Paradigm Ultracube 12 12" Subwoofer Made In Canada (Sold Out)
Paradigm Ultracube 12 12" Subwoofer Made In Canada Brand New. Now Selling At RM5,999. Free Shipping Within West Malaysia.
单个高偏移驱动器,双254毫米(10英寸)平衡平面,高速无源辐射器,内置高级Class-D:tm:放大器,USB端口/ PBK接口。功率输出为1950瓦动态峰值/ 650瓦RMS。
Key Features
Denizens of the Deep
When it comes to compact subwoofer design our UltraCube:tm: Series breaks new ground. From their proprietary advanced Class-D:tm: amplifiers to their very high-power drivers, everything about these little cubes is optimized for high-performance, including their sleek, acoustically inert enclosures. Power! Impact! Extraordinary refinement! Remarkable musical finesse! The UltraCubes deliver it all! A completely unprecedented accomplishment in subwoofers of such compact dimensions.
UltraCube 12
Single high-excursion driver, dual 254-mm (10 in) balanced-plane, high-velocity passive radiators, built-in advanced Class-D:tm: amplifier, USB Port / PBK Interface. Power output is 1950 watts Dynamic Peak/650 watts RMS.单个高偏移驱动器,双254毫米(10英寸)平衡平面,高速无源辐射器,内置高级Class-D:tm:放大器,USB端口/ PBK接口。功率输出为1950瓦动态峰值/ 650瓦RMS。
Key Features
- 12" RCR:tm: Mineral-Filled Co-Polymer polypropylene cone, 2" Bifilar 2+2-layer Voice-Coil, Woofer
- Dual 10" Balanced-Plane, High-Velocity Passive radiators
- 650 Watts RMS Advanced Class D amplifier
- Variable 0° - 180° Sub / Sat phase alignment
- RCA (L/R-Mono) input, USB Port / PBK interface
- Auto On/Off, Soft clipping, Thermal & electrical shorting protection
Control Facilities
- Auto On/Off
- Subwoofer Level
- Subwoofer Cut-Off Frequency (continuously variable 40 Hz – 150 Hz)
- Sub/Sat Phase Alignment (continuously variable 0° to 180°)
- USB Port/PBK Interface
- Line-level Inputs
Features
Proprietary Advanced High-Power Class-D:tm: Switching Amplifiers
Provide truly massive amounts of clean, high-current power as well as ultra-low distortion. Power output is 1950 watts Dynamic Peak/650 watts RMS.Advanced Down-Firing Mineral-Filled Co-Polymer Polypropylene Cones with RCR:tm: Resonance Control Ribs
Superior cone rigidity and the high internal damping properties of polypropylene ensure well-extended bass response with impressive articulation and ultra-low distortion.Oversized Dual Magnet Structures
Generate exceptionally strong magnetic energy in the gap. Advanced suspension ensures wide peak-to-peak excursion with superb control.Proprietary AVS:tm: Airflow Ventilation System Cooling
Conducts heat away from the voice coil.Dual Balanced-Plane High-Velocity Passive Radiators
Solid, stable, and free from unwanted resonances and vibrations, the passive radiator design assists in providing the exceptionally deep bass these compact cubes deliver.Acoustically Inert MDF Enclosures
Help limit unwanted panel resonances and vibrations for clean, tight, extremely accurate bass performance.Interested please feel free to contact:
DESIGN | Single high-excursion driver, dual passive radiators, built-in advanced Class-D:tm: amplifier, USB Port / PBK Interface |
AMPLIFIER | 1950 watts Dynamic Peak / 650 watts RMS |
AMPLIFIER FEATURES | Auto-On / Off, soft clipping, thermal protection, electrical shorting protection |
ROOM CORRECTION | pbk-1 |
LOW FREQUENCY DRIVER | 305-mm (12 in) RCR:tm: mineral-filled co-polymer polypropylene cone, 51-mm (2 in) bifilar 2+2-layer voice-coil, dual spiders, AVS:tm: die-cast heatsink chassis |
FINISHES | Black Ash |
WEIGHT | 36 lbs. (16.3 kg) |
LOW FREQUENCY EXTENSION | 19 Hz (DIN) |
LOW PASS FILTER FREQUENCY | Variable 40 Hz - 150 Hz; Bypass Option |
SUB / SAT PHASE ALIGNMENT | Variable 0° - 180° |
INPUTS | RCA (L/R-Mono) for L/R Line-Out or Sub-Out / LFE-Out of receiver, processor or other line-level source |
PASSIVE RADIATORS | Dual 254-mm (10 in) balanced-plane, high-velocity passive radiators |
DIMENSIONS HXWXD (INCLUDES GRILLES AND FEET) | 15" × 14" × 14" (38.1cm × 35.6cm × 35.6cm) |
- Number of posts : 1336
» Paradigm UltraCube 12 Subwoofer (Used) SOLD
» Paradigm UltraCube 10 Subwoofer (Used) SOLD
» Paradigm Bookshelf Speaker (Made In Canada)
» Paradigm Monitor 11 v.3 Floorstanding Speaker Made in Canada (PL) - Reserved
