Musical Fidelity M1 CDT CD transport
Item: Musical Fidelity M1 CDT CD transport
Condition: 8.5/10. Item is in excellent condition. No dents or scratches. Comes with original remote, manual, power cable and original box.
Price: RM2200 or swap/topup
Retail Price: USD999.00
[*]High-quality, slot-loading CD transport
[*]M1 CDT minimises jitter thanks to their use of a premium stabilised clock system
[*]M1 CDT can be connected in true balanced mode to the M1 DAC via its AES/EBU output
[*]Perfect partner for the Musical Fidelity M1 CLiC or M1 DAC
by Crutchfield's
Dave Bar
Most CD players combine a transport that reads your discs with a digital-to-analog converter and other electronics to process the digital bits into sound. Needless to say, that combo works out pretty well most of the time. But when you really want the best possible performance, separate components for these two tasks are the way to go.
The Musical Fidelity M1CDT transport is a true CD specialist. It's designed to do only one thing with the utmost precision — read your compact discs. This single-purpose design allows it to deliver digital data to an outboard DAC with no interference from internal analog circuitry. To further improve playback accuracy, the M1CDT incorporates Musical Fidelity's premium stabilized clock system to ensure low-jitter performance. You'll hear more detail and impact from your music CDs when you play them on this transport.
The M1CDT's compact, slot-loading design saves you shelf space, and makes a perfect partner for Musical Fidelity's fantastic M1DAC digital-to-analog converter. Together these two take up the same amount of room as a standard-width CD player, while providing greater flexibility and performance. The M1CDT makes an excellent choice to pair up with other high-end DACs, as well.
remote control
15V trigger input and output for system control expansion
detachable power cord
8-11/16"W x 3-15/16"H x 13"-7/16"D
weight: 7.75 lbs.
[size=18]An Impressively Simple and Dynamic CD Transport[/size]
The M1 CDT high quality CD transport is a perfect match for the M1 DAC and the upcoming M1 CLiC. Its sophisticated power supply has seven separate sections and twin choke filtration to ensure ultra-low noise and highly accurate data retrieval.
The M1 CDT has a fully stabilized clock system which helps to ensure ultra low jitter. It will read a wide range of CDs: CDDA, CD-R AND CD-R/W discs, and it provides CD text (for those discs with that data). Digital outputs are: AES/EBU balanced, RCA Coax, and Toslink optical.
When feeding either M1 DAC or the upcoming M1 CLiC, the M1 CDT offers outstanding technical and sonic performance that illustrates the benefits of isolating the mechanical and electrical parameters of a transport mechanism from critical conversion circuits. As you can see from the pictures, it is elegant and beautiful.
Websites:
https://www.musicdirect.com/disc-player/musical-fidelity-m1-cdt-cd-transport
https://www.techradar.com/sg/reviews/audio-visual/hi-fi-and-audio/cd-players-and-recorders/musical-fidelity-m1-series-cd-player-and-dac-945215/review
http://www.hifi-review.com/152336-musical-fidelity-m1-cdt.html
https://www.hifix.co.uk/musical-fidelity-m1-cdt-cd-transport
https://www.musicalfidelity.com/m1cdt
About the Musical Fidelity M1CDT
by Crutchfield's
Dave Bar
A top-notch CD transport...
...deserves a top-shelf DAC
Product highlights:
- disc transport only — requires outboard digital-to-analog converter
- slot-loading design reads stereo audio from standard CD, CD-R, or CD-RW
- allows playback of 44.1kHz/16-bit S/PDIF digital CD audio
- supports CD text with compatible discs
- programmed playback for up to 30 tracks
- premium stabilized clock system ensure low jitter output
- digital outputs:
- 3-pin XLR (AES/EBU)
- coaxial RCA (S/PDIF)
- optical (Toslink S/PDIF)
Websites:
» Musical Fidelity MC-2 Speakers & Musical Fidelity B200 Integrated Amplifier SOLD
» Musical Fidelity Elektra E100 Integrated Amplifier & Musical Fidelity Elektra E600 CD Player Made In England (Used)
» Musical Fidelity M3CD CDP and Musical Fidelity M3i Integrated Amplifier
» Musical Fidelity F22 Pre Amplifier + Musical Fidelity F15 Power Amplifier Made in England ( PL )
