HDMI Audio Extractor Splitter 4 in 2 out HDCP2.2 HDR 4K 60Hz ARC (Used)
Usual price RM499, reason for sale because upgrade to new AV receiver with more HDMI port.
Conditions: 9.5/10 (USED)
Price: RM250
Item Sold.
This extractor / splitter can support 4 HDMI input signals. It then makes it possible to separate the video stream from the audio stream, keeping the encodings. Video output is 4K 60hz compatible with HDR and Dolby Vision support. The HDMI audio output allows DTS-HD, Dolby True HD and other signals to be passthrough.
This allows, among other things, to separate the stream to be able to play 4K HDR movies with HD sound on a home cinema amplifier that does not manage 4k HDR.
TV ARC signal is supported for output to optical or headphone port only.
The HDMI audio stream can also be routed to the optical (5.1 max) or headphone port.
It also complies with the HDCP 2.2 standard. Finally, a remote control allows it to be controlled from a distance.
Beware though, it does not support CEC.
SPECIFICATIONS
Product type HDMI extractor / switch
Inputs 4x HDMI
Outputs 1x HDMI (ARC compatible)
1x HDMI (audio only)
1x Optical Toslink
1x Jack 3.5mm headphone output
Supported video resolutions
4K @ 60Hz
4K @ 30Hz
1080p
720p
480p
ARC function Supported
HDMI Audio formats DTS-HD, Dolby TrueHD, LPCM 7.1, DTS, Dolby AC3, DSD Color
Bit depth (video) 8/10/12bit @ 1080p
8bit @ 2160p
Audio output formats LPCM 2.0
DTS
Dolby AC3
Maximum usable cable length (@ 26AWG, HDMI 2.0) 2160p : < 5m
1080p : < 10m
Supported audio sampling rates PCM up to 24bit 192kHz
HDMI Transmission bandwidth 25~600MHz
HDMI Transmission speed 0.75~18Gbps
General
Supply voltage 5VDC 1A (power supply included)
Operating temperature range 0°C ~ +40°C
Dimensions 205 x 74 x 26mm
Weight 350g
Color Black
Package 1x HDMI switch
1x Power supply
1x IR Remote control
Price: RM250
Item Sold.
SPECIFICATIONS
Inputs 4x HDMI
1x Optical Toslink
4K @ 60Hz
4K @ 30Hz
1080p
720p
480p
8bit @ 2160p
DTS
Dolby AC3
1080p : < 10m
General
Weight 350g
Color Black
1x Power supply
akinishi- New Member
- Number of posts : 4
Registration date : 2022-04-20
» Egreat H10 4K HDR HDMI 2.0a Audio & Video Splitter
» HDMI 2.0 Cable UHD 4K@60Hz HDR (5m) [SOLD]
» HDMI Splitter (New)
» (WTS)-HDMI Splitter/Switcher (New)
» 1 to 2 output HDMI Splitter [NEW]~ SOLD~
