Q Acoustics 3010i 5.1 H/ Theatre System
Q Acoustics 3010i 5.1 H/Theater System Brand New. Now Selling At RM5,799. Free Shipping Within West Malaysia.
Key Features
Each speaker that forms part of the Q 3010 5.1 Cinema Pack is a genuine hi fi speaker incorporating a wealth of technology applied to the entire 3000i Series – resulting in an exceptional cinematic performance for small to medium sized listening rooms. The Q 3010 5.1 Cinema Pack also delivers stunning musical performances.
Across the entire 3000i Series, conventional terminal panel cut-outs have been removed, giving greatly improved structural integrity to the enclosures and new low profile binding posts have been incorporated with sockets deep enough to accept 4mm (0.16 in) Banana Plugs. The speaker can be positioned very close to a rear wall even when banana plugs rather than spades or bare wires are used which means the Q 3010i home cinema system can be a seamless addition to your listening room.
The Q 3010i speakers can be shelf-mounted on compliant, pre-fitted rubber feet, stand-mounted or wall-mounted on optional, dedicated stands and brackets giving you ultimate flexibility in your home cinema setup.
The Q 3090Ci is the same width as most Amplifiers and AV Receivers so will fit attractively into the specialist furniture designed to house them and can also be shelf or cabinet mounted, or on dedicated wall brackets.
The Q 3060S is our most slimline subwoofer with all the power needed to deliver every nuance of an acoustic double bass or rumble of a cinematic explosion. The Q 3060i Subwoofer can be floor mounted using spikes provided or wall mounted with a dedicated wall bracket.
Not only does the entire 3000i range features all new enclosure aesthetics but it also offers 4 new contemporary finishes. The new 3000i series speakers are available in four standard finishes; Graphite Grey, English Walnut, Carbon Black or Arctic White. All are finished with an attractive chrome bezel around each driver and feature magnetic speaker grilles.
hich can be wall mounted with optional, dedicated brackets
Specification
Specifications 3010i:
Enclosure type: 2-way reflex
Woofer unit: 100 mm ø
Tweeter unit: 22 mm ø
Frequency response (+3 dB, -6 dB): 65 Hz – 30 kHz
Average Impedance: 6 Ohm
Minimum Impedance: 4 Ohm
Sensivity (2.83 V@1 m): 86 dB
Stereo amplifier: 15 - 75 W
AV Receiver power (2 ch. driven): 50 - 125 W
Crossover Frequency: 2,6 kHz
Effective volume: 4,0 l (244 cu in)
Dimensions W/H/D: 150 x 253 x 252 mm (5.9 x 10.0 x 9.9 in)
Weight (per speaker): 4.1 kg (9.0 lbs)
Specifications 3090i:
Bass Unit: 2 x 100 mm (4 in)
Treble Unit: 22 mm (0.9 in)
Frequency Response (+3 dB, -6 dB): 75 Hz – 30 kHz
Sensitivity (2.83 V@1 m): 89 dB
Stereo Amplifier: 25 - 100 W
AV Receiver (2 ch. driven): 50 - 165 W
Internal Amplifier Power: -
Crossover Frequency: 2.7 kHz
Effective Volume: 6.6 L (403 cu in)
Dimensions H/D/W mm: 430 x 152 x 216 mm (16.9 x 6.0 x 8.5 in)
Weight (per speaker): 6 kg (13.2 lbs)
Specifications 3060S:
Enclosure type: infinite baffle
Bass Unit: 200 mm (8 in)
Treble Unit: -
Frequency Response (+3 dB, -6 dB): 35 – 250 Hz
Average Impedance: -
Minimum Impedance: -
Sensitivity (2.83 V@1 m): -
Stereo Amplifier: -
AV Receiver (2 ch. driven): -
Internal Amplifier Power: 150 W Class D
Crossover Frequency: 35 – 250 Hz (var)
Effective Volume: 10.6 L (647 cu in)
Dimensions H/D/W mm: 480 x 300 x 150 mm (18.9 x 11.8 x 5.9 in)
Weight (per speaker): 8.5 kg (18.7 lbs)
Q Acoustics 3010i Cinema Pack
The Q 3010i 5.1 Cinema Pack combines the very best of the 3000i Series to deliver a stunning, compact home cinema system ensuring you hear every detail at its very best from your favourite movies and music.Key Features
- Comprising of 2 pairs Q 3010i + Q 3060 Subwoofer + Q 3090i Centre and providing a massive cinema sound from compact cabinets all of which can be wall mounted with optional, dedicated brackets
- The slimline Q 3010i speakers provide a large sound and deep bass thanks to increased cabinet volume from previous models
- The Q 3090Ci centre channel delivers crisp and clear dialogue and will bring onscreen sound to life
- The Q 3060S delivers every nuance of an acoustic double bass or rumble of a cinematic explosion utilising a powerful 150watt amplifier partnered with a high performance 200mm driver
NATURAL DIALOGUE TO EXPLOSIVE SOUND
The Q 3010i Series 5.1 Cinema Pack will unleash the full potential of your home cinema electronics. Its exquisitely detailed sound will convey all the atmosphere, natural dialogue and, when required, the full bodied explosive drama of every video soundtrack. The 3010i 5.1 cinema package is derived from its award-winning predecessors and boasts an extended cabinet size delivering a larger sound, P2P™ (Point to Point) bracing for additional cabinet stability for a purer, more dynamic home cinema sound.PERFECT FOR MUSIC & MOVIES
Each speaker that forms part of the Q 3010 5.1 Cinema Pack is a genuine hi fi speaker incorporating a wealth of technology applied to the entire 3000i Series – resulting in an exceptional cinematic performance for small to medium sized listening rooms. The Q 3010 5.1 Cinema Pack also delivers stunning musical performances.EASY ROOM POSITIONING
Across the entire 3000i Series, conventional terminal panel cut-outs have been removed, giving greatly improved structural integrity to the enclosures and new low profile binding posts have been incorporated with sockets deep enough to accept 4mm (0.16 in) Banana Plugs. The speaker can be positioned very close to a rear wall even when banana plugs rather than spades or bare wires are used which means the Q 3010i home cinema system can be a seamless addition to your listening room.The Q 3010i speakers can be shelf-mounted on compliant, pre-fitted rubber feet, stand-mounted or wall-mounted on optional, dedicated stands and brackets giving you ultimate flexibility in your home cinema setup.
BEAUTIFUL INSIDE AND OUT
Not only does the entire 3000i range features all new enclosure aesthetics but it also offers 4 new contemporary finishes. The new 3000i series speakers are available in four standard finishes; Graphite Grey, English Walnut, Carbon Black or Arctic White. All are finished with an attractive chrome bezel around each driver and feature magnetic speaker grilles.hich can be wall mounted with optional, dedicated brackets
Specification
Treble Unit: -
Stereo Amplifier: -
- Number of posts : 1342
» Q Acoustics Q 3010i Bookshelf Speaker
» Home Theatre System
» Kawamichi DTS Home Theatre System
» Onkyo TX-SR252 5.1Ch Home Theatre System
» Antique Theatre System. (You Can't Find Anywhere Else But Here.)
