Cambridge Audio 651A Stereo integrated amplifier with USB input
Item: Cambridge Audio 651A Stereo integrated amplifier with USB input
Condition: 8/10. Item in good working condition. No remote control.
Vocal sounds smooth and expressive. Bass is deep and powerful.
Price: RM1380 or swap/topup
Featuring a USB connection, the Cambridge Audio Azur 651A bridges the gap between your computer and hi-fi better than ever before
Now with USB
Although not uncommon for CD players to feature a USB input, they're a rarity on amplifiers. Yet, once you've sampled the device on the Azur 651A, you'll wonder why. Connect your PC, Mac or laptop via USB and you're able to access all your stored music and streaming music services. By using USB, you bypass the computer's soundcard for the purest audio output possible. It means your computer can now become a fully integrated part of your hi-fi system without the usual loss in audio quality.
Separate subwoofer output
Also included for the first time is a separate subwoofer output - perfect for using with a compact 2.1 speaker system. As before, the 651A comes with a comprehensive range of other sockets including A/B speakers, twin recording loops, a front-mounted 3.5mm portable input and headphone socket, a pre-output and three further line level inputs. In short, the 651A has the whole lot covered.
Quality internal components
As you'd expect from this leading hi-fi brand, the Cambridge Audio Azur 651A is full of high-spec components. The volume control is the world-renowned ALPS Black Box pot, for superb accuracy and improved channel separation. Low dissipation polypropylene and custom-made electrolytic capacitors ensure low distortion and crystalline levels of detail. Separate transformer taps for left and right channels, twin rectifiers and separate PSUs give exceptional channel separation and, hence, separation of the sound - you'll hear every instrument, as it should sound and in its correct place.
Power to spare
With a hefty 75W per channel, the Azur 651A is one of the most powerful amplifiers in its class, thanks to its oversized toroidal transformer. Despite the power, the Azur 651A is also a model of control. The high capacity heatsink easily dissipates the spent energy, while Cambridge's CAP5 protection system keeps your speakers and the amp protected, without unduly affecting the sound quality.
Class-leading Azur quality
Take in the acoustically damped chassis with curved edges, thick aluminium front panel and sculptural Navigator remote and you could easily mistake the 651A for an amplifier of twice the price. Indeed, even at this level we can think of several designs that would be shamed for finish quality by the Cambridge Audio! Of course, the styling also blends perfectly with the full range of other Azur hi-fi separates.
If you're looking for a powerful yet sweet, fully featured yet sleek, mid-range amplifier, then we can think of little better than Azur 651A. It's truly hard to fault!
Site:
https://www.richersounds.com/cambridge-azur-651a-sil.html
https://www.whathifi.com/cambridge-audio/azur-651a/review
https://www.crutchfield.com/S-KZNO8ON5X5l/p_779651AB/Cambridge-Audio-651A-Black.html
SEE ALL MY ITEMS HERE:
https://www.hifi4sale.net/st/raymond88
Thanks for viewing
Now with USB
Power to spare
Product highlights:
- 75 watts x 2 channels into 8 ohms (20-20,000 Hz), 0.03% THD at 80% of rated power
- signal-to-noise ratio: >92 dB
- toroidal power transformer for low noise and high-current output
- separate transformer taps for left and right channels, twin rectifiers and separate PSUs for dual mono operation of the left and right power amps
- 5 RCA line-level analog audio inputs accommodate CD players, tuners, other components
- front-panel minijack input for connecting a portable music player
- 2 stereo RCA record outputs
- 1 stereo RCA preamp output and a dedicated mono subwoofer output
- connect a turntable with a phono preamp
- USB input accepts 16-bit, 32/44.1/48kHz signals, no drivers needed for Mac or Windows computers
- infrared control input and control bus input/output for integration into multi-room systems
- full-size headphone jack
- remote control
- 16 15/16"W x 4-5/8"H x 14-5/8"D
- weight: 18.5 lbs.
Site:
Thanks for viewing
» (Sold) - Cambridge Audio Azur 651A integrated amplifier
» Sold - Cambridge Audio Azur 651A integrated amplifier
» Cambridge Audio Azur 650A Stereo Integrated Amplifier
» Cambridge Audio P40 MKII England Made Stereo Integrated Amplifier with MM MC Phono
» Cambridge Audio CXA61 Integrated Stereo Amplifier (PL)
