ARCAM SA20 INTEGRATED AMPLIFIER (USED)
TECHNICAL SPECIFICATIONS
Type: Solid-state, 2-channel integrated amplifier with built-in DAC, phonostage, and headphone amplifier
Analogue inputs: One MM phono input (via RCA jacks), three single-ended line-level inputs (via RCA jacks), one 3.5mm minijack
Digital inputs: Three S/PDIF (one coaxial, two optical)
Analogue outputs: One pre-out (via RCA jacks), RS232 home automation, one RJ45 network port
Supported sample rates: up to 192kHz
Input impedance:
High-level: 10kOhms
Phono: 47kOhms, 100pF
Output impedance (preamp): 230 Ohms
Headphone Loads: 16–2 KOhms
Power Output: 90Wpc @ 8 Ohms
20Hz–20kHz
Bandwidth: Not specified
Distortion: THD 0.002% – 80% power, 8 Ohm at 1kHz
Signal to Noise Ratio: Not specified
Dimensions (H×W×D): 87 ×433 ×323mm
Weight: 11.1kg
CONDITION:9/10
used about 1 year,come with original box and full accessories
PRICE : RM4350
FOR MORE INFO PLEASE CALL OR WHATAPPS
018-9742567 YANG
016-5368723 YUAN
Input impedance:
High-level: 10kOhms
20Hz–20kHz
Weight: 11.1kg
CONDITION:9/10
PRICE : RM4350
018-9742567 YANG
016-5368723 YUAN
YUAN- Frequent Contributor
- Number of posts : 131
» Arcam DV88 DVD/CD Player with Arcam DiVA A65+ integrated amplifier in black (used) SOLD
» Arcam FMJ A22 Integrated Amplifier (Used)
» Arcam A85 Integrated Amplifier (Used)
