CAYIN A-88T MK2 (KT88 tube amp)
CAYIN A-88T MK2 (KT88 tube amp) Empty CAYIN A-88T MK2 (KT88 tube amp)
Post by ben wong on Wed Jun 17, 2020 3:50 pm
CAYIN A-88T MK2 (KT88 tube amp) Img_2013
CAYIN A-88T MK2 (KT88 tube amp) Img_2014
CAYIN A-88T MK2 (KT88 tube amp) Img_2015
Selling for : RM5,300
Good condition : 8/10 (no box)
Selling to upgrade
Whatsapp: Bennett 0176818939
Features:
  • Four pieces of KT88 are used for Class AB push-pull amplification while input stage has taken 6SL7 and 6SN7 for voltage regulation.
  • Designed with remote control and Triode and Ultralinear selection.
  • User bias control is accessible with true ampere meter on the chassis.Two 6SL7s and two 6SN7s are used in the preamplifier.
  • Can be used as a Power amplifier.
  • High-quality Japanese ALPS motorized potentiometer.
  • Thickly silver-plated signal cable has been used.
  • Hand-made construction with the finest point-to-point wiring.
  • Two EI output transformers with wide bandwidth and one specially-designed toroid power transformer are applied for A-88T MK2.
  • A-88T MK2 can memorise the last operation state once switched off.
  • Improved amplification circuit with Takman audio-grade resistors in key locations and Realcap PPMF-S series of high grade coupling capacitors being used to improve the sound.
  • Soft start function (about 30 seconds) and other protection circuit has been used for better protection of power transformer and output transformers.
Specification:
Power output : 2*25w (8 Ω,Triode)
                      2*45w(8 Ω,Ultralinear)
Dimension :     420mm*382mm*195mm
Weight :          28kg
Power consumption:  <280w
Tube:              KT88*4 , 6SN7*2, 6SL7*2
ben wong
Number of posts : 11
Registration date : 2017-04-13
CAYIN A-88T MK2 (KT88 tube amp) Empty Re: CAYIN A-88T MK2 (KT88 tube amp)
Post by ben wong on Tue Jun 30, 2020 10:57 am
ben wong
