Floorstand Speaker Paradigm Monitor 9 S7 Used
Specification
One of the surface material a bit sticky, all drivers still in perfect condition.
RM2750
Contact Emir for more info
019-6873626
Specification
DESIGN | 4-driver, 2-1/2-way bass reflex, quasi-3rd-order resistive port, floorstanding model |
CROSSOVER | 3rd-order electro-acoustic at 2.0 kHz, 2nd-order electro-acoustic at 700 Hz (lower bass drivers) |
FREQUENCY RESPONSE ON-AXIS | ±2dB from 46 Hz - 22 kHz |
HIGH FREQUENCY DRIVER | 25-mm (1 in) S-PAL:tm: dome tweeter, ferro-fluid cooled and damped |
MID/BASS FREQUENCY DRIVER | 140-mm (5-1/2 in) S-PAL:tm: cone, 25-mm (1 in) high-temperature voice-coil, oversize ceramic / ferrite magnets, GRIP:tm: chassis |
LOW FREQUENCY EXTENSION | 31 Hz (DIN) |
LOW FREQUENCY DRIVER | Two 140-mm (5-1/2 in) carbon-infused polypropylene cones, 25-mm (1 in) high-temperature voice-coils, oversize ceramic / ferrite magnets, GRIP:tm: chassis |
SENSITIVITY ROOM / ANECHOIC | 91 dB / 88 dB |
FREQUENCY RESPONSE 30° OFF-AXIS | ±2dB from 46 Hz - 18 kHz |
SUITABLE AMPLIFIER POWER RANGE | 15 - 200 watts |
MAXIMUM INPUT POWER | 150 watts |
IMPEDANCE | Compatible with 8 ohms |
DIMENSIONS HXWXD | 40" × 6.875" × 10.5" (101.6cm × 17.5cm × 26.7cm) |
WEIGHT | 42 lbs. (19.1 kg |
RM2750
019-6873626
emir786- New Member
- Number of posts : 16
Registration date : 2018-10-19
» Paradigm Monitor Center 3 V7 Speaker SOLD
» Sold - Paradigm Monitor 7v1 floorstand tower speakers (Used)
» Paradigm Studio Series Floorstand & Center Speaker (SOLD)
» Paradigm Monitor 7v3 Speaker (used)(SOLD)
» Paradigm Monitor 7 S7 Floorstanding Speaker (Used)
