AAD by Phil Jones C-11 Down Firing 10 inch Active Subwoofer
Item: AAD by Phil Jones C-11 Down Firing 10 inch Active Subwoofer
The subwoofer looks impressive. He rests on a special platform, unleashing it with the floor. A 254-mm speaker with a proprietary aluminium diffuser and a soft suspension is directed downwards towards the floor. It is powered by a 160-watt amplifier. The bass reflex port is located on the rear panel. All controls are on the front panel. By the way, the device has a 5-band equalizer.
Condition: Brand New in Unopened box
Colour: Black
Price: RM1000 nett only. New was RM2100.
Specifications for this product:
Model: C-11
Type: Active Subwoofer ( Down Firing)
Frequency Response : 30Hz-160Hz +/- 3dB
Bass Principle : Bass Reflex
Accessories: Power cord
Poweroutput: 160w Class A/B
Speakers : 1x10 inch Aluminum Cone Woofer
Net Weight : 52 lbs
Volts : 240V AC
Design. The subwoofer looks impressive. He rests on a special platform, unleashing it with the floor. A 254-mm speaker with a proprietary aluminium diffuser and a soft suspension is directed downwards towards the floor. It is powered by a 160-watt amplifier. The bass reflex port is located on the rear panel. All controls are on the front panel. By the way, the device has a 5-band equalizer. On the back panel are all the switching connectors, the choice of which inspires respect.
Sound. Deep, dynamic and pure bass in the Movie and Also for Music.
The sound body is powerful, This AAD model expressively plays music. This is helped by the correct operation of the Equalizer (a rare phenomenon) : it allows you to adjust / fine tune Low Frequency Bass to the acoustics of the room.
Specifications:
Power: 160 Watts Continuous at 4 Ohms (Class A / B)
Resp. Frequency: 30HZ - 160Hz
Speaker: 1 woofer 10 "
Electronic Crossover: Variable 30Hz-160Hz, 24dB / octave
Phase adjustment: 0-180 degrees variable
5-band equalizer: +/- 10dB at 25Hz, 40Hz, 60Hz, 80Hz and 100Hz
Inputs / Outputs: RCA for line signal and speaker terminals
Unit Weight: 23.5kg
Dimension (cm): 51.4 Height x 37.5 Width x 44.5 Depth
Actual item pictures. Still in sealed box
For reference, item is the same as below:
https://www.hifi4sale.net/t59592-aad-by-phil-jones-c-11-down-firing-10-inch-active-subwoofer
https://produto.mercadolivre.com.br/MLB-1144641740-subwoofer-aad-by-phil-jones-c-11-para-audio-home-estudio-_JM
Colour: Black
Model: C-11
Net Weight : 52 lbs
Volts : 240V AC
Specifications:
Unit Weight: 23.5kg
» Aad by Phil Jones SD-10 Subwoofer
» AAD by Phil Jones, SD-10 (Sold)
» AAD by Phil Jones CX-550 Floorstand speakers
» AAD Floorstanding Speaker By Phil Jones (Used)
» REL T5 Active Subwoofer
