Bowers & Wilkins 603+607+HTM6 S2 Anniversary Edition Speaker Package
Bowers & Wilkins 603+607+HTM6 S2 Anniversary Edition Speaker Package Brand New. Now Selling At RM16,999. Free Shipping Within West Malaysia.
The powerful 603 S2 Anniversary Edition combines the accuracy and transparency of our acclaimed Continuum mid-range cone with the scale and authority of two dedicated bass drivers. Featuring upgraded crossovers for even more transparency and a unique trim-ring to celebrate its status, the 603 S2 Anniversary Edition is the most sophisticated affordable floor-standing loudspeaker we've ever made.
A celebration of sound.
The 603 S2 Anniversary Edition is the largest and most capable loudspeaker in the 600 Series Anniversary Edition range. A floorstander designed to offer outstanding power accuracy and musicality. Perfect for larger rooms and also ideal for home theatre. Available in a new wood effect finish as well as black and white.
Layered, beautiful details.
The new 603 S2 Anniversary Edition adopts a refined and upgraded version of the proven Decoupled Double Dome tweeter, offering 38kHz breakup performance. The result? An accurate and immersive reproduction of your favourite music.
Truly amazing sound.
Voices and instruments are delivered with purity and precision, thanks to the revolutionary Continuum cone, as found in our flagship 800 Series Diamond. Once reserved for only our most revered models, Continuum brings you a cleaner and more accurate performance.
Powerful and controlled bass performance.
603 S2 Anniversary Edition features two optimised low-frequency cones that combine terrific extension and superlative accuracy to give high levels of controlled bass with your favourite music and movies.
Upgraded and optimised crossovers.
As well as celebratory cosmetic changes, 600 Series Anniversary Edition also benefits from a new optimised crossover design featuring carefully selected components, offering greater insight from your music.
Offering power and scale that belies its compact form, the 607 S2 Anniversary Edition features the Continuum cone and updated crossovers to ensure exceptional resolution and musicality. Ideal for stereo or surround sound use.
Same size, even more detail.
Ideal for smaller spaces, the 607 S2 Anniversary Edition uncovers incredible insight and dynamism in your music. Using the same game-changing technologies as its siblings, 607 S2 Anniversary Edition is perfect for enjoying your music or providing surround sound as part of a home theatre system.
The new 607 S2 Anniversary Edition adopts a refined and upgraded version of the proven Decoupled Double Dome tweeter, offering 38kHz breakup performance. The result? An accurate and immersive reproduction of your favourite music.
As well as celebratory cosmetic changes, 600 Series Anniversary also benefits from a new optimised crossover design featuring carefully selected components, offering greater insight from your music.
The HTM6 S2 Anniversary Edition small enough to fit in to convenient spaces in your home but powerful enough to partner the floorstanding 603 S2 Anniversary Edition. Offered in three finishes, it features the same crossover improvements as the others speakers in the range.
Celebrate clarity.
Powerful enough to partner with 603s and compact enough to fit with any piece of furniture, HTM6 S2 Anniversary Edition brings more realism and accuracy to your movie experience.
The new HTM6 S2 Anniversary Edition adopts a refined and upgraded version of the proven Decoupled Double Dome tweeter, offering 38kHz breakup performance. The result? An accurate and immersive reproduction of your favourite music.
Technical Specifications
Model
Description
3-way vented-box system
Features
Decoupled Double Dome aluminum tweeter
Continuum cone FST midrange
Paper bass cones
Flowport
Drive units
1x ø25mm (1 in) aluminum dome high-frequency
1x ø150mm (6 in) Continuum cone FST midrange
2x ø165mm (6.5 in) Paper bass
Frequency range
-6dB at 28Hz and 33kHz
Frequency response
48Hz - 28kHz ±3dB
Sensitivity
88.5dB spl (2.83V, 1m)
Harmonic distortion
2nd and 3rd harmonics (90dB, 1m)
<1% 90Hz - 22kHz
<0.5% 120Hz - 20kH
Normal impedance
8Ω (minimum 3.0Ω)
Recommended amplifier power
30W - 200W into 8Ω on unclipped programme
Dimensions
Height: 985mm (38.8 in) cabinet only
1055mm (41.5 in) with plinth
Width: 190mm (7.5 in) cabinet only
320mm (12.6 in) with plinth
Depth: 340mm (13.4 in)
370mm (14.6 in) with plinth
Net weight
24.1 kg (53.1 lb)
Cabinet finishes
Black, Oak
Model
Description
2-way vented-box system
Features
Flowport
Drive units
1x ø130mm (5 in) Continuum cone bass / midrange
Frequency range
-6dB at 40Hz and 33kHz
Frequency response
52Hz - 28kHz ±3dB
Sensitivity
84dB spl (2.83Vrms, 1m)
Harmonic distortion
<1% 110Hz - 22kHz
<0.5% 180Hz - 20kHz
Normal impedance
8Ω (minimum 4.0Ω)
Reccomended amplifier power
30W - 100W into 8Ω on unclipped programme
Dimensions
Height: 300mm (11.8 in)
Width: 165mm (6.5 in)
Depth: 207mm (8.1 in) cabinet only
231mm (9.1 in) including grille and terminals
Net weight
4.7kg (10.4 lb)
Cabinet finishes
Black, Oak
Grille finishes
Black, Grey
Model
Description
Features
Flowport
Drive units
2x ø130mm (5 in) Continuum cone bass / midrange
Frequency range
-6dB at 42Hz and 33kHz
Frequency response
72Hz - 28kHz ±3dB
Sensitivity
87dB spl (2.83Vrms, 1m)
Harmonic distortion
<1% 100Hz - 22kHz
<0.5% 200Hz - 22kHz
Normal impedance
8Ω (minimum 4.3Ω)
30W - 120W into 8Ω on unclipped programme
Dimensions
Height: 160mm (6.3 in)
Width: 480mm (18.9 in)
Depth: 255mm (10.0 in) cabinet only
279mm (11 in) including grille and terminals
Net weight
7.8kg (17.2 lb)
Cabinet finishes
Black, White, Oak
Grille finishes
Black, Grey
Floorstanding loudspeaker
Bookshelf speaker
Centre channel speaker
Celebrate clarity.
Model
Description
Features
Paper bass cones
Flowport
Drive units
Frequency range
Frequency response
48Hz - 28kHz ±3dB
Sensitivity
Harmonic distortion
<1% 90Hz - 22kHz
<0.5% 120Hz - 20kH
Normal impedance
8Ω (minimum 3.0Ω)
Dimensions
Net weight
24.1 kg (53.1 lb)
Cabinet finishes
Black, Oak
Model
Description
Features
Flowport
Drive units
Frequency range
Frequency response
52Hz - 28kHz ±3dB
Sensitivity
Harmonic distortion
<1% 110Hz - 22kHz
<0.5% 180Hz - 20kHz
Normal impedance
8Ω (minimum 4.0Ω)
Dimensions
Net weight
4.7kg (10.4 lb)
Cabinet finishes
Black, Oak
Grille finishes
Black, Grey
Model
Description
Features
Flowport
Drive units
Frequency range
Frequency response
72Hz - 28kHz ±3dB
Sensitivity
Harmonic distortion
<1% 100Hz - 22kHz
<0.5% 200Hz - 22kHz
Normal impedance
8Ω (minimum 4.3Ω)
Dimensions
Net weight
7.8kg (17.2 lb)
Cabinet finishes
Black, White, Oak
Grille finishes
Black, Grey
- Number of posts : 1336
» Bowers & Wilkins 607+606+HTM6 S2 Anniversary Edition Speaker Package
» Bowers & Wilkins HTM6 S2 Anniversary Edition Center Speaker
» Bowers & Wilkins 603+607+HTM6 S3 5.0 Speaker Package
» Bowers & Wilkins 603 S2 Anniversary Edition Floorstanding Speaker
» Bowers & Wilkins 606 S2 Anniversary Edition Bookshelf Speaker (Light Oak) (Pair)
