Marantz SR5015+Wharfedale D330 5.0 Home Theatre Package
Marantz SR5015+Wharfedale D330 5.0 Home Theatre Package Brand New. Now Selling At RM9,399. Free Shipping Within West Malaysia.
Package Included:
Marantz SR5015 7.2ch. 8K Atmos Network AV Receiver
Wharfedale D330 5.0 Speaker Package
Please choose your preferred Subwoofer using FREE Voucher
We accept trade in your old system
* Free Rm500 Voucher For New Subwoofer (Valid For 6 Months)
* Free QED QX075 Speaker Cable 30Meter (Free cable Not included banana plugs)
* Free Ethereal MHX-LHDME2 8K HDMI Cable 2Meter
* One voucher redeemable for each product *
* Free gift will be packed nicely in the product’s box for shipping option
* 如果需要邮寄,我们将会把赠品放进产品包装内。
Just as you would expect from any Marantz AV Receiver, the SR5015 pays extra special attention to audio quality, and it creates a highly immersive and richly detailed surround sound experience. Moreover, with the latest current feedback topology and the Marantz own-developed high-definition HDAMs, the SR5015 has both the power and the finesse to astonish and astound. Stream music from leading services, and listen to music in your whole home with HEOS Built-in.
Enjoy exquisite video performance thanks to the latest HDMI technologies such as 8K/60Hz pass-through and upscaling, various HDR format support including HDR10, HDR10+, Dolby Vision, Hybrid Log-Gamma (HLG) and Dynamic HDR. Game with better immersion thanks to 4K/120Hz pass-through, Variable Refresh Rate (VRR) and Auto Low Latency Mode (ALLM).
Extensively tuned by world-renowned sound acousticians at the most state-of-the-art facilities, the new Marantz SR5015 leverages decades of experience in Hi-Fi to drive exceptional, audiophile-quality surround sound for all your entertainment.
Key Features
Wharfedale loudspeakers have been recognized around the world for many years. Both budget and high-end products used in stereo and home cinema systems are part of the desire of enthusiasts of good sound.
Wharfedale D300 is a new line of loudspeakers included in the Diamond series. The loudspeakers use medium-low-grade Kevlar membranes and are equipped with solid, rigid and strong housings. In addition, the front speakers in the lower part are equipped with a lower bass-reflex, thanks to which the sound pressure is distributed in all directions, which allows free placement of the column in the listening room.
The bass-reflex port is separated by a metal base with spikes.
By choosing Wharfedale you choose the best sound quality in a given price range. You get a product quality guarantee based on 70 years of experience of English engineers and designers.
Marantz SR5015
Amplifier
Channels 7.2
Power Output per Channel 2-Channel Driven:
100 W at 8 Ohms / 20 Hz to 20 kHz / 0.08% THD
140 W at 6 Ohms / 1 kHz / 0.7% THD
1-Channel Driven:
200 W at 6 Ohms / 1 kHz / 10% THD
Speaker Impedance 4 to 16 Ohms
Audio Processing
DTS Compatibility DTS-HD Master Audio, DTS:X
Dolby Compatibility Dolby Atmos, Dolby TrueHD
Auro 3D Support No
Upmixing Technology Dolby Surround, DTS Neural:X, DTS Virtual:X, Dolby Atmos Height Virtualization Technology
Supported File Formats AAC, ALAC, DSD, FLAC, MP3, WAV, WMA
DAC AKM AK4458 32-Bit
Video
HDR Compatibility HDR10, HDR10+, Dolby Vision, Hybrid Log Gamma
Pass-Through Support 8K60p 4:4:4 (3D, BT.2020)
Upscaling 8K
GUI Yes
Connectivity
Rear A/V Inputs 6 x HDMI
2 x 3RCA Component
2 x RCA Composite
2 x Optical TOSLINK
2 x Digital Coaxial
4 x Stereo RCA
1 x Stereo RCA (Phono) with Ground Screw
Rear A/V Outputs 2 x HDMI
1 x 3RCA Component
1 x RCA Composite
2 x RCA Subwoofer
1 x 7-Channel RCA Pre-Out
1 x Stereo RCA Zone 2 Pre-Out
Front I/O 1 x USB Type-A Input
1 x RCA Composite Input
1 x Stereo RCA Input
1 x 1/8" / 3.5 mm Setup Mic Input
1 x 1/4" / 6.35 mm Headphone Output
Other Rear I/O 2 x Bluetooth/Wi-Fi Antenna Terminal Input
1 x AM Antenna Terminal Input
1 x FM Antenna Terminal Input
1 x RJ45 (Ethernet)
1 x DE-9 (RS-232C)
1 x 1/8" / 3.5 mm (12 V Trigger) Output
1 x 1/8" / 3.5 mm (IR) Input
1 x RCA (IR) Input
1 x RCA (IR) Output
Speaker Connectors 7 x Binding Post Pairs
HDCP Support Version 2.3
Audio Return Channel (ARC) Yes, eARC
HDMI CEC Yes
Wireless Connectivity
Wireless Audio Protocols AirPlay 2, HEOS
Control
External Control Support Domotz Pro, OvrC
Virtual Assistant Support Amazon Alexa, Apple Siri, Google Assistant, Josh.ai
Tuner Section
Tuner Type AM, FM
Power
AC Input Power 240 VAC,50/ 60 Hz
Power Consumption Active: 650 W
No Sound (ECO Off): 75 W
No Sound (ECO On): 45 W
Network Standby: 2.7 W
CEC Standby: 0.5 W
Standby: 0.2 W
Physical
Dimensions (W x H x D) 17.3 x 6.3 x 13.7" / 43.9 x 16.0 x 34.8 cm (Antenna Down)
17.3 x 9.1 x 13.7" / 43.9 x 23.1 x 34.8 cm (Antenna Up)
17.3 x 6.3 x 13.3" / 43.9 x 16.0 x 33.8 cm (Antenna Removed)
Weight 22.3 lb / 10.1 kg
Wharfedale D330 - front speakers
Design: 3-way, bass-reflex
Frequency range: 40Hz ~ 20kHz
Woofer: 130mm, Kevlar
Midrange driver: 130mm, Kevlar
Tweeter: 25mm, dome
Effectiveness: 88dB
Recommended amplifier power: 25-120W
Impedance : 4-8 Ohm
Dimensions (H x W x D): 965mm (with spikes and base) x 200mm x 338mm (with base)
Weight: 18.2 kg / pcs.
Wharfedale D300C - center speaker
Construction: 2-way, bass-reflex
Tweeter: 25mm, dome
Efficiency: 89dB
Impedance: 4-8 Ohm
Frequency range: 65Hz ~ 20kHz
Dimensions (W x S x G ): 190 x 510 x 232mm
Weight: 8 kg
Wharfedale D310 - surround speakers
Woofer: 100m, Kevlar
Tweeter: 25mm, dome
Dome : 65Hz ~ 20kHz
Efficiency: 86dB
Recommended amplifier power: 20-60W
Impedance: 4-8Ohm
Dimensions (H x W x D): 265 x 155 x 228mm
Weight: 4 kg / pc.
Package Included:
Marantz SR5015
7.2ch. 8K AV Receiver with 3D Sound and HEOS Built-inJust as you would expect from any Marantz AV Receiver, the SR5015 pays extra special attention to audio quality, and it creates a highly immersive and richly detailed surround sound experience. Moreover, with the latest current feedback topology and the Marantz own-developed high-definition HDAMs, the SR5015 has both the power and the finesse to astonish and astound. Stream music from leading services, and listen to music in your whole home with HEOS Built-in.
Key Features
- Performance, power and connectivity to suit your audio preferences:7.2 channel discrete power amplifier, 180W per channel.
- 8K/60Hz and 4K/120Hz pass-through support for every entertainment need:With the latest technology in HDMI support, enjoy 8K quality video from your 8K source devices or with 8K upscaling from Full HD or 4K sources.
- Support for the most advanced three-dimensional audio formats:Dolby Atmos, Dolby Atmos Height Virtualization Technology, DTS:X and DTS Virtual:X processing are all supported to allow you to listen to immersive, multi-dimensional audio.
- Enhanced Audio Return Channel (eARC) HDMI support:Through the main HDMI output, connect your TV with eARC HDMI support to allow uncompressed and object-based audio formats like Dolby Atmos and DTS:X directly from a smart TV app to your AV receiver.
- The greatest technology for home cinema:Support for the latest HDR formats including HDR10, HDR10+, HLG, Dolby Vision, 4:4:4 colour resolution and BT.2020, as well as Dynamic HDR provides exceptional picture quality for brightness, clarity and contrast.
- Advanced gaming specifications:With 4K/120Hz pass-through, Variable Refresh Rate (VRR), Auto Low Latency Mode (ALLM) and Quick Frame Transport (QFT), experience gaming thrills with amazing imaging and reduced lag.
- High-resolution streaming for audiophile approved sound:Play back ALAC, FLAC and WAV lossless files up to 24-bit/192-kHz as well as DSD 2.8MHz and 5.6MHz tracks, and enjoy your music exactly as the artist intended.
- Exclusive components elevate the Marantz sonic signature:Marantz proprietary HDAM circuit boards, Current Feedback circuitry, AKM AK4458 32-bit D/A converters, and Hybrid PLL Clock Jitter Reducer produce more detailed, dynamic sound.
- Almost unlimited music sources:Stream from music services like Spotify Free and Premium, Amazon Music HD, Tidal and more, or stream directly from smart devices via AirPlay 2 or Bluetooth
- Features HEOS Built-in and the free HEOS App:Your key to digital music streaming, multi-room audio and voice control throughout your entire home.
- Supports all your favourite voice assistants:With the SR5015, simply use your voice to control your preferred voice assistant like Amazon Alexa, Google Assistant and Apple Siri.
Marantz SR5015
Amplifier
Channels 7.2
1-Channel Driven:
Audio Processing
Auro 3D Support No
Video
Upscaling 8K
GUI Yes
Connectivity
2 x 3RCA Component
2 x RCA Composite
2 x Optical TOSLINK
2 x Digital Coaxial
4 x Stereo RCA
1 x 3RCA Component
1 x RCA Composite
2 x RCA Subwoofer
1 x RJ45 (Ethernet)
1 x DE-9 (RS-232C)
1 x RCA (IR) Input
1 x RCA (IR) Output
HDMI CEC Yes
Control
Tuner Section
Tuner Type AM, FM
Power
CEC Standby: 0.5 W
Standby: 0.2 W
Physical
Tweeter: 25mm, dome
Effectiveness: 88dB
Impedance : 4-8 Ohm
Tweeter: 25mm, dome
Efficiency: 89dB
Impedance: 4-8 Ohm
Weight: 8 kg
Tweeter: 25mm, dome
Dome : 65Hz ~ 20kHz
Efficiency: 86dB
Impedance: 4-8Ohm
Weight: 4 kg / pc.
- Number of posts : 1318
» Yamaha RX-A2A+Wharfedale D330 5.0 Home Theatre Package
» Onkyo & Jamo 5Ch Home Theatre Package
» Marantz NR1711+ Monitor Audio Mass 2G 5.1 Home Theatre Package
» Wharfedale D330 + D310 + D300C Speaker Package (Sold Out)
» Yamaha RX-V6A+Taga Harmony TAV-806 5.0 Home Theatre Package
