Yaqin MS-12B Tube Preamplifier and Phono Stage (Moving Magent MM)
Yaqin MS-12B Tube Preamplifier and Phono Stage (Moving Magent MM) Empty Yaqin MS-12B Tube Preamplifier and Phono Stage (Moving Magent MM)
Post by yuenyan Wed Feb 24, 2021 11:37 am
Yaqin MS-12B Tube Preamplifier and Phono Stage (Moving Magent MM) Ms-12b10
Yaqin MS-12B Tube Preamplifier and Phono Stage (Moving Magent MM) Ms-12b11
Yaqin MS-12B Tube Preamplifier and Phono Stage (Moving Magent MM) Ms-12b12
Features:
1.Ability to use with CD/DVD player as a preamplifier and with MM cartridge turntable as a phono stage;
2.Dual stereo outputs either 0.7V for a post stage amplifier or 0.25V for an integrated amplifier. It can be applied to bi-amp configuration;
3.Employ DC filaments power supply to minimize humming noise;
4.Adopts conventional active RIAA equalization in phono stage circuit;
5.Power transformers manufactured with silicon steel sheet and high quality oxygen-free enameled copper wire;
Specifications:
Tubes:12AX7 × 2(Phono voltage amplifier)
12AU7 × 2(Voltage amplifier)
Output Voltages: Dual outputs of either 0.25V or 0.7V
0.25V (for integrated amplifier)
0.7V (for power amplifier or second gear)
Input Sensitivity:≤0.25V(Preamplifier)
≤5mV(Phono stage)
Distortion of Harmonic Wave: ≤0.2% (Preamplifier)
≤0.5% (Phono stage)
Frequency Response: 15Hz ~ 100KHz (-2.0dB)
Signal-to-Noise Ratio: >75dB (CD/DVD input 0.5V 1KHz, output 0.7V)
>65dB (Phono input 10mV 1KHz, output 0.7V)
Supply Voltage: AC115V 60Hz
Weight: 3.0kg (7.7lb)
Dimension: 17cm(W) x 38cm(D) x 16cm(H)
Shipping Weight: 4.6kg (10lb)
Shipping Dimension: 45cm x 25cm x 23cm
Packages:
A YAQIN MS-12B unit
A Power cable
A manual
18 months warranty
New in box
Price: RM1,999
yuenyan
Number of posts : 1324
Yaqin MS-12B Tube Preamplifier and Phono Stage (Moving Magent MM) Empty Re: Yaqin MS-12B Tube Preamplifier and Phono Stage (Moving Magent MM)
Post by yuenyan Thu Mar 25, 2021 5:13 pm
yuenyan
Post by yuenyan Wed May 05, 2021 9:13 am
yuenyan
Post by yuenyan Thu Jul 15, 2021 9:20 am
yuenyan
Post by yuenyan Thu Sep 23, 2021 8:55 am
yuenyan
Post by yuenyan Tue Dec 28, 2021 8:46 am
yuenyan
Post by yuenyan Fri Mar 18, 2022 9:02 am
yuenyan
Post by yuenyan Mon May 30, 2022 8:40 am
yuenyan
Post by yuenyan Sat Aug 06, 2022 8:46 am
yuenyan
Post by yuenyan Thu Nov 03, 2022 8:44 am
yuenyan
Post by yuenyan Thu Jan 19, 2023 9:02 am
yuenyan
Post by yuenyan Sat Apr 01, 2023 9:07 am
UP
yuenyan
