Yaqin SD-38A Vacumm Tube CD player
Yaqin SD-38A Vacumm Tube CD player Empty Yaqin SD-38A Vacumm Tube CD player
Post by yuenyan Thu Feb 25, 2021 10:59 am
Yaqin SD-38A Vacumm Tube CD player Yaqin-41
Yaqin SD-38A Vacumm Tube CD player Yaqin-39
Yaqin SD-38A Vacumm Tube CD player Yaqin-40
YAQIN SD-38A Vacuum Tube hifi CD PLAYER
Heart of the device is SONY high accuracy cassette mechanism, good stability and reading disc easy. Servo circuit uses the PHILIPS SAA7824 chip. It uses American BB Corporation PCM1732U chip with HDCD decoder. It uses the outstanding stable multi-layer filter circuit, Effective elimination numerical code signal,just High-fidelity Music signal output for you. It uses two low-resistance Vacuum Tube 6N8P, push power is powerful. It has the coaxial digital signal output terminal, it can connect external audio decoder Its coupled circuit uses Enthusiast nonpolarity Philips (MKP) capacitor and high quality metallic resistance.The output transformer use Japanese audio special stalloy (thickness is 0.35mm) and high strength enamel-insulated wire. It used special coiling process, let the audio frequency wide, to ensure timbre of the trebles, mediant and bass are nice, transparent and powerful.
SPECIFICATIONS:
Audio output signal:2.3V(+-0.5dB)
Frequency Response:10Hz-20kHz(+-0.3dB)
SNR:≥110dB(A)
Distortion:≤0.005%
Dynamic range≥100 dB
Channel separation:96dB
Power consumption:≤70W
Vacuum Tube:6N8P x 2
Input Power Voltage:(110V, 120V, 127V, 230V, 240V version will take 3-14 work days to order) 220V version is in stock
Dimensions:390mm x 490mm x 190mm
Weight13kg
Packing Include:Set Tubes, Aluminum remote control and Standard 1.5m Power Cord
18 months warranty
New in box
Price: RM4,999
yuenyan
Number of posts : 1386
Yaqin SD-38A Vacumm Tube CD player Empty Re: Yaqin SD-38A Vacumm Tube CD player
Post by yuenyan Thu Apr 01, 2021 8:53 am
yuenyan
Post by yuenyan Fri May 28, 2021 10:05 am
yuenyan
Post by yuenyan Wed Aug 04, 2021 9:18 am
yuenyan
Post by yuenyan Fri Oct 22, 2021 9:02 am
yuenyan
Post by yuenyan Thu Jan 20, 2022 10:11 am
yuenyan
Post by yuenyan Tue Apr 05, 2022 8:38 am
yuenyan
Post by yuenyan Fri Jun 10, 2022 8:54 am
yuenyan
Post by yuenyan Sat Aug 13, 2022 8:52 am
yuenyan
Post by yuenyan Wed Nov 16, 2022 10:18 am
yuenyan
Post by yuenyan Mon Feb 20, 2023 9:06 am
yuenyan
Post by yuenyan Sat Jun 10, 2023 8:59 am
UP
yuenyan
