Denon AVR-X550BT+ Monitor Audio Mass 2G 5.1 Home Theatre Package
Denon AVR-X550BT+ Monitor Audio Mass 2G 5.1 Home Theatre Package Brand New. Now Selling At RM6,199. Free Shipping Within West Malaysia.
AWARDS
MASS is quick and easy to set up and delivers genuinely enthralling surround sound excitement in a compact design, making any room feel like a state-of-the-art concert hall or cinema.
Music lovers, movie fans and gamers will all revel MASS’s ability to put them in the middle of the action, bringing incredible levels of immersion to their favourite songs, films and games. All the clarity, all the drama, all the 360-degree thrills - and a new acoustic experience - are there to be enjoyed.
MASS Movies –
Hollywood knows its soundtracks are just as big a part of the cinema experience as its pictures – and, thanks to MASS, you can enjoy your own full-on home cinema surround sound experience without breaking the bank or compromising the look of your room. Despite its size, MASS is capable of dynamic, room-filling sound with all the punch and drive the biggest Hollywood blockbusters demand. With perfect clarity to build the tension in quieter scenes, hair-raising attack when the going gets explosive, and incredible effects placement to keep you at the heart of the story, MASS brings you the authentic cinema experience.
MASS Gaming –
If you want to properly immerse yourself in your gaming experience, there’s no better way than MASS to put you right in the thick of the action. Gaming is hugely enhanced by accurate placement of effects, seamless panning right around the 360-degree soundfield and, thanks to the Subwoofer, incredible low-frequency presence. No matter if your favourite games rely on the roar of the crowd, the rattle of the guns or the tension-packed near-silence of a spooky alien planet, MASS gives you more of what you need. Enjoy every gaming scenario like never before and take your experience to an entirely different level.
MASS Music –
Whether you like to listen in stereo or prefer a multi-channel mix, MASS has the talent to bring your favourite music to life. Thanks to the beautifully engineered integration between the Satellites and the Subwoofer, MASS is a thrilling listen from the deepest bass notes to the crispest treble. Incredible stereo imaging puts your favourite singer on the centre of the stage, while the combination of MMP II driver technology and soft dome tweeter in each Satellite gives each instrument extraordinarily faithful and convincing tonality. Fast, controlled and, above all, deep bass from the Subwoofer makes MASS as powerful and punchy a listen as it is subtle and detailed. It’s the speaker system your music has been waiting for.
3/4" (19 mm) soft dome tweeter with thermal protection
Integrated stand-mount point and wall bracket (compatible with MASM bracket)
Rear cover concealing binding posts
MASS Subwoofer
Denon AXR-X550BT
Power Output - Watts per CH 70 x 5
Active Subwoofer Output Yes
Analogue Input 2
Audio Inputs 2
Bluetooth Yes
Channels 5.2
Coaxial Inputs No
Coaxial Outputs No
Component No
Dimensions WxDxH 434 x 319 x 151
DLNA Compliant No
Dolby Atmos No
Dolby ProLogic Surround No
DTS No
Dolby TrueHD Yes
Dolby Digital Plus Yes
Eco Friendly No
Freq Response (Hz) 10 - 100,000Hz
HDMI Audio Yes
HDMI text 5 in/1 out
HDMI Zone Out No
HDR Compatible HDMI Yes - 3 in/1 out
Headphone Output Yes
Internet Radio Services No
Multi Channel Input No
Multiroom No
NFC No
Optical Digital Inputs 2
Optical Inputs 2
Optical Outputs No
Power Consumption- Normal Use 310
Power Consumption - Standby 1
Remote Control yes
App Control Yes
Sub Output 2
Tuner Radio FM/AM
USB 1
USB Input 1
Weight (KG) 8
Wireless Connection No
Brand Denon
Colour Black
MASS Satellite
System Format
2-Way
Frequency Response (-6 dB)
105 - 34,000 Hz
Sensitivity (1W@1M)
80 dB
Nominal Impedance
8 ohms
Minimum Impedance
4.4 ohms @ 300 Hz
Maximum SPL
98 dB (Pair)
Power Handling (RMS)
30 W
Power Handling (RMS) With Amplifier Crossover (150 Hz)
70 W
25 – 100 W
Bass Alignment
Sealed Enclosure
Crossover Frequency
3.0 kHz
Drive Unit Complement
1 x 31/2" (89 mm) MMP II Mid-Bass Driver
1 x 3/4" (19 mm) Soft Dome Tweeter
External Dimensions (Including Grille and Terminals (H x W x D)
147 x 122 x 107 mm (513/16 x 413/16 x 43/16")
Weight (each)
1.12 kg (2 lb 8 oz)
MASS Subwoofer
System Format
Sealed cabinet, 15 mm MDF construction with 18 mm base and front baffle
Internally braced with sealed amplifier compartment
Lower Frequency Limit
-3 dB @ 35 Hz / -10 dB @ 30 Hz (Free Field)
Default preset: Music, -3 dB @ 34 Hz / -10 dB @ 25 Hz (In Room)
Upper Frequency Limit
-6 dB @ 150 Hz
1 x 8" (200 mm) MMP II subwoofer driver featuring a 2" long throw voice coil
Linear Driver Excursion
15 mm Peak to Peak
Amplifier Output
120 W
Amplifier Classification
Class D with high current Switch mode power supply (SMPSU)
Phase Control
0 Degrees & 180 Degree pure Invert
Low Pass Filter Alignment
2nd order (12 dB/Octave), from 50 Hz to 150 Hz
Auto Sensing Input Requirements
Line Level >3 mV Auto Standby feature after 20 minutes
Audio Input/Outputs
LFE unbalanced input RCA
Stereo unbalanced inputs RCA
Connection
12 V Trigger in (3.5 mm mono mini-jack, 4v threshold)
Electrical Certifications
CE / CB/ ETL / Fcc / CCC/ ErP (Energy saving compliant)
Mains Input Voltage
100 – 240 Vac, 50/60 Hz
Power Consumption
Maximum 130 W, Standby <0.5 W (ErP compliance)
Fuse Type
20 mm T8AL 250VAC
External Dimensions (Including Amp, Drivers and Terminals (H x W x D)
340 x 320 x 350 mm (133/8 x 125/8 x 133/4")
External Dimensions (Including Amp, Drivers, Terminals and Feet (H x W x D)
359 x 320 x 350 mm (141/8 x 125/8 x 133/4")
Weight (unpacked)
10.2 kg (22 lb 8 oz)
Denon AXR-X550BT
Overview
The 5.2 channel Denon AXR-X550BT AV receiver delivers quality home theater at an accessible price. Watch your favorite movies and shows with exceptional picture clarity thanks to Full 4k Ultra HD, Dolby Vision and HDCP 2.2 (supported on three of the five HDMI inputs). Stream music with built-in Bluetooth or play back MP3, WMA, FLAC and MPEG-4/AAC tracks via the front panel USB port. A guided Setup Assistant and measuring microphone make getting started as simple as possible. And with a more than 100-year history steeped in audio technology, the Denon AVR-X550BT is guaranteed to provide audio fidelity and picture clarity to vastly improve every aspect of your home theater.概述
5.2声道Denon AXR-X550BT AV接收机以能承受的价格提供高品质家庭影院。采用全4K超高清、Dolby Vision和HDCP 2.2(HDMI输入支持),让您欣赏到画面异常清晰的电影和节目。使用内置蓝牙串流播放音乐,或者通过前面板USB接口播放MP3、WMA、FLAC和MPEG-4/AAC曲目。向导式设置助手和测量麦克风使入门尽可能简单。此外,100多年浸淫在音频技术的历史,可确保Denon AVR-X550BT提供的音频保真度和画面清晰度大幅改善家庭影院的方方面面。Monitor Audio MASS 5.1
Designed to deliver full-scale audio fidelity from compact, stylish speakers and a discreet subwoofer, MASS combines all Monitor Audio’s award-winning expertise with sophisticated looks. The result is a new level of performance for music, gaming and movie sound alike.AWARDS
MASS Movies –
MASS Gaming –
MASS Music –
Key Features
MASS Satellite- Two-way, sealed cabinet, tuned for wide dispersion and optimal integration with MASS Subwoofer
- Rigid, braced and fibre-reinforced cabinet
- Custom-weave cloth finish, unique to Monitor Audio
- Compact design, with point-source acoustic alignment for precise audio focus and response
- 31/2" (89 mm) Mid-Bass driver featuring;
- – MMP II (Metal Matrix Polymer) cone technology
- – Advanced FEA simulation used to optimise the cone & motor unit performance
MASS Subwoofer
- Compact, sealed enclosure with braced 15 mm MDF construction and rigid 18 mm MDF baffle
- Custom-weave cloth finish grille
- 8" (203 mm) long-throw driver with MMP II cone
- 120 W Class-D amplification for efficient, powerful performance
- Digital Sound Processing DSP providing accurate filter characteristics
- Advanced limiters guarantee controlled, authentic sound
- 3 pre-set modes (‘Music’, ‘Movie’, ‘Impact’) for superlative acoustics
Denon AXR-X550BT
Analogue Input 2
Audio Inputs 2
Bluetooth Yes
Channels 5.2
Coaxial Inputs No
Coaxial Outputs No
Component No
DLNA Compliant No
Dolby Atmos No
DTS No
Dolby TrueHD Yes
Eco Friendly No
HDMI Audio Yes
HDMI Zone Out No
Multiroom No
NFC No
Optical Inputs 2
Optical Outputs No
Remote Control yes
App Control Yes
Sub Output 2
Tuner Radio FM/AM
USB 1
USB Input 1
Weight (KG) 8
Brand Denon
Colour Black
MASS Satellite
System Format
2-Way
105 - 34,000 Hz
Sensitivity (1W@1M)
80 dB
Nominal Impedance
8 ohms
Minimum Impedance
4.4 ohms @ 300 Hz
Maximum SPL
98 dB (Pair)
30 W
70 W
25 – 100 W
Bass Alignment
Sealed Enclosure
Crossover Frequency
3.0 kHz
Weight (each)
1.12 kg (2 lb 8 oz)
MASS Subwoofer
System Format
-6 dB @ 150 Hz
15 mm Peak to Peak
Amplifier Output
120 W
Phase Control
Audio Input/Outputs
Connection
Mains Input Voltage
Power Consumption
Fuse Type
20 mm T8AL 250VAC
Weight (unpacked)
- Number of posts : 1318
» Denon AVR-S660H + Monitor Audio Mass 2G 5.1 Home Theatre Package
» Denon AVR-S960H + Monitor Audio Mass 2G 5.1 Home Theatre Package
» Marantz NR1711+ Monitor Audio Mass 2G 5.1 Home Theatre Package
» Denon AVR-S960H + Taga Harmony TAV-606 V.3 5.0 Home Theatre Package
» Monitor Audio Mass 2G 5.1 Home Theater System
