Cambridge Audio Azur 540A V2 integrated amplifier.
Cambridge Audio Azur 540A V2 integrated amplifier. Empty Cambridge Audio Azur 540A V2 integrated amplifier.
Post by chkl026 Sun Jul 02, 2023 2:11 pm
Up for sale 1 unit of Cambridge Audio 540A integrated amplifier.
Condition :8/10,  no box no manual. Only the integrated amp with a working remote control. This is an updated model of 540a which has 60w @ 8Ohms and upgraded power circuit design at the back panel. It has been test run in my environment for sometimes with no issues encountered.
Asking : SOLD
Please refer to specs below and scroll down for photos of real item.
Thank you.
Cambridge Audio Azur 540A v2 Specifications:
Power Output:
60 watts (into 8Ω)
90 watts (into 4Ω)
THD (unweighted)
Less than 0.002% at 1 kHz, of rated power
Less than 0.070% from 20Hz - 20 kHz, of rated power
Less than 0.025% from 20Hz - 20 kHz at 10 W
Frequency Response:  5 Hz - 50 kHz (-1 dB)
Signal-to-Noise Ratio (ref 1w):  better than 85 dB
Input Impedances:  47 k Ω
Power Amp Damping Factor:   better than 100 W
Max Power Consumption:  650 W
Min/On Power Consumption:  less than 35 W (no signal)
Standby Power Consumption:  less than 10 W
Bass/Treble Controls:  Shelving, ultimate boost/cut  ±7.5 dB (at 20 Hz and 20 kHz)
Dimensions (W x H x D): 430 x 100 x 310 mm (16,9 x 3.9 x 12.2”)
Weight:  7.4 kg (16.3 lbs)
StereoNoMono
AudioReview
Last edited by chkl026 on Mon Aug 28, 2023 10:38 am; edited 1 time in total (Reason for editing : sold)
chkl026
Number of posts : 109
Registration date : 2009-09-22
