions when analogue outputs are disabled)
Display set, like new condition, view to believe.
Comes with cable, remote, user manual (No Box)
S/N: 249xxx
RM13500
Naim Hi Line Interconnect DIN Cable
5 pin DIN to 5 pin DIN
The Hi-Line Air-PLUG (patented) is designed as a decoupling device to prevent vibrations from one product being transmitted, through the cable, to another product and to stop airborne vibrations picked up by the cable being transmitted to the products to which it is connected.
The cable section of the Hi-Line also benefited from a complete re-think. It had to be low capacitance, low resistance and flexible. It had to work superbly in DIN to DIN connections but it also had to perform when used in other configurations.
The cable, exclusive to Naim, is manufactured from twisted pairs of 80 Litz conductors surrounded by PTFE, Kapton and PTFE tape all then enclosed within a semi conductive shield to reduce static charges. This is then wrapped by two spiral wound copper shields and lapped PTFE tape. Two of these assemblies side by side are then wrapped in layers of PTFE tape and finally a rubber outer covering.
This gives a two-channel cable where the signal and RF grounds are held in a static position relative to each other negating any difference in field between them
Clean, good, 100% perfect working condition
No box
RM3300
viii) Siltech Classic Anniversary Model, 220i 5-Pin DIN Interconnect for Naim
Classic Anniversary Series brings you ultra-low distortion, lack of coloration, untouched transients, rich details and a fantastic soundstage.
The Classic Anniversary Series are developed to commemorate 25 years of Siltech and its persistent efforts for perfection.
It performs even better in terms of magnetic insulation and electrical shielding. Cutting-edge research in magnetic behaviour has led to truly silent cables. Siltech uses precision micro-engineering to achieve the quietest cables ever made. Electromagnetic inductance and radio frequency interference pose an ever-increasing problem in today’s technology driven world full of transformers, cell phones, computers and other electronics.
This new Classic Anniversary Series cables to be up to 10,000 times quieter than the most expensive, best-tested contenders.
Uses the unique G7 silver-gold conductors. This seventh generation silver-gold material reduces low-level distortion even further.
1M length
Less than a year, comes with box.
RM1000
Welcome for audition @ Subang Jaya ss14
*Credit cards accepted.
Contact 01 26116917
Re: NAIM Audio system (Display Set) CDX2, HiLine, Siltech
ii) HiCap left last unit,
vi) Power Line left last unit,
ix) CD5i sold
ix) CD5i sold
is the cdx2 still available?
salahu- New Member
- Number of posts : 4
Registration date : 2014-06-15
Why your CDX 2 looks different then the first picture?
Ao-Ao Yeh- Frequent Contributor
- Number of posts : 174
Registration date : 2012-11-09
Source(s): Marantz
Amplification: Cyrus 2
Speakers: Mission 753
Thanks wah...lauyeh.
Guess it's the earlier batch/version.
Refer to real item picture as reference ya.
» Naim Hiline 5 Pin Din to 2 RCA (sold)
» Naim CdX2 CD player,Naim XPS power supply (used)
» Naim Audio CD5X CD Player (Display)
» Naim cdx2.2 and dac
» Wilson Audio WATT Puppy System 8 speakers (Display)
