Pro-Ject Amp Box S2 Stereo Power Amplifier (Used)
Pro-Ject Amp Box S2 Stereo Power Amplifier (Used) Empty Pro-Ject Amp Box S2 Stereo Power Amplifier (Used)
Post by choyaudiovisual Fri Apr 08, 2022 4:49 pm
Pro-Ject Amp Box S2 Stereo Power Amplifier (Used) Img_7674
Pro-Ject Amp Box S2 Stereo Power Amplifier (Used) Img_7673
Pro-Ject Amp Box S2 Stereo Power Amplifier (Used) Img_7672
Pro-Ject Amp Box S2 Stereo Power Amplifier (Used) Img_7676
Pro-Ject Amp Box S2 Stereo Power Amplifier (Used) Img_7675
The new Amp Box S2 offers one stereo RCA input and delivers powerful and room-filling sound to every loudspeaker. The aimed sound characteristics of this power amplifier was the one of tube power amplifiers, with their lush, rich and musical sound with an analogue touch of warmth. Amp Box S2 is ultra compact and allows for easiest placement in every listening room and can be turned on and off remotely via the trigger sockets. For Bi– or Tri-amplification you can use the trigger outputs to connect further power amplifiers. Amp Box S2 comes in a luxurious design with a stable housing made of aluminium/metal, which effectively protects against interferences and vibrations!
Features
  • Ultra compact & audiophile
  • advanced amplifier module
  • More power and further improved performance
  • Stereo input (RCA)
  • Isolated speaker sockets
  • Suitable for banana/spade/pin/bare wire
  • Trigger input
  • Trigger output for further Amp Box S2
  • Metal casing protects against vibration and interference
  • On/Off front-sided
Power output
2 x 23 W / 35 W at 8 ohms/4 ohms (both channels driven)
Frequency response
5 Hz - 20 kHz (+ 0.2 dB, - 0.2 dB)
Channel separation
>-55dB bei 20kHz
Noise floor
>-100dBA
THD
<0.18% bei 10 W
Gain
31 dB
Pre in
1 pair RCA/phono sockets
Bypass Output
Jack socket 3,5mm stereo
Input sensitivity
330 mV
Input impedance
20 kohms
Speaker connectors
4 mm banana plugs, spades connectors or naked wire
Trigger
12V DC switching voltage, 2-pole co-axial, 2.5mm co-axial jack
Outboard power supply:
20V/3A DC (peak 7A DC), suitable for your country's mains supply
Power consumption
3A DC, <1W in standby
Dimensions W x H x D with sockets
103 x 37 x 136 mm
Weight
385 g without power supply
Conditions: 9.5/10 (USED)
Price: RM850 inclusive postage to West Malaysia
Last edited by choyaudiovisual on Fri May 27, 2022 8:53 am; edited 1 time in total
Number of posts : 5281
Pro-Ject Amp Box S2 Stereo Power Amplifier (Used) Empty Re: Pro-Ject Amp Box S2 Stereo Power Amplifier (Used)
Post by choyaudiovisual Tue Apr 26, 2022 8:42 am
Post by choyaudiovisual Fri May 27, 2022 8:54 am
Post by choyaudiovisual Sat Jun 25, 2022 8:38 am
Post by choyaudiovisual Wed Jul 20, 2022 9:23 am
Post by choyaudiovisual Fri Aug 19, 2022 9:14 am
Post by choyaudiovisual Wed Sep 28, 2022 11:49 am
Post by choyaudiovisual Wed Oct 26, 2022 1:15 pm
Post by choyaudiovisual Thu Dec 08, 2022 8:46 am
Post by choyaudiovisual Fri Jan 13, 2023 9:41 am
Post by choyaudiovisual Thu Mar 02, 2023 10:23 am
