Bada 3.0 SE hybrid integrated amplifer - SOLD
Selling a very good physical and working condition Bada hybrid stereo tube integrated amplifier. Preamp is tube and output is transistor. This is a huge amplifier both physical and weight wise. Built quality is very good with good used of thick aluminium for chassis as well as heat sink. 130 watts per channel at 8 ohms continuos power output in Class AB mode and 80 watts per channel with pure Class A output. It come with a metal remote. There is both rca and xlr input. It is recently service and clean so it will last a long time to come.
Specifications:
Output power; Class A 80W +80 W (8 ohm¸) Class AB 130W +130 W (8ohm¸)
Distortion: less than 0.6%
Frequency Response: 10Hz-35kHz (-1dB)
Signal to noise ratio: 90dB
Gross Weight: 41 kg
https://www.google.com.sg/amp/s/m.aliexpress.com/item/498135504.html
Specifications:
Gross Weight: 41 kg
James46- Frequent Contributor
- Number of posts : 241
Registration date : 2012-12-30
» Luxman L81 Integrated Amplifer (used) Sold
» fs: Jadis Orchestra Integrated Amplifer (used)-sold
» Kenwood Integrated Amplifer Special Edition (Used)
» Naim Audio Supernait 2 Integrated Amplifer (Used) Sold
» Primare I30 Integrated Amplifer (used)
