Cyrus Audio XPA Power Amplifier
Cyrus Audio XPA Power Amplifier Empty Cyrus Audio XPA Power Amplifier
Post by raymond88 Mon Jun 05, 2023 2:31 pm
Item: Cyrus Audio XPA Power Amplifier
Condition: Item is in very good working condition. Comes with power cable
Price: RM1900 or swap/topup
Cyrus Audio XPA Power Amplifier Cyrusx10
Cyrus Audio XPA Power Amplifier Cyrusx11
The X Series may have the footprint of a shoebox, but is the Cyrus's flagship range of power amps capable of serious power, and can kick out seismic bass like no other.  The Cyrus XPA is an exceptionally versatile power amplifier with outstanding performance. In a basic installation the XPA is an extraordinary 50W/Ch stereo power amplifier with an unrivalled level of performance.   The quality lightweight die-cast enclosure of Cyrus XPA has a myriad of advantages both electrically and mechanically. The integrated heatsink design enhances the thermal efficiency allowing higher performance to size ratio.  Additionally, the non-resonant nature of the alloy minimises microphonic effects, while its non-ferrous composition provides an effective shield from external electro-magnetic disturbances. This also eliminates coupling of the power transformer stray magnetic fields to the sensitive audio circuitry.
Electrical
Inputs – RCA
Outputs – Loudspeakers and also line level chain out
Power Supply – 180VA Toroidal transformer, running 230AC
Switch-on – Auto switch-on sensing with input signal
Continuous Power – 50W/CH (both driven into 8 Ohms) 70W/CH (both driven into 4 Ohms)
Distortion – <0.004%, (1kHz into 8 Ohms) <0.01%, (20Hz-20kHz into 8 Ohms)
Frequency Response - -3 dB at 1Hz and 80kHz
Current – 30 Amps peak to peak
Sensitivity (RCA input) – 380mV (for 50W stereo into 8 Ohms)
Input impedance – 10Kohm (RCA)
Output voltage – 380mV (Chain out)
S/N Ratio – 110dBA
Dimensions – (H x W x D) 73 x 215 x 360 (mm)
Weight – 4.6kg
Number of posts : 9647
Cyrus Audio XPA Power Amplifier Empty Re: Cyrus Audio XPA Power Amplifier
Post by raymond88 Tue Jun 13, 2023 2:25 pm
Post by raymond88 Tue Jun 20, 2023 9:29 am
Post by raymond88 Wed Jun 28, 2023 9:33 am
