Audia Flight Pre and Power amp (Demo set)
Audia Flight Pre and Power amp (Demo set) Empty Audia Flight Pre and Power amp (Demo set)
Post by CentreCircle Wed May 17, 2023 4:44 pm
Audia Flight Pre and Power amp (Demo set) Image011Audia Flight Pre and Power amp (Demo set) Image113
F L S 1 - Stereo, full balanced preamplifier with headphone amplifier
Preliminary Technical Data
Inputs: 3 unbalanced (RCA), 2 balanced (XLR)
Outputs: 1 unbalanced (RCA), 1 balanced (XLR), 1 REC unbalanced (RCA)
Gain range: -90dB / +10dB
Gain resolution: 0,5dB
Frequency response (-3dB): 0,3 Hz ÷ 500 KHz
THD: < 0,05 %
S/N Ratio: 110 dB
Input impedance: 47 Kohm
Output impedance: < than 1 ohm
Headphone output power per channel: 12W Wrms on 8 ohm, 10Vrms
Main voltage AC (50-60Hz): 100, 110-115, 220-230, 240 V
Stand-by power consumption: less than 1 W
Power consumption: 50 W
Dimensions and weigth: 450x120x380mm (wxhxd) - 11Kg
FLS4 Stereo Power Amplifier
Output power per channel Watts RMS @ 8/4/2 Ohm 200/380/700W*
Gain 29 dB
Input sensitivity 1.41 Volts RMS
Frequency response (1W RMS -3dB) 0,3 Hz ÷ 0,7 MHz
Slew-Rate (@ 8 Ohm) > 160 V/µS
THD< 0,05 %
S/N Ratio110 dB
Input impedance Unbalanced 7,5 kOhm
Balanced 7,5 kOhm
Damping factor (@ 8 Ohm)> 650
Main voltage AC (50-60Hz)100, 110-115, 220-230, 240 V
Stand-by Power consumption less than 1W
Nominal Power consumption (no signal)170W
Power consumption (200W RMS @ 8 Ohm both channels) 840W
Dimensions and weight 450x180x440mm (W x H x D) - 34kg
RM 32,000
Condition 8/10
Contact Method / details :Call 03-77282686 or WhatsApp +6018-9882686
(Mon-Sat 10am-6.30pm)
CentreCircle
Number of posts : 98
Registration date : 2017-09-11
http://info@centrecircleaudio.com.my
