Marantz SR7013 9.2 Channel 4K Ultra HD AV Receiver
Marantz SR7013 9.2 Channel 4K Ultra HD AV Receiver Brand New. Now Selling At RM7,999. Free Shipping Within West Malaysia.
DTS:X沉浸式音頻格式將聲音置於它在空中的自然發聲位置,在家中創建逼真的多維音頻體驗。 DTS Neural:X:tm:附帶空間重映射引擎,為您所有最喜愛的電影提供改善的沉浸效果和增強的真實感。
DTS Virtual:X提供沒有縱向聲道的沉浸式音頻性能,在5.1、7.1或2.1揚聲器佈置中營造虛擬縱向效果。
To start streaming with Alexa voice commands, open the Alexa app and select “Skills.” Add HEOS Home Entertainment to enable. Then, go to Smart Home in the Alexa app menu and choose Devices and Discover or say “Alexa, discover my devices.”
With HEOS Home Entertainment and Alexa, you can stream to this product and any other HEOS-enabled device.
Learn More
Learn More
Airplay 2 also supports multi-room audio – wirelessly stream content to multiple AirPlay 2 compatible devices simultaneously with improved audio buffering to ensure smooth audio playback. AirPlay 2 provides control and grouping of compatible audio devices within the Apple Music or Home app. Use Airplay 2 in-app or with your voice via Siri.
Learn More
Learn More
馬蘭士2016 AVR Remote應用程序提供對最新一代馬蘭士網絡AV接收機前所未有的控制。控制電源、音量、輸入和設置,或切換至HEOS應用程序以訪問範圍極廣的音樂內容和串流媒體服務。 iOS和Android手機和平板電腦都可以下載。
Marantz SR7013 Specs
Amplifier
Output Power 110 W per channel @ 8 Ohms, 20 Hz to 20 kHz, 0.08% THD, 2 channels driven
125 W per channel @ 8 Ohms, 20 Hz to 20 kHz, 0.05% THD, 2 channels driven
165 W per channel @ 6 Ohms, 1 kHz, 0.7% THD, 2 channels driven
235 W per channel @ 6 Ohms, 1 kHz, 10% THD, 1 channel driven
Channels 9.2
Signal to Noise Ratio Analog: 100 dB (IHF-A weighted, Direct Mode)
Phono: 74 dB (IHF-A)
D/A Output: 102 dB
Video
HDCP Version 2.2
Input/Output Level and Impedance Composite Video: 1 Vp-p, 75 Ohms
Component Video, Y Signal: 1 Vp-p, 75 Ohms
Component Video, PB/CB and PR/CR Signals: 0.7 Vp-p, 75 Ohms
Frequency Response Composite Video: 5 Hz to 10 MHz (0, -3 dB)
Component Video: 5 Hz to 60 MHz (0, -3 dB)
Tuner Section
Tuner Bands AM / FM
Reception Frequencies AM: 520 to 1710 kHz
FM: 87.5 to 107.9 MHz
Sensitivity AM, Effective: 18 μV
FM, Effective: 1.2 μV (12.8 dBf)
50dB Sensitivity Mono/Stereo FM, Mono: 2.8 μV (20.2 dBf)
S/N Ratio FM, Mono: 70 dB (IHF-A weighted, Direct Mode)
FM, Stereo: 67 dB (IHF-A weighted, Direct Mode)
Distortion FM, Mono: 0.7% (1 kHz)
FM, Stereo: 1% (1 kHz)
Connectivity
Bluetooth Version: 3.0 + EDR (Enhanced Data Rate)
Transmission Power: Class 1
Maximum Communication Range: Approximately 98.4' (30 m) in line of sight
Frequency Band: 2.4 GHz
Modulation Scheme: FHSS (Frequency-Hopping Spread Spectrum)
Supported Profiles: A2DP (Advanced Audio Distribution Profile) 1.2, AVRCP (Audio Video Remote Control Profile) 1.5
Corresponding Codec: SBC
Transmission Range (A2DP): 20 Hz to 20 kHz
Wi-Fi Radio Frequency: Dual-band (2.4 / 5 GHz)
Network Type: Wi-Fi 4 (IEEE 802.11a/b/g/n)
Security: WEP 64-bit, WEP 128-bit; WPA/WPA2-PSK (AES); WPA/WPA2-PSK (TKIP)
Inputs 8 x HDMI (1 front)
2 x optical TOSLINK
2 x digital coaxial
3 x component video
4 x composite video (1 front)
7 x stereo RCA audio (1 front, 1 phono with ground screw)
1 x USB (front)
1 x 7.1-channel analog in
Outputs 3 x HDMI (1 with ARC)
1 x component video
2 x composite video
2 x subwoofer pre-out
2 x stereo RCA (Zone 2/3)
1 x 11-channel analog pre-out
Other Ports 1 x FM antenna
1 x AM antenna
1 x Ethernet
1 x 1/8" / 3.5 mm IR in
1 x RCA remote in
1 x RCA remote out
2 x 1/8" / 3.5 mm 12 VDC, 150 mA out
1 x RS-232C DE9
2 x Bluetooth/Wi-Fi antennas
1 x 1/8" / 3.5 mm setup mic in (front)
Speaker Connectors 11 x gold-plated binding post pairs
File Support WMA, MP3, WAV, MPEG-4 AAC, FLAC, Apple Lossless, DSD
Input Sensitivity Analog: 200 mV
Phono: 2.5 mV
Frequency Response Analog: 10 Hz to 100 kHz (+1, -3 dB, Direct mode)
Physical Specifications
Power Requirements 120 VAC, 60 Hz
Power Consumption (Active) 710 W
No Sound, ECO On: 65 W
No Sound, ECO Off: 110 W
Power Consumption (Standby) 0.2 W
CEC Standby: 0.5 W
Network Standby: 2.7 W
Dimensions (W x H x D) 17.32 x 9.72 x 16.18" / 440 x 247 x 411 mm with antennas up
17.32 x 7.28 x 16.18" / 440 x 185 x 411 mm with antennas down
Weight (Approximate) 31.1 lb / 14.1 kg
SR7013
9.2 Channel 4K Ultra HD AV Receiver with IMAX Enhanced, Dolby Atmos, Auro-3D, HEOS, AirPlay 2 and Alexa Voice Compatibility
Enjoy a superior and powerful listening experience for your favorite movies and music with precision audio engineering and tuning. The Marantz SR7013 features Dolby Atmos, DTS:X, Auro-3D and DTS Virtual:X decoding for immersive home theater, and proprietary HDAM circuit boards for more detailed, dynamic sound. Eight HDMI inputs are fully compatible with the latest specifications, including 4K Ultra High Definition video, 60Hz video, HDR, Dolby Vision and Hybrid Log-Gamma. Listen to all your favorite music from your smart devices via Bluetooth, AirPlay 2 or the HEOS app. Control the SR7013 with your voice and Amazon Alexa — download the HEOS Home Entertainment skill and ask Alexa to play, pause or stop music, switch inputs for your different media players, turn up the volume and more.馬蘭士9.2聲道4K AV擴音機具備Dolby Atmos, Auro-3D技術
以精確的音頻工程和調節為您欣賞喜愛的電影和音樂帶來優越和強大的聆聽體驗。馬蘭士SR7013配備了杜比全景聲、DTS:X和DTS Virtual:X解碼,帶來沉浸式家庭影院體驗,並配備專屬HDAM電路板,確保了更細膩、動態的聲音效果。八個HDMI輸入完全兼容最新規格,包括4K超高清視頻、60Hz視頻、HDR、Dolby Vision和Hybrid Log-Gamma。通過藍牙、AirPlay 2或HEOS應用程序從智能設備聆聽所有您最喜歡的音樂。通過您的語音和Amazon Alexa控制SR7013——下載HEOS家庭娛樂技能,請Alexa播放、暫停或停止音樂,切換不同媒體播放機的輸入,調整音量等等。Key Features
- 9.2 channel AV Receiver with 8 Ohms driven per channel
- 8 HDMI inputs (incl. 1 front) with full HDCP 2.2 support; 3 HDMI outputs (incl. Zone 2)
- Advanced video processing with analog to HDMI, SD to HD/4K Upscaling
- 4K/60 Hz full-rate pass-through, Dolby Vision compatibility, HDR, HLG and BT.2020
- Tree-dimensional audio formats IMAX Enhanced, Dolby Atmos, DTS:X (up to 7.1.4 with an external 2ch amplifier), Auro-3D and DTS Virtual:X for height virtualization effects
- eARC (Enhanced Audio Return channel) supports the transmission of 3D audio from your TV apps with a single HDMI connection
- Stream music from Internet Radio, Spotify Connect, Pandora, SiriusXM, Amazon Music, TIDAL, Deezer and more with Bluetooth, Airplay 2 or HEOS built-in
- Built-in Wi-Fi with 2.4GHz/5GHz dual band support
- Enjoy multi-room whole-home audio streaming with HEOS technology
- Amazon Alexa voice control via the HEOS Home Entertainment skill
- Marantz 2016 AVR remote for control over the latest generation of Marantz network AV Receivers. Available on iOS and Android.
- High Resolution DSD (2.8/5.6MHz), FLAC, ALAC and WAV support
- AKM AK4458 32-bit D/A converters, HDAM circuit boards and Current Feedback circuitry for optimum fidelity and maximum dynamic range
- Suite of Audyssey room correction software: Audyssey MultEQ XT32, Dynamic Volume and Dynamic EQ, LFC and Sub EQ HT
- Seamless out-of-the-box experience with Quick Start Guide, guided Setup Assistant and Marantz AVR Remote App
- Hybrid PLL Clock Jitter Reducer for pristine sound that’s immune to disruptions in the surrounding environment
主要特色
- 9.2聲道AV擴音機,內置9聲道放大器,11.2聲道解碼
- 8個HDMI輸入(包括1個前置),支持全HDCP 2.2;3個HDMI輸出(包括區域2)
- 高級視頻處理帶模擬至HDMI技術和SD至HD/4K升頻技術
- 4K/60 Hz全速率直通、Dolby Vision兼容性、HDR、HLG和BT.2020
- 三維音頻格式杜比全景聲、DTS:X(高達7.1.4,使用外部雙聲道放大器)、Auro-3D和DTS Virtual:X,確保高度虛擬化效果
- eARC(增強音頻回傳通道)通過單一條HDMI連接線支持從電視機App進行3D音頻傳輸
- 利用內置藍牙、Airplay 2或HEOS從互聯網收音機等串流媒串流傳輸音樂
- 內置Wi-Fi並支持2.4GHz/5GHz雙頻
- 通過HEOS技術享受多房間全屋音頻串流傳輸
- 通過HEOS家庭娛樂技能使用亞馬遜Alexa語音控制
- 馬蘭士2016 AVR App用於控制最新一代的馬蘭士網絡AV擴音機。適用於iOS和Android。
- 支持高解析度DSD (2.8/5.6MHz)、FLAC、ALAC和WAV文件
- AKM AK4458 32bit D/A轉換器、HDAM電路板和電流反饋電路,確保最佳傳真度和最大動態範圍
- Audyssey房間聲學校正套件:Audyssey MultEQ XT32、Dynamic Volume(動態音量)和Dynamic EQ(動態均衡器)、LFC和Sub EQ HT
- 通過快速入門指南和馬蘭士AVR Remote應用,嚮導式設置助手實現無縫開箱即用體驗
- 混合PLL時基誤差抑制電路確保原始聲音,不受周圍環境的干擾
High-performance Discrete 9-Channel Amplifier
Featuring discrete high-current power amplifiers on all channels, the SR7013 delivers 125 watts of power per channel (8 Ohm, 20 Hz - 20 kHz, 0.08% 2ch drive). With low impedance drive capability, it offers operational stability with a wide range of speakers for balanced, quality sound. To enjoy immersive 3D sound, you can set up a 7.1.2 or 5.1.4 3D experience without the need of external amplifier or expand to 7.1.4 with an additional two-channel amp. Auto Eco Mode adjusts power output to speakers based on volume level and on-screen eco meter, providing power consumption reduction in real-time without sacrificing superb Marantz sound.高性能分離式9聲道放大器
所有聲道配備分離式高電流功率放大器,SR7013為每聲道輸送200瓦的功率(6 Ω,1 kHz,1%,單聲道)。利用低阻抗驅動能力,為各種各樣的揚聲器提供操作穩定性,確保平衡、高品質的聲音。為享受沉浸式三維聲效,您可以將設置調整為7.1.2或5.1.4的三維體驗,無需外部放大器,或利用附加雙聲道放大器擴展至7.1.4。自動Eco模式基於音量和屏幕上的eco表對揚聲器的功率輸出進行調節,實時降低功率損耗,且不會影響馬蘭士卓越的音質。Latest HDMI Connectivity
Includes eight HDMI inputs — with one HDMI input on the front panel for quick connection — each one supporting HDCP 2.2, 4K Ultra HD 60Hz video, 4:4:4 Pure Color sub-sampling, Dolby Vision, HLG, High Dynamic Range (HDR), 21:9 video, 3D and BT.2020 pass-through. The video processor is capable of upscaling SD and HD video to 4K Ultra HD. Three HDMI outputs allow you to connect to multiple zones and run a TV and projector at the same time.最新HDMI連接性
包括八組HDMI輸入(一個位於前面板,用於快速連接),均支持HDCP 2.2、4K超高清60Hz視頻、4:4:4純色子採樣、Dolby Vision、HLG、高動態範圍(HDR)、21 :9視頻、3D、和BT.2020直通。視頻處理器能將標清和高清視頻升頻至4K超高清視頻。三個HDMI輸出允許您連接至多個區域,同時使用電視和投影機。Supports All Latest Object-based Audio Formats
Immerse yourself in multi-dimensional audio with the latest surround formats, including IMAX Enhanced, Dolby Atmos, DTS:X and DTS Virtual:X.支持所有最新的基於對象的音頻格式
讓您沉浸在杜比全景聲、DTS:X和DTS Virtual:X等最新環繞立體聲格式的多維立體聲音頻之中。 DTS Virtual:X提供沒有縱向聲道的沉浸式音頻性能,在5.1、7.1或2.1揚聲器佈置中營造虛擬縱向效果。IMAX Enhanced Technology
Get the most premium at-home entertainment experience with IMAX Enhanced—the latest technology program from IMAX that sets a new standard for image, sound, scale and content quality. Watch clearer pictures and brighter images. Feel immersive, heart-pounding audio delivered by DTS. See more picture on the largest screens. And experience premium content digitally remastered by IMAX.IMAX Enhanced技術
通過IMAX Enhanced獲得最高級的家庭娛樂體驗 - IMAX的最新技術計劃為圖像,聲音,比例和內容質量設立了新標準。 觀看更清晰的圖像和更明亮的畫質。 感受由DTS提供的身臨其境,令人心跳加速的音頻。 在最大的屏幕上觀看更多影片。 並體驗IMAX以數字方式重新製作的優質內容。Dolby Atmos
Feel every dimension in Dolby Atmos. Enjoy a 5.1 surround sound speaker system and two additional overhead speakers or two Dolby Atmos elevation speakers for the ultimate home theater experience — including Dolby Surround upmixer for legacy content.杜比全景聲(Dolby Atmos)
全方位感受杜比環繞聲。只需一個5.1環繞聲揚聲器系統和兩個附加天花頂置揚聲器或2個杜比全景聲反射揚聲器,即可享受終極家庭影院體驗——包括用於傳統內容的杜比環繞聲上混頻器。DTS:X
DTS:X immersive audio formatting places sound where it would naturally occur in space, creating life-like, multi-dimensional audio. The included spatial remapping engine of DTS Neural:X:tm: offers improved immersion and heightened realism in all of your favorite movies.DTS:X沉浸式音頻格式將聲音置於它在空中的自然發聲位置,在家中創建逼真的多維音頻體驗。 DTS Neural:X:tm:附帶空間重映射引擎,為您所有最喜愛的電影提供改善的沉浸效果和增強的真實感。
DTS Virtual:X
DTS Virtual:X provides immersive audio without height channels, creating virtual height effects in a 5.1, 7.1 or 2.1 speaker arrangement.DTS Virtual:X提供沒有縱向聲道的沉浸式音頻性能,在5.1、7.1或2.1揚聲器佈置中營造虛擬縱向效果。
HEOS, Bluetooth, Wi-Fi and AirPlay 2 Capability
Dual antenna system lets you stream the most popular music services via Bluetooth, AirPlay 2 or the HEOS app. Listen to your playlists on Spotify, Pandora, TuneIn, Deezer and more.HEOS、藍牙、Wi-Fi和AirPlay 2功能
雙天線系統讓您通過藍牙、AirPlay 2或HEOS應用程序串流傳輸最流行的音樂服務。聆聽您在TuneIn等媒體上的播放列表。HEOS Multi-room Streaming
Built-in HEOS technology lets you enjoy your favorite music in any room of your home for a wireless, whole-home audio experience. Play the same song in every room or select a different song for each connected room — the choice is yours. Enjoy music from Spotify, TuneIn, Sound Cloud, Tidal, Napster, Deezer or your local music file libraries. With additional HEOS components, like HEOS-capable speakers, play all your music in one room or many.HEOS多房間串流傳輸
內置HEOS技術讓您在家裡任何房間都能欣賞自己最喜愛的音樂,享受全家無線音頻體驗。在每個房間播放同一首歌,或為每個連通的房間選擇不同的歌——選擇權在您手裡。從TuneIn或您的本地音樂文件庫欣賞音樂。享受Spotify,TuneIn,Tidal音樂文件庫的音樂。利用附加HEOS組件,如支持HEOS的揚聲器,可以在一個房間或多個房間播放您所有的音樂。Support for Major Voice Control Agents
Enjoy effortless voice control and total flexibility from the leading voice agents. Speak commands with Amazon Alexa , Google Assistant, Apple Siri and high-end smart home automation, Josh.ai. Ask to play your favorite music, turn the volume up, skip to the next track, switch inputs and more. Switch between voice agents, or pick a favorite to use — the choice is yours. Functionality varies by voice agent.Amazon Alexa Voice Control
Use your voice to stream your favorite music services to this HEOS-enabled device. Ask Alexa to play music from Pandora, Spotify, Amazon Music and much more. Switch between inputs (Blu-ray, DVD, Media Player, etc.), turn volume up or down, pause, mute and play the next song — all with your voice.To start streaming with Alexa voice commands, open the Alexa app and select “Skills.” Add HEOS Home Entertainment to enable. Then, go to Smart Home in the Alexa app menu and choose Devices and Discover or say “Alexa, discover my devices.”
Learn More
Google Assistant Voice Control
Ask your Google Home, Google app or other devices with Google Assistant built-in to control content across your listening environment. Start music in the HEOS app, then ask your Google Assistant to control volume, play, pause, skip tracks and more. ‘Works with the Google Assistant’ feature is always improving — further enhancements arrive in 2019.Learn More
AirPlay 2 + Apple Siri Voice Control
Stream audio from your favorite music services like Apple Music and Spotify or watch videos from services like Youtube and Netflix from any iPhone, iPad, Mac or Apple TV and hear the audio perfectly synced to your speakers Airplay 2 sources.Airplay 2 also supports multi-room audio – wirelessly stream content to multiple AirPlay 2 compatible devices simultaneously with improved audio buffering to ensure smooth audio playback. AirPlay 2 provides control and grouping of compatible audio devices within the Apple Music or Home app. Use Airplay 2 in-app or with your voice via Siri.
Learn More
Josh.ai Smart Home Voice Automation
An elevated voice agent for the high-end smart home, Josh.ai offers flexible voice control for nearly any aspect of your day-to-day experience and entertainment environment. Use voice commands to control the thermostat, lights, home appliances, speakers, AVR and more. Josh.ai is installed by custom integrators and accessed through an app on your phone or tablet. Works with iOS and Android devices.Learn More
Marantz 2016 AVR Remote
The Marantz 2016 AVR Remote app provides unprecedented control over the latest generation of Marantz network AV Receivers. Control power, volume, input and settings, or switch to the HEOS app to access an incredible range of music content and streaming services. Download available for iOS and Android phones and tablets.馬蘭士2016 AVR Remote應用程序提供對最新一代馬蘭士網絡AV接收機前所未有的控制。控制電源、音量、輸入和設置,或切換至HEOS應用程序以訪問範圍極廣的音樂內容和串流媒體服務。 iOS和Android手機和平板電腦都可以下載。
High-resolution Audio Support
Discover the incredible fidelity of high resolution audio tracks with the ability to decode up to 24-bit/192-kHz ALAC, FLAC and WAV lossless files as well as DSD 2.8MHz and 5.6MHz tracks (the audiophile format of SACD) via the front panel USB port and network sources. Or, listen to other popular file types such as MP3.支持高清音頻
通過前面板USB接口和網絡資源,解碼高達24bit /192-kHz的ALAC、FLAC和WAV無損文件以及DSD 2.8MHz和5.6MHz曲目(SACD音響格式),讓您享受高清音頻曲目令人難以置信的傳真度。您還可以聆聽其他流行的文件類型,如MP3。Advanced 32-bit D/A Conversion on All Channels
For optimum fidelity and the widest dynamic range with lowest distortion, the SR7013 features advanced reference-class 32-bit AKM D/A converters on all channels. This ensures consistent high fidelity and precise channel matching across all channels for the ultimate listening experience.所有聲道配備高級32bit D/A轉換功能
為獲得最佳傳真度和最寬動態範圍並把失真降到最低,SR7013在所有聲道上配備了先進的參考級32 bit AKM數模轉換器。這能確保所有聲道都有一致的高傳真度和準確的聲道配對,實現終極聆聽體驗。High Grade Audio Components; Marantz HDAM and Current Feedback Technology
The SR7013 features exclusive Marantz Hyper Dynamic Amplifier Module (HDAM) technology that provide ultra-fast slew rate, true wideband performance and maximum dynamic range for optimum sound quality. Current Feedback technology, first introduced by Marantz more than 60 years ago, replaces voltage feedback configuration that’s typical of AV receivers and delivers wide, closed-loop bandwidth and steep slew rate for superior fidelity with wideband audio sources.Phono EQ Stage with HDAM
The HDAM component of the Marantz SR7013 outperforms op-amp solutions due to its high speed and maintains a clean audio signal for exceptional sound performance.帶HDAM的唱頭均衡器前級
馬蘭士SR7013的HDAM組件遠勝運算放大器方案,因為它速度快且能保持清晰的音頻信號,確保了超凡的聲音性能。Advanced Audyssey MultEQ XT32
Equipped with the full Audyssey Platinum suite of advanced DSP algorithms, the SR7013 features Audyssey MultEQ XT32 automatic room acoustic correction. With the supplied measurement microphone, MultEQ XT32 analyzes each speaker's output (including the subwoofers) at up to eight measurement locations and generates precision digital filters that optimize each channel for the correct frequency and time domain response. Audyssey Dynamic Volume smooths out disruptive jumps in volume (such as TV commercials), letting you listen at lower levels while still enjoying clear dialogue, music and sound. Audyssey Dynamic EQ provides full-range clarity at any listening level, and Audyssey Low Frequency Containment uses advanced psychoacoustic algorithms to deliver a full-range balance, including deep bass, without disturbing neighbors or people in other rooms of your home. Audyssey Sub EQ HT provides individual DSP tailoring of each subwoofer in a dual subwoofer setup for deeper bass with improved definition. Plus, the Audyssey MultEQ Editor app lets you view and adjust settings for detailed tuning and customize the sound more precisely to your room and tastes.先進的Audyssey MultEQ XT32
配備高級DSP算法的完整Audyssey套件,SR7013具有Audyssey MultEQ XT32自動室內聲音校正功能。通過附帶的測量麥克風,MultEQ XT32可在最多八個測量位置分析各揚聲器的輸出(包括超低音揚聲器),並產生能優化各聲道以獲得正確頻率和時域響應的精確數碼濾波器。 Audyssey Dynamic Volume能撫平音量上的干擾性變動(如電視廣告),讓您以更低的聲級聆聽但仍能欣賞到清晰的對話、音樂和聲音。 Audyssey Dynamic EQ可在任何音量級別提供全頻程清晰度,而Audyssey低頻阻遏技術運用先進的心理聲學算法提供全頻程平衡,包括重低音,使鄰居或家中其他房間的人不受打擾。 Audyssey Sub EQ HT為雙超低音揚聲器音響設置中的各超低音揚聲器提供個別DSP定制功能,確保低音更低沉並改善清晰度。此外,可以使用Audyssey MultEQ Editor app查看和調整設置,進行細微調節,以及根據您的房間和品味更加準確地自定聲音。External Control Capabilities
The SR7013 features external control and IP control capabilities for easy customization and compatibility with third-party integration solutions. It offers IP control capability for major third-party control devices, as well as Control4 SDPP (Simple Device Detection Protocol) certification for seamless integration with Control4 home automation equipment. An IR (infrared) remote control is included on the rear panel for remote control compatibility with other components in your home theater system, and remote monitoring capability is now supported for troubleshooting.外部控制能力
SR7013具有外部控制和IP控制能力,便於進行定制設置並與第三方集成方案兼容。Multi-source, Multi-room
Watch a movie in one room while another family member listens to a CD in a different zone without interruption. Enjoy 7.1-channel surround sound in the main room and a separate source or music stream in another. Connect a pair of stereo speakers to the multi-room amplified outputs or hook up a separate stereo amp and speakers to the Zone 2 pre-outs多源、多房間
在一個房間觀賞電影,而其他家庭成員在別的區域聆聽CD,互不干擾。在主房間欣賞7.1聲道環繞聲而在另一房間欣賞其他音源或音樂串流媒體。將一對立體聲揚聲器連接多區域放大輸出,或將另一立體聲放大器和揚聲器搭接區域2前級輸出。Dual Subwoofer Outputs
Surround yourself with even, accurate bass. The SR7013 features two subwoofer outputs to smooth low frequencies and improve bass dispersion, avoiding peaks and audible dips.雙超低音揚聲器輸
在您周圍環繞均勻、精準的低音。 SR7013配有兩個低音炮輸出,以使低頻聲效圓潤,並改善了低音分散,避免了峰值和可聽見的谷。Smart TV Connectivity
The Marantz SR7013 may be controlled with your Smart TV remote via the HDMI CEC functionality associated with your Smart TV. Simply set “HDMI Control” to ON in your receiver, then set “Smart Menu” to ON and begin controlling the SR7013 with your TV remote. The Smart Menu home screen provides you quick access to source and surround mode selections, the AVR's setup menu and four Smart Selects.智能電視連接能力
可以通過與智能電視相關聯的HDMI CEC功能,使用智能電視遙控器控制馬蘭士SR7013。只需在擴音機上將“HDMI控制”設為“ON”,再將“智能菜單”設為“ON”,即可使用您的電視遙控器控制SR7013。智能菜單主屏幕上提供了音源和環繞模式選擇、AVR設置菜單以及四個智能選擇的快速訪問方式。Simple Smart Select Functions
The SR7013 features a front panel with four Smart Select buttons that store your preferred setup for each source, including input, volume and Audyssey configuration. With each button, EQ settings will adjust to support television, Blu-ray, Internet radio and more.簡易智能選擇功能
SR7013前面板搭載了四個智能選擇按鈕,儲存了您對每個資源的設置偏好,包括輸入、音量和Audyssey的配置。通過每個按鈕,EQ設置都會進行調整,以支持電視、藍光、網絡收音機或其他資源。Easy Setup Experience
The SR7013 Quick Start Guide provides simple, direct instructions to get started. Once you connect your TV to the SR7013 via HDMI, the Marantz Setup Assistant appears on your TV screen and guides you through setup. The Setup Assistant helps you establish crucial settings for the best possible sound quality, whatever your configuration.便捷的設置體驗
SR7013快速入門指南為開始使用提供了簡單直接的說明。一旦通過HDMI將電視機連接到SR7013,您的電視屏幕上就會出現馬蘭士設置助手並指導您完成整個設置。設置助手可幫助您制定獲得最佳音質的關鍵性設置,不管您的配置如何。More Than 60 Years of Audiophile Heritage
Founded in 1953, Marantz has a long and rich history of designing audio components embraced by music lovers and critical listeners around the world. Because Music Matters, the SR6013 carries on our long tradition of delivering a best-in-class listening experience for music and cinema.超過60年的高保真傳承
馬蘭士創辦於1953年,具有悠久豐富的音響器材設計歷史,其產品得到全球音樂愛好者和挑剔收聽者的推崇。因為“音樂至上”。More Support for Custom Integration
All Marantz 2018 AVRs offer extended support for easy integration into custom installs. To support this effort, Marantz 2018 AVRs support “ihiji Invision” remote system management technology, “Domotz Pro” remote monitoring and management technology as well as offer a web interface to control and setup your AVR from a computer on the same network. The two first programs allow you to monitor the status of connected products and troubleshoot remotely from a sperate location or on the go.Interested please feel free to contact:
Amplifier
Channels 9.2
D/A Output: 102 dB
Video
HDCP Version 2.2
Tuner Section
Tuner Bands AM / FM
Connectivity
2 x optical TOSLINK
2 x digital coaxial
3 x component video
1 x USB (front)
1 x component video
2 x composite video
1 x AM antenna
1 x Ethernet
1 x RCA remote in
1 x RCA remote out
1 x RS-232C DE9
Phono: 2.5 mV
CEC Standby: 0.5 W
- Number of posts : 1342
» Marantz SR7015 9.2-Channel 4K Ultra HD AV Receiver
» Marantz SR7013 AV Receiver (SOLD)
» Marantz SR5012 7.2 Channel Full 4K Ultra HD AV Receiver (Used) SOLD
» onkyo tx nr5009 thx ultra plus 2 9.2 channel av receiver used
