Quad 909 Power Amplifier
Quad 909 Power Amplifier Empty Quad 909 Power Amplifier
Post by thtiong Sat Dec 31, 2022 3:53 pm
Quad 909 Power Amplifier Quad_911
Description
The Quad 909 is a two channel power amplifier using current dumping technology.
It weighs approximately 12kg and is built to be robust.
The performance of the 909 amplifier is as accurate as it is possible to achieve by careful design, selection of components and rigorous test procedures.
The unit has no controls other than a power switch (which is normally left on) and may be mounted out of sight in a cabinet or other convenient location.
To keep BUS connections simple you can place the unit below the 99 preamplifier.
Power amplifiers can be placed alongside or out of sight using a long 99 AMPBUS cable.
The amplifier is full compatible with the ESL-63, ESL-988 and ESL-989 loudspeakers but it should not be used with the earlier model ESL which could be damaged by signal peaks unless a protection circuit is fitted in the loudspeaker.
Power output: 140 watts per channel into 8Ω (stereo)
Frequency response: 13Hz to 40kHz
Total harmonic distortion: 0.01%
Input sensitivity: 0.775V
Signal to noise ratio: 108dB
Dimensions: 321 x 140 x 240mm
Weight: 12kg
Selling price : RM4000
Condition : 8/10
Contact : 0195106057
thtiong
Regular
Regular
Number of posts : 88
Registration date : 2019-06-07
Quad 909 Power Amplifier Empty Re: Quad 909 Power Amplifier
Post by thtiong Sat Jan 28, 2023 4:07 pm
BUMP
thtiong
Regular
Regular
Post by thtiong Tue Mar 07, 2023 11:13 am
thtiong
Regular
Regular
Post by thtiong Sat Mar 18, 2023 4:26 pm
thtiong
Regular
Regular
