Pass Labs XP17 class A phono preamp
Pass Labs XP-17 single ended class A phono preamplifier with balance input / output.
Ready stock . Brand new.
Exclusively in perfect hifi amcorp mall.
Please whatsapp me for more info. Cheers.
017-6101363 - Calvin
Or visit me at :
Lot 1-30, 1st Floor, Amcorp Mall No. 18, Jalan, Persiaran Barat, Petaling Jaya, Malaysia
Pass Labs XP17
XP17 uses the new-shielded low noise toroid and input filter module, like the XP-12. The power supply has an extra stage of RC filtering. We have lower radiated and mechanical noise.
The XP17 has an all-new input circuit that is symmetrical and lower in noise and distortion with greater drive capability. Noise is the most prominent part of THD+N in the first section of a phono stage. By lowering noise we get better resolution and dynamics.
Designed with a split EQ network like the XP 25 and XS Phono that is more accurate and can handle greater signal levels.
The secondary stage runs a higher bias output stage with auto bias.
The numerous loading options from the XP-15 are all still available and three gain settings to accommodate low output MC to MM cartridges.
Power Consumption = 35 Watts
Gain = 76, 66, 56 dB Balanced; 70, 60, 50 Unbalanced
Output Impedance = 110 Ohms RCA; 220 Ohms Balanced
Input Impedance = 10 = 47K Ohms more than 200 values
Capacitive Loading = 100 = 750 pF
RIAA Curve Accuracy = +/- .1 dB 20 = 20 KHz Passive / Active EQ
Distortion and Noise = 0.004%; Quad matched low noise symmetrical JFET input; Double shielded low noise toroid
Dimensions = 17”w x 12.5”d x 4”h 8.7kg
Or visit me at :
Pass Labs XP17
Clarity123- Dealer\Reseller\Trader\Service Provider
- Number of posts : 865
Source(s): yes
Amplification: yes
Speakers: yes
» Pass Labs XP17 phono preamp
» Pass Labs XP12 class A pre amplifier
» (Sold) Pass Labs XOno Phono Preamp
» Pass Labs Phono Amp XP-17
