Chario Academy Sonnet Loudspeakers With Original Stands
Item: Chario Academy Sonnet Loudspeakers With Original Stands
Condition: 8.5/10. Item is in excellent condition. Comes with the original stands. Academy Sonnet is built, as all the Chario Speakers, completely in Italy. The solid walnut wood is in mint condition, no scratches or dents.
Price: sold
Listening to music on small-sized systems is a reasonable and quite understandable preference, given that they are easily installed in many venues. Although the compromises required make this sort of design almost impossible, Sonnet offers a solution to bypass the Laws of Physics.
But we can exploit the very small size of the cabinet as a true source to design a "smart" crossover capable of re-sizing the sound stage following your preferences.
ACADEMY : SONNET
Websites:
https://www.ultimateaudio.gr/el/proionta/chario/academy/chario-academy-s-sonnet-1-000-me-basi.html
https://www.hifi-forsale.co.uk/moreinfo.php?prod_title=Chario_Academy_Sonnet_Loudspeakers_with_Stands&p=standspeaker&prod_id=51054&offset=
http://www.xtremeplace.com/yabbse/index.php?topic=167880.0
https://picclick.co.uk/Chario-Sonnet-Academy-With-Original-Stands-323604779308.html
https://www.enjoy-audio.de/angebote-details/chario-academy-sonnet.html
https://www.ihoekfrasi.gr/Audio/Speakers/Bookshelf-Speakers-hxeia-%CE%B7%CF%87%CE%B5%CE%B9%CE%B1-%CF%81%CE%B1%CF%86%CE%B9%CE%BF%CF%85/Chario-Academy-Sonnet-bookshelf-walnut.html
Price: sold
ACADEMY : SONNET
Low Frequency Load | Back firing Vented 4? sr |
Vent Geometry | Half-Exponential Hourglass Type |
Configuration | 2 way Reversed Array |
Drivers | 1 Tweeter 32 mm SILVERSOFT TM dome NeFeB motor 1 Woofers 170 mm ROHACELL Full-Apex TM Poly-Ring NeFeB motor |
Sensitivity | 90 dB SPL normalized to 1m with 2.83Vrms de-correlated L/R pink noise within IEC 268-13 compliant listening room |
Low Frequency Cut Off | 55Hz @ -3dB referred to C4 WETS |
Xover Frequency | 1,180 Hz |
Rated Impedance | Modulus 4O (min 3.0) Argument ±36° |
Size | 445x235x340 mm (HxWxD) |
Weight | 14kg |
Suggested Amplifier | Rated for 120 W/4 max Average Power |
Cabinet Finishing | Solid walnut or cherry and HDF |
Speakers Orientation | The speakers can be tilted inward/outward to control sound stage width. |
Optional Stand | Weight 13kg Size 750x540x460 mm (HxWxD) Iron black anodized (Top Plate & Legs) Painted HDF (central body) |
Websites:
» Chario Academy Sonnet (used)
» Chario Academy Sonnet speaker (Used)SOLD
» Chario Academy Sonnet speakers (Used) SOLD
» Chario Academy Millenium II with factory original stand (Used)
» Chario academy 3 speakersold
