Cambridge Audio CXA-60 Integrated Amplifier
Item: Cambridge Audio CXA-60 Integrated Amplifier
Condition: 9/10. Item is in like new condition. Bought less than one year ago. Still under warranty. With receipt. Complete with all accesories. Selling due to under utilize.
New price is RM3899.00 as below:
https://www.stylelaser.com.my/product/cambridge-audio-cxa60-integrated-amplifier/
https://shopee.com.my/Cambridge-Audio-CXA-60-Integrated-Amplifier-i.135005905.2031123992
Price: Letting go for only RM2500. First come first serve.
https://www.cambridgeaudio.com/en/products/cx/cxa60
https://www.whathifi.com/cambridge-audio/cxa60/review
Code : CACXA60
RM 6000
RM 3999
RM 6000
RM 3999
[size=36]CXA60[/size]60W integrated amplifierThe most fun you can have with 60 watts. An amplifier is the heart of any hi-fi system and ours - What Hi-Fi?�s �Best Stereo Amplifier� two years running � is hugely entertaining. With those 60 watts of power comes 4 analogue, 3 digital and optional Bluetooth inputs so your connectivity is sorted too. OUR MOST ENERGETIC SOUND YET Designing the CXA60 was a challenge that was accepted with open arms by our engineers. We wanted an amp that sounded more musical and energetic than anything we�ve made before. They beavered away for months and after some particularly late nights they eventually nailed it. To achieve this they used some unique engineering techniques, some very premium components, and some great ears for detail. LISTEN TO YOUR MUSIC AT ITS BEST We�ve used an audiophile-grade toroidal transformer which helps minimise magnetic flux levels. This basically keeps distortion and other noise levels low so that your music is played back with complete purity. We also centrally mount the transformer to reduce interference with other components in the circuit board such as the volume pot; this is in a further effort to keep your music sounding amazing. As for the volume pot itself, we�ve used an ALPs film type volume pot which delivers accurate volume control and superb low level channel balance so the volume is always perfectly controlled across both left and right channels at whatever volume you�re enjoying. EVERY INSTRUMENT HAS ITS PLACE ON YOUR STAGE The CXA60 was designed to work with digital sources from the outset so has a 24-bit Wolfson WM8740 DAC (a very premium digital to analogue converter) built in. This chip is as the heart of our award-winning DacMagic range. So whether it�s music from your TV or your network streaming device, it all gets passed through the Wolfson DAC. Connecting the CXA60 to the digital out of the CXC dedicated CD transport also creates a perfect partnership. The result is that any digital music soars to new heights, reveals new depths and can be enjoyed like never before. CONNECTIONS Digital connections are in the form of S/PDIF co-axial and TOSLINK digital inputs. Add an optional BT100 Bluetooth dongle and you have access to aptX high-quality streaming, opening up a world of wireless possibilities from your paired device. Analogue options include four sets of RCA inputs and a front 3.5mm aux jack so you�re fully catered for there as well. POWER OUTPUT 60W RMS into 8 Ohms, 90W RMS into 4 Ohms DAC Wolfson WM8740 FREQUENCY RESPONSE <5Hz� 60kHz +/-1dB ANALOGUE AUDIO INPUTS 4 x RCA, 1 x 3.5mm MP3 input (front panel) DIGITAL AUDIO INPUTS 1 x S/PDIF coaxial, 2 x TOSLINK optical, Bluetooth via BT100 (not supplied) COMPATIBILITY TOSLINK optical, S/PDIF coaxial, BT100 Bluetooth receiver OUTPUTS Speakers A+B, 3.5mm Headphone, Preamp Output, Subwoofer Output MAX POWER CONSUMPTION 600W STANDBY POWER CONSUMPTION <0.5W DIMENSIONS (H X W X D) 115 x 430 x 341mm (4.5 x 16.9 x 13.4�) WEIGHT 8.3kg (18.3lbs) |
» SOLD Cambridge Audio Topaz AM10 Integrated Amplifier and Cambridge Audio SX-60 Bookshelf Speakers.
» Cambridge Audio Integrated Amplifier Azur 351A and Cambridge Audio CD Player Azur 351C (USED)(SOLD)
» Cambridge Audio Integrated Amplifier Azur 351A+Cambridge Audio CD Player Azur 351C (USED) (SOLD)
» cambridge audio AXA 35 cd integrated amplifier
» Cambridge Audio P 40 integrated amplifier (Used)SOLD
