Copper Litz multi-strand speaker cable Euphorix Hex
Greetings all,
Introducing Euphorix Cables; assembled in Malaysia with imported components.
Design highlights:
True litz: Made with vintage Japanese Litz cables. Thin individual strands are enameled but not cased in plastic or other insulators.
Multi-strand: Each positive and negative run comprises 432 strands each adding up to a mind-boggling 864 strands per side! In comparison, the popular Kimber 8TC has 16 strands.
Ultra-thin strands: Individual strands are ultra-thin in order to reduce skin effect.
Litz weave: The strands are woven to continuously cross each other at right angles.
Flat impedance curve: Measurements published by Nelson Pass shows that the raw cable has near-flat impedance curve.
Separate positive and negative runs: Separate runs are used for positive and negative side.
PTFE and air as dielectrics: Designed with PTFE tube as dielectric and damper. Effectively makes the inner dielectric almost entirely air (best dielectric material after vacuum).
World class parameters: Here is the measured performance of the Euphorix Hex.
Measurements does not determine the sound quality of cable but measurements are important as part of rigorous design.
The sound: I am no reviewer but the key quality of Euphorix Hex is clarity (transparency). So much so that originally I wanted to name my brand "Clarity Cable" but that name was taken!.This is cable has the best measured parameters and subjective performance among my three designs.
Review: Here is a review of my cables done by local blogger elhefe. Review of Euphorix cables was published on Monday 12th December 2022.
I am really grateful for a professional reviewer taking time to review a Malaysian made cable design by a local non-entity.
Test drive: You can drop by at my place in Cyberjaya to audition the cables. And you can bring your own cables (and amplifiers/speakers if you don't mind the hassle of bringing them upto the 25th floor )
Loaner and return policy: I have a 1.9m loaner pair if you would like a home trial. You can return the cable within 40 days for a full refund. No questions asked (unless you damage the cable ) and we remain friends. I must be the only cable seller in Malaysia who offers a return policy.
Custom made: Your cables will be custom made to your required length and terminated with your choice of connectors (Banana/spade and your preferred brand). Custom made cables are NOT returnable.
Lifetime first buyer Warranty: All cables sold will be repaired or replaced if they develop any defect due to poor quality materials or workmanship for life. This warranty is for the first buyer.
Price: As the cable is custom made to your requirement, the price varies.
The price of the 1.9m loaner pair of Hex with WBT0610Cu and WBT0681Cu connector is RM 6150.
Introductory offer: 20% discount for the first three cables sold.
Contact: Please WhatsApp or call +60 one one 55842 seven eight six for photos and more information.
My website is still under construction.
Models: This model (Hex) is my reference model. I do have two other models, Twin and Tube Master. Please see my other posts.
Thank you for visiting.
Design highlights:
Cable name | Capacitance | Inductance |
Euphorix Hex | 27 pF/m | 0.89 uH/m |
Cardas Cross Kenkraft labs Zeus Kimber 8TC QED Performance | 35-735 pF/m | 0.12-0.75 uH/m |
Euphorix Hex DC Resistance is 1.75 m Ohm/m. | ||
DC resistance of the above cables range between 1-15 m Ohm/m | ||
As you can see the measured parameter are comparable or better than these high-end cables. | ||
Item | Price RM | Comments |
Euphorix Hex per meter pair (order in multiples of 0.1m) | 2500 | Custom made |
Generic spade or banana (China) | 100 | Audiocrast or similar from Aliexpres |
Furutech FP202 Rhodium (Japan) | 900 | Purchased from local agent |
Furutech FP203 Rhodium (Japan) | 760 | " |
WBT 0610Cu banana (Germany) | 1400 | Purchased from Singapore/Taiwan agent |
WBT 0681Cu spade (Germany) | 1400 | " |
Last edited by euphorix on Thu Jan 12, 2023 3:50 pm; edited 8 times in total (Reason for editing : added comparison measurements)
euphorix- New Member
- Number of posts : 7
Registration date : 2023-01-01
Re: Copper Litz multi-strand speaker cable Euphorix Hex
Jump six times...
Thank you elhefe
Thank you elhefe
» Copper Litz multi-strand speaker cable Euphorix Twin
» Copper Litz multi-strand speaker cable Euphorix Tube Master
» Audio Note LEXUS 42 strand high purity copper Litz interconnect cable 1.5m
» Sold - Audio Note ISIS Reference copper litz interconnect RCA cable. (Used)
» Qed 42 Strand Speaker Cable ( NEW )
